Go Back   GSM-Forum > Product Support Sections > No More Supported Solutions (Dead Products) > No More Supported H/W Products > Advance-Box
Old 11-25-2014, 11:36   #1 (permalink)
Member: 1508116
Sonork: none
Thanks Meter: 21
ATF Nitro Can`t Flash dct4 phone Please help me ATF team
Hi! ATF Team I buy ATF nitro few days ago. i install it already, i follow this procedure:
install ATF main Software which is v11.70
After you install ATF 11.70, you will see 2 Folders inside
C:\AdvanceBox Turbo Flasher\OpenSSL\
DLL_32-BIT
DLL_64-BIT
Now inside each folder are 2 dll Files...
Try First to copy the 2 files from DLL_32-BIT, and paste it to
overwrite the current files there.
Update important files
Check Software Updates
Restore Box
Update Firmware
Screen Shot
Now Here is my problem can`t flash, scan phone also cant buscheck
cable that i used rj45 and X-Fbus II.
Note:Phone is in local mode and working
But in BB5 working perfectly with the same cable X-fbusII that i used
please help ATF TEAM what is wrong for my procedure.
Old 11-26-2014, 01:54   #2 (permalink)
Member: 1508116
Sonork: none
Thanks Meter: 21
up this thread hoping will notice to the PM ang PS.
I need to be function the DCT4 cause til a lot of people use in my locality.
The Following User Says Thank You to joshua ontoy For This Useful Post:
Old 11-26-2014, 04:51   #3 (permalink)
niaz muhammad's Avatar
Member: 1519396
Sonork: 100.1612702
Thanks Meter: 1,951
chik box fbus pin is daimag i chik 100% don
The Following User Says Thank You to niaz muhammad For This Useful Post:
Old 11-26-2014, 07:40   #4 (permalink)
Member: 1508116
Sonork: none
Thanks Meter: 21
But My X-Fbus II sir, is fully worked, i test it also with BB5 like 7210c and n73 it work perfectly.
Old 11-26-2014, 11:05   #5 (permalink)
Member: 1508116
Sonork: none
Thanks Meter: 21
until now my problem not solve. Product manager & product supporter please help me.
I just want to restore EEprom this box but i become uncertain maybe it damage my atf nitro cause its new.
if i restore EEprom its need internet connection cause i use usb type (plug it) kind of internet. its need to remove also this.
Old 12-07-2014, 11:44   #6 (permalink)
Member: 174094
Thanks Meter: 74
DLL_32-BIT
DLL_64-BIT
Restore Box
Update Firmware
Screen Shot
yes same prob for me itry & in the end i collapse
Old 12-07-2014, 11:57   #7 (permalink)
Member: 1259144
it is cable problem try another
Page generated in 0.15527 seconds with 8 queries
