10-25-2014, 16:14 | #1 (permalink) |
Insane Poster Join Date: Oct 2014
Member: 2280006 Status: Offline Thanks Meter: 15 | plz help i need file pm for nokia 808 rm-807 plz help i need file pm for nokia 808 rm-807 scan phone MCU Version: V 79u_sr2_12w20.10 12-10-12 RM-807 (c) Nokia IMEI Plain : 351965051133626 IMEI Spare : A351965051133620 IMEI SV : 33519650511336232F Phone Model: Nokia 808 PureView Category : Classic Phone Phone Type : RM-807 ================================================ Extended Phone Information ================================================ Product Serial Number: C7G826477 Product Code : 059M7N0 Basic Production Code: 059M5B9 Long Production SN : 0 MCU SW Version : V 79u_sr2_12w20.10 12-10-12 RM-807 (c) Nokia HW Version : 4010 RFIC Version : |Alli_4.b.1 DSP Version : 79u_sr2_12w20_2 APE BT Version : HCI Version 12 (rev. 64). LMP Version 36 (rev. 64). Manufacturer 3696. AHNE Version : 21 APE SW Core Version : 113.010.1508 Variant Version : 113.010.1508113.010.1508.01.01113.010.1508.C09.01 RETU Version : 35 TAHVO Version : 00 APE HW Version : 256 APE ADSP SW Version : 256 Wireless LAN ID : D0B:32:AD:25:30 Bluetooth ID : D0B:32:A8:43:30 CS Type : GSM850, GSM900, GSM1800, GSM1900, WCDMA I, WCDMA II, WCDMA IV, WCDMA V, WCDMA VIII ================================================ Simlock Information ================================================ CONFIG KEY : 0000000000000000 PROVIDER KEY : 2440700000000000 NETWORK NAME : Nokia Default;Finland LOCK COUNTERS : KEYPRESS 0/3, FBUS 0/10 SIMLOCK TABLE : Block [1] 1:Open 2:Open 3:Open 4:Open 5:Open Block [2] 1:Open 2:Open 3:Open 4:Open 5:Open Block [3] 1:Open 2:Open 3:Open 4:Open 5:Open Block [4] 1:Open 2:Open 3:Open 4:Open 5:Open Block [5] 1:Open 2:Open 3:Open 4:Open 5:Open Block [6] 1:Open 2:Open 3:Open 4:Open 5:Open Block [7] 1:Open 2:Open 3:Open 4:Open 5:Open SIMLOCK STATE : Not Locked SIMLOCK_TYPE : PA_SL3 (15-digit NCK) SIMLOCK_TEST : PASSED SECURITY_TEST : FAILED > Try SX4 "PM AUTH" > Then Write PM 1 and 309 SECURITY_CODE : ENCRYPTED CMLA_KEY : ABSENT SUPER_DONGLE_TEST : PASSED ================================================ SL3 Phone detected ================================================ * Firmware Version Downgrade will KILL PHONE !!! * Manual Full Erase WILL KILL PHONE!!! * Simlocks are in PM 120 Only... * PM 308 is Write Protected... PHONE_MODE : RF INACTIVE WARNING: DCC Unavailable in Current State Change Phone Mode to TEST MODE scan phone pm sx4 MCU Version: V 79u_sr2_12w20.10 12-10-12 RM-807 (c) Nokia IMEI Plain : 351965051133626 IMEI Spare : A351965051133620 IMEI SV : 33519650511336232F Phone Model: Nokia 808 PureView Category : Classic Phone Phone Type : RM-807 ================================================ SX4 Custom Keys Stand Alone Edition ================================================ >>> : SX4 Auth Successfull Selected PM File: D:\351965051133626\imp_351965051133626_RM-807_173718.pm Start Uploading PM... Field : 1 Sub : 0 Byte(s): 12 - Ok Field : 1 Sub : 1 Byte(s): 96 - Ok Field : 1 Sub : 2 Byte(s): 112 - Ok Field : 1 Sub : 4 Byte(s): 12 - Ok Field : 1 Sub : 6 Byte(s): 112 - Ok Field : 1 Sub : 7 Byte(s): 452 - Ok Field : 1 Sub : 8 Byte(s): 12 - Ok Field : 1 Sub : 13 Byte(s): 112 - Ok Field : 1 Sub : 15 Byte(s): 32 - Ok Field : 1 Sub : 16 Byte(s): 32 - Ok Field : 1 Sub : 17 Byte(s): 32 - Ok Field : 1 Sub : 18 Byte(s): 32 - Ok Field : 1 Sub : 19 Byte(s): 32 - Ok Field : 1 Sub : 22 Byte(s): 24 - Ok Field : 1 Sub : 26 Byte(s): 12 - Ok Field : 1 Sub : 27 Byte(s): 36 - Ok Field : 1 Sub : 28 Byte(s): 112 - Ok Field : 1 Sub : 29 Byte(s): 12 - Ok Field : 1 Sub : 30 Byte(s): 36 - Ok Field : 1 Sub : 31 Byte(s): 24 - Ok Field : 1 Sub : 32 Byte(s): 216 - Ok Field : 1 Sub : 33 Byte(s): 36 - Ok Field : 1 Sub : 35 Byte(s): 24 - Ok Field : 1 Sub : 36 Byte(s): 24 - Ok Field : 1 Sub : 38 Byte(s): 216 - Ok Field : 1 Sub : 39 Byte(s): 36 - Ok Field : 1 Sub : 40 Byte(s): 24 - Ok Field : 1 Sub : 41 Byte(s): 216 - Ok Field : 1 Sub : 43 Byte(s): 36 - Ok Field : 1 Sub : 44 Byte(s): 216 - Ok Field : 1 Sub : 45 Byte(s): 216 - Ok Field : 4 Sub : 1 Byte(s): 200 - Ok Field : 4 Sub : 3 Byte(s): 12 - Ok Field : 4 Sub : 4 Byte(s): 8 - Ok Field : 4 Sub : 5 Byte(s): 8 - Ok Field : 4 Sub : 9 Byte(s): 8 - Ok Field : 4 Sub : 28 Byte(s): 4 - Ok Field : 120 Sub : 0 Byte(s): 944 - Ok Field : 120 Sub : 1 Byte(s): 160 - Ok Field : 120 Sub : 2 Byte(s): 132 - Ok Field : 120 Sub : 3 Byte(s): 112 - Ok Field : 308 Sub : 1 Super Dongle Key Found Field : 308 Sub : 1 Write Super Dongle Key - OK Field : 308 Sub : 1 CMLA Key Found Field : 308 Sub : 1 Write CMLA Key - Failed Field : 309 Sub : 0 Byte(s): 4 - Ok Field : 309 Sub : 1 Byte(s): 4 - Ok Field : 309 Sub : 2 Byte(s): 12 - Ok Field : 309 Sub : 3 Byte(s): 36 - Ok Field : 309 Sub : 4 Byte(s): 12 - Ok Field : 309 Sub : 7 Byte(s): 12 - Ok Field : 309 Sub : 17 Byte(s): 12 - Ok Field : 341 Sub : 0 Byte(s): 4 - Ok Field : 341 Sub : 3 Byte(s): 4 - Ok Field : 341 Sub : 4 Byte(s): 4528 - Ok Field : 341 Sub : 12 Byte(s): 328 - Ok Field : 341 Sub : 15 Byte(s): 940 - Ok PM Upload Done!... |
11-13-2014, 18:15 | #3 (permalink) |
No Life Poster Join Date: Jan 2014
Member: 2100013 Status: Offline Thanks Meter: 125 | What is your situation? This problem has not yet resolved? In fact, it is easy to solve because I tried, my solution is to back up all the Certificates, and then erases and re-FLASHING, write RPL, repair super dongle, SX4 Auth, write FULL PM, writes PP completely factory settings, |
11-14-2014, 16:32 | #4 (permalink) |
Member: 2100013 Status: Offline Thanks Meter: 125 | WARNING! ! Now absolutely beyond repair£¡£¡ NOKIA 808_RM-807 PureView ASHA 311_RM-714 ROOT KEY HASH: 6D956B2D26FEC3C784E216492B7CC90A Not ERASE! Otherwise, data can not be repaired! |
