11-25-2014, 11:36 | #1 (permalink) |
Major Poster Join Date: Feb 2011 Location: philippines
Member: 1508116 Status: Offline Sonork: none Thanks Meter: 21 | ATF Nitro Can`t Flash dct4 phone Please help me ATF team install ATF main Software which is v11.70 After you install ATF 11.70, you will see 2 Folders inside C:\AdvanceBox Turbo Flasher\OpenSSL\ DLL_32-BIT DLL_64-BIT Now inside each folder are 2 dll Files... Try First to copy the 2 files from DLL_32-BIT, and paste it to C:\AdvanceBox Turbo Flasher\ overwrite the current files there. Update important files Check Software Updates Restore Box Update Firmware Screen Shot Now Here is my problem can`t flash, scan phone also cant buscheck cable that i used rj45 and X-Fbus II. Note:Phone is in local mode and working But in BB5 working perfectly with the same cable X-fbusII that i used please help ATF TEAM what is wrong for my procedure. |
11-26-2014, 01:54 | #2 (permalink) |
Member: 1508116 Status: Offline Sonork: none Thanks Meter: 21 | up this thread hoping will notice to the PM ang PS. I need to be function the DCT4 cause til a lot of people use in my locality. |
The Following User Says Thank You to joshua ontoy For This Useful Post: |
11-26-2014, 04:51 | #3 (permalink) |
No Life Poster Join Date: Feb 2011 Location: ( United States Of Islam ) Age: 35
Member: 1519396 Status: Offline Sonork: 100.1612702 Thanks Meter: 1,951 | chik box fbus pin is daimag i chik 100% don |
The Following User Says Thank You to niaz muhammad For This Useful Post: |
11-26-2014, 11:05 | #5 (permalink) |
Member: 1508116 Status: Offline Sonork: none Thanks Meter: 21 | until now my problem not solve. Product manager & product supporter please help me. I just want to restore EEprom this box but i become uncertain maybe it damage my atf nitro cause its new. if i restore EEprom its need internet connection cause i use usb type (plug it) kind of internet. its need to remove also this. |
12-07-2014, 11:44 | #6 (permalink) | |
No Life Poster Join Date: Aug 2005 Age: 71
Member: 174094 Status: Offline Thanks Meter: 74 | Quote:
yes same prob for me itry & in the end i collapse | |
