Go Back   GSM-Forum > Product Support Sections > Hard/Software Products (official support) > Advance-Box
Old 08-14-2013, 15:43   #1 (permalink)
Member: 570252
Thanks Meter: 164
Red face ATF nokia 301 can't reset or flash - [SOLVED]
cant reset phone or even flash it
i've reinstalled nokia connectivity driver and upgraded to latest version from http://nds1.nokia.com/Nokia_Connecti...ble_Driver.exe
and same
phone info from sticker
nokia
type: rm-840
model : 301.1
code : 059r203
Old 08-15-2013, 13:46   #2 (permalink)
Member: 570252
Thanks Meter: 164
support need solution................
Old 08-15-2013, 13:54   #3 (permalink)
..::Angel::..'s Avatar
Member: 643472
Sonork: 100.96901
Thanks Meter: 16,490
Hi, need to full flash phone, select files and flash in dead usb mode.
Old 08-15-2013, 13:59   #4 (permalink)
Member: 570252
Thanks Meter: 164
Wink
Number of Image Files: 3
Processing Image File :
 rm840__02.03b.mcusw
 rm840__02.03b.ppm_e3
 rm840__02.03b.image_e3_059R1S2
AUTO SELECTED DEAD USB FLASHING...
If Phone Booting does not Start in 5 Seconds,
Then Perform Steps 1, 2, and 3...
1. Remove USB Cable and Battery...
2. Connect USB Cable.
3. Connect Battery.
***** IF PHONE STARTS CHARGING OR DOES NOT BOOT *****
******* REMOVE BATTERY AND PUT IT BACK AGAIN. *******
Infineon Boot: F01650A9070100030101E00018090004846449DA8234FFFF
         <<<< Connect Battery Now >>>>
Sending PBL...
PBL Successfully Sent...
Sending SBL...
SBL Successfully Sent...
Flash Chip Manufacturer: STMicroelectronics
Flash Boot Successful...
Unique Data: E000180900048464-49DA8234
Original Product Code: 059R203
Reading : CCC... OK!
Reading : HWC... OK!
Reading : NPC... OK!
RPL Backup was Successful...
 Plain RPL saved to:
 C:\AdvanceBox Turbo Flasher\Nokia\Backup\355520054263676\355520054263676_135839.rpl
Current File    : rm840__02.03b.mcusw
Number of Images: 8
psi_flash_unsigned.fls
slb_signed.fls
main_toc_signed.fls
rm840__02.03b.mcusw_signed_mcusw.fls
swap_signed.fls s
dynsw.fls
aeneas_signed.fls s
fota_signed.fls s
Processing Data Block 0x00
Erase Block: 0x00090000~0x000A0FDE
Start Erasing...
Erasing Please Wait...
Block Erase Done...
Start Writing...
Finalizing...
Data Block Write Done...
Processing Data Block 0x01
Erase Block: 0x60000000~0x6003FFFE
Start Erasing...
Block Erase Done...
Start Writing...
Finalizing...
Processing Data Block 0x02
Erase Block: 0x60040000~0x600403FE
Start Erasing...
Block Erase Done...
Start Writing...
Finalizing...
Processing Data Block 0x03
Erase Block: 0x62E00000~0x63D03DCA
Start Erasing...
Block Erase Done...
Start Writing...
Finalizing...
Erase Block: 0xFFF00000~0xFFF7FFFE
Start Erasing...
Block Erase Done...
Processing Data Block 0x04
Erase Block: 0x80000000~0x80C13E9A
Start Erasing...
Block Erase Done...
Start Writing...
Finalizing...
Processing Data Block 0x05
Erase Block: 0x62080000~0x620C3FFE
Start Erasing...
Block Erase Done...
Start Writing...
Finalizing...
Processing Data Block 0x06
Erase Block: 0x63F79C00~0x63FF046E
Start Erasing...
Block Erase Done...
Start Writing...
Finalizing...
Processing Data Block 0x07
Erase Block: 0x61F00004~0x62045396
Start Erasing...
Block Erase Done...
Start Writing...
Finalizing...
Current File    : rm840__02.03b.ppm_e3
Number of Images: 1
package_e3.ppm_ebl_psi.fls
Erase Block: 0x80F00000~0x816340E2
Start Erasing...
Block Erase Done...
Start Writing...
Finalizing...
Current File    : rm840__02.03b.image_e3_059R1S2
Number of Images: 1
package_e3_059R1S2.image.fls
Erase Block: 0xA1000000~0xA27597FE
Start Erasing...
Block Erase Done...
Start Writing...
Finalizing...
Erase Block: 0xAE000000~0xAE2FFFFE
Start Erasing...
Block Erase Done...
Total Flashing Time (Erase + Flashing) : 00:00:15
(Booting time is NOT Included)
Waiting for Phone to Start-Up..(Max 150 seconds)
Scanning USB Ports...
             Basic Phone Information
MCU Version: V 02.03b 08-04-13 RM-840 (c) Nokia
IMEI Plain : 355520054263676
IMEI Spare : A355520054263670
IMEI SV    : 33555200542636704F
Phone Model: Nokia 301
Category   : Phone
Phone Type : RM-840
            Extended Phone Information
Product Serial Number: 0692727BH
Product Code         : 059R203
Module Code          : 0205267
Basic Production Code: 059P5R1
Long Production SN   : 0
PPM SW Version       : V 02.03b 08-04-13 RM-840 (c) Nokia            E3
BT MCM Version       : 19e2-4702G12
ADSP Version         : PMU_MAXIM8939B
MCU SW Version       : V 02.03b 08-04-13 RM-840 (c) Nokia
HW Version           : 1000
UPP Version          : MFR:0x20,DEV:0x40,REV:0x131
RFIC Version         : 152
LCD Version          : TPO
Camera               : 01035602006004
Content Pack Version : Content: e3_059R1S2 V 02.03b 08-04-13 RM-840 (c) Nokia
AHNE Version         : 13
RETU Version         : PMU_MAXIM8939B
Bluetooth ID         : F4:F5:A5:E6:F4:D1
CS Type              : GSM850, GSM900, GSM1800, GSM1900, WCDMA I, WCDMA VIII
  ********** SIMLOCK INFO  **********
CONFIG_DATA  : 0010100000000000
PROFILE_BITS : 800000000004000B
ASIC         : 11
PROVIDER     : Default Test Operator
LOCK COUNTERS: KEYPRESS 0/3,  FBUS 0/10
   Block [1]  1:Open 2:Open 3:Open 4:Open 5:Open
   Block [2]  1:Open 2:Open 3:Open 4:Open 5:Open
   Block [3]  1:Open 2:Open 3:Open 4:Open 5:Open
   Block [4]  1:Open 2:Open 3:Open 4:Open 5:Open
   Block [5]  1:Open 2:Open 3:Open 4:Open 5:Open
   Block [6]  1:Open 2:Open 3:Open 4:Open 5:Open
   Block [7]  1:Open 2:Open 3:Open 4:Open 5:Open
SIMLOCK_TYPE             : PA_SIMLOC30 (20-digit NCK)
SIMLOCK_TEST             : PASSED
SECURITY_TEST           : PASSED
SECURITY_CODE          : 42420
PHONE_MODE              : TEST
          Dynamic Camera Configuration
DCC ID  : 01035602
DCC Ver: 006004
Status   : OK
Selected VPL File:
RM840_059R1S2_02.03b_030.vpl
Variant Details     : RM-840 EURO_E3_WHITE_LATIN_RO
Software Version : 02.03b
Product Type       : RM-840
Product Code      : 059R1S2
Variant Version    : 030
FACTORY SET TO : Full Factory Set
 OK
FACTORY SET TO : User Data
 OK
FACTORY SET TO : Leave Factory
 OK
FACTORY SET TO : Service Center
 OK
FACTORY SET TO : Software Upgrade
 OK
FACTORY SET TO : Production Tune
 OK
RESET LIFE TIMER TO : 0000:00
 OK
Old 10-11-2013, 15:53   #5 (permalink)
Member: 236764
Thanks Meter: 11
 rm840__02.03b.mcusw
3. Connect Battery.
Sending PBL...
Sending SBL...
 Plain RPL saved to:
Number of Images: 8
slb_signed.fls
main_toc_signed.fls
swap_signed.fls s
dynsw.fls
aeneas_signed.fls s
fota_signed.fls s
Start Erasing...
Block Erase Done...
Start Writing...
Finalizing...
Start Erasing...
Block Erase Done...
Start Writing...
Finalizing...
Start Erasing...
Block Erase Done...
Start Writing...
Finalizing...
Start Erasing...
Block Erase Done...
Start Writing...
Finalizing...
Start Erasing...
Block Erase Done...
Start Erasing...
Block Erase Done...
Start Writing...
Finalizing...
Start Erasing...
Block Erase Done...
Start Writing...
Finalizing...
Start Erasing...
Block Erase Done...
Start Writing...
Finalizing...
Start Erasing...
Block Erase Done...
Start Writing...
Finalizing...
Number of Images: 1
Start Erasing...
Block Erase Done...
Start Writing...
Finalizing...
Number of Images: 1
Start Erasing...
Block Erase Done...
Start Writing...
Finalizing...
Start Erasing...
Block Erase Done...
Category   : Phone
Phone Type : RM-840
HW Version           : 1000
RFIC Version         : 152
LCD Version          : TPO
AHNE Version         : 13
ASIC         : 11
PHONE_MODE              : TEST
DCC ID  : 01035602
DCC Ver: 006004
Status   : OK
Selected VPL File:
 OK
 OK
 OK
 OK
 OK
 OK
 OK
what's driver use for this phone...
i try flash this phone but always have driver problem ..
Old 10-11-2013, 19:27   #6 (permalink)
.::MASTER ALONE::.'s Avatar
Member: 1587480
Sonork: 100.1618317
Thanks Meter: 2,134
Install Nokia Latest Driver Installer..
WBR.
Arsalan gsm2000.
Old 10-22-2013, 16:56   #7 (permalink)
Member: 2051162
I need help for unlocking Nokia 301, what I must to do?
Can somebody help to me and show step by step about unlocking Nokia 301.1
I am new here on this forum.
plz and thank you
Old 10-22-2013, 17:27   #8 (permalink)
Member: 643472
Sonork: 100.96901
@slavuj
Nokia 301 isn't supported for Network Unlock.
Old 03-12-2014, 23:23   #9 (permalink)
dcosmin22's Avatar
Member: 1716439
Thanks Meter: 32
unlock 301.1
hey, got nokia 301.1 which is 20 digits unlock
MCU Version: V 08.02 18-11-13 RM-840 (c) Nokia
IMEI Plain : 359956052262631
IMEI Spare : A359956052262630
IMEI SV : 33599560522626322F
Category : Phone
Phone Type : RM-840
Product Serial Number: 40E8DF7BH
Product Code : 059S693
Module Code : 0205271
PPM SW Version : V 08.02 18-11-13 RM-840 (c) Nokia E2
MCU SW Version : V 08.02 18-11-13 RM-840 (c) Nokia
HW Version : 1200
UPP Version : MFR:0xec,DEV:0x40,REV:0x231
RFIC Version : 152
LCD Version : TPO
Camera : 01035602006003
Content Pack Version : Content: e2_059Q939 V 08.02 18-11-13 RM-840 (c) Nokia
AHNE Version : 13
Bluetooth ID : 2C:5A:05:99:E0:B1
CONFIG_DATA : 0000000000000000
PROFILE_BITS : 0000000000040000
ASIC : 11
PROVIDER : Unknown Provider
Unable to read SP Data..
SIMLOCK_TEST : FAILED
SECURITY_CODE : 12345
PHONE_MODE : NORMAL
DCC ID : 01035602
DCC Ver: 006003
Status : OK
Selected VPL File:
RM840_059S693_08.02_037.vpl
Variant Details : RM-840 VAR EURO-E2 ES VODAFONE SL BLACK
Software Version : 08.02
Variant Version : 037
im not able to put the unlock code.
it wont accept it and it is source code unlock.
Sending SP code: #pw+07318144783561883085+7#
Sending FBUS Command
FBUS Command Sent
ERROR: Bad PM 120, 3
Old 03-26-2014, 12:21   #10 (permalink)
Member: 1693369
Thanks Meter: 21
I can not flash this phone. all drivers are installed but atf don't connect to the phone.
i don have such problem with other nokia phones only 301
Old 03-05-2016, 10:45   #11 (permalink)
Crazy Poster
Member: 1731024
Thanks Meter: 12
Try to install last nokia usb driver and do full flash for this mobile
Page generated in 0.40128 seconds with 8 queries
