Go Back   GSM-Forum > Product Support Sections > Hard/Software Products (official support) > Advance-Box
Old 12-07-2011, 10:52   #1 (permalink)
Advance-Box's Avatar
Member: 651945
Thanks Meter: 20,031
ATF Nokia 303 RM-763 First In The World USB Flashing !!!
1. You do not need to Update anything,,, you can see in Screenshots
I am using old ATF Software 7.95 only...
2. After Flashing, Phone may not be detected immediately if you are using
Windows 7 Operating System. But Do not worry, just click scan phone
again and it will be detected.
Here are the Screenshots:
Here are the Logs:
Number of Image Files: 3
Processing Image File :
 rm763__13.44.mcusw
CMT Type : BB5
CMT Algorithm : XSR 1.6
Secondary Sending Speed    : 650000Hz
Algorithm Sending Speed    : 6500000Hz
Program Sending Speed      : 6500000Hz
Message Reading Speed      : 98000Hz
Number of Blocks :  330
Entry Point:  0x02BB
Page Format : -1
MAX PAGE : 0x00020000
 rm763__13.44.ppm_q
CMT Type : BB5
Number of Blocks :  76
Entry Point:  0x0151
Page Format : -1
 rm763__13.44_001.image_q_ctv_hk_9m701
CMT Type : BB5
Number of Blocks :  367
Entry Point:  0x0182
Page Format : -1
[]: Found 1 active devices.
[Nokia USB Phonet]: Opening Connection
[Nokia USB Phonet]: Port opened OK!
SW: V 13.44 04-11-11 RM-763 (c) Nokia
IMEI: 358279042220416
CONFIG KEY    :  0000000000000000
PROVIDER KEY  :  2440700000000000
NETWORK NAME  :  Nokia Default;Finland
LOCK COUNTERS :  KEYPRESS 0/3,  FBUS 0/10
SIMLOCK TABLE :
   Block [1]  1:Open 2:Open 3:Open 4:Open 5:Open
   Block [2]  1:Open 2:Open 3:Open 4:Open 5:Open
   Block [3]  1:Open 2:Open 3:Open 4:Open 5:Open
   Block [4]  1:Open 2:Open 3:Open 4:Open 5:Open
   Block [5]  1:Open 2:Open 3:Open 4:Open 5:Open
   Block [6]  1:Open 2:Open 3:Open 4:Open 5:Open
   Block [7]  1:Open 2:Open 3:Open 4:Open 5:Open
SIMLOCK STATE :  Not Locked
 START FULL PM BACKUP
Please Wait...
Reading : PM 0~400... OK!
 FULL PM Backup Saved to:
 C:\AdvanceBox Turbo Flasher\Nokia\Backup\358279042220416\USB_FULL_BACKUP_V 13.44 04-11-11 RM-763 (c) Nokia_358279042220416_Not Locked_52401.pm
Reading battery value  : 3883 mV
Rebooting Phone...
AUTO SELECTED DEAD USB FLASHING...
 If Flashing DOES NOT Start in 5 Seconds,
 Then Perform Steps 1, 2, 3 and 4...
1. Remove USB and Battery...
2. Insert USB.
3. Insert Battery. (Some phones boot automatically)
4. Please Power on phone shortly...
AdvanceFBox SendBootCodeEx
InitialiseBootstrap_DCT5 DIR
BootFlashMode_DCT5
 Cant verify BootRom!
BootFlashMode_DCT5
 BootRom Verified!
BootFlashModeDCT5Ex Succeded After 2 Tries
SYSTEM_ID_RESPONSE_BB5 (0xC0) - 0  (0x00) bytes returned
Number of Sub Blocks 7 (0x07)
  1  SYSTEM_ASIC_ID 01
     Block Length  : 21  (15)
     BB ASIC Index : 0  (00)  CMT
     ID DWORD    0 : 00000003
     ID DWORD    1 : 00000226
     ID DWORD    2 : 00010007
     ID DWORD    3 : 400C1921
     ID DWORD    4 : 03032108
  2  EM_ASIC_ID 02
     Block Length  : 5  (05)
     ID DWORD    0 : 00001051
  3  EM_ASIC_ID 02
     ID DWORD    0 : 00001060
  4  PUBLIC_ID 12
     ID DWORD    0 : 7E0B0004
     ID DWORD    1 : FFFB3C40
     ID DWORD    2 : 9F95238A
     ID DWORD    3 : C9EC54FA
     ID DWORD    4 : 3CCED4DD
  5  ASIC_MODE_ID 13
     Block Length  : 2  (02)
     Mode Id       : 00
  6  ROOT_KEY_HASH 14
     Block Length  : 17  (11)
     Hash          :  3A B5 DB 70 B4 5D 23 F1 AD EE BB 57 34 16 07 06
  7  ROM_ID 15
     Block Length  : 9  (09)
     CRC         0 : 2CAC45E2
     CRC         1 : 3BC33C8B
 START FLASHING
RawLoaderExtract: rm763__13.44.mcusw
CMT Secondary Loader: C:\AdvanceBox Turbo Flasher\Nokia\BB5_Loader\BB5_USBLoaders\RAPUv21_2nd.fg
Secondary Loader Sent....
MCU_CONFIGURATION_RESPONSE_BB5:
 MessageID  : C1
 SubBlocks  : 06
 1 Sub Block ID      : 10  STORAGE_DEVICE_ID_BB5
   Block Length      : 0B
   BB ASIC Index     : CMT  00
   Device Type       : RAM  05
   Device Index      : 00
   Manufacturer Code : 0000 -> Flash
   Device ID         : 0000 -> not detected
   Extended/Fixed ID : 0000
   Revision ID       : 0000
 2 Sub Block ID      : 10  STORAGE_DEVICE_ID_BB5
   Block Length      : 0B
   Device Type       : MMC  04
   Device Index      : 00
   Manufacturer Code : FFFF -> Flash
   Device ID         : 0000 -> BAD FLASH TYPE
   Revision ID       : 0000
 3 Sub Block ID      : 10  STORAGE_DEVICE_ID_BB5
   Block Length      : 0B
   Device Type       : NOR  00
   Device Index      : 00
   Revision ID       : 0000
 4 Sub Block ID      : 10  STORAGE_DEVICE_ID_BB5
   Block Length      : 0B
   Device Index      : 01
   Manufacturer Code : 0000 -> SPANSION
   Device ID         : 0001 -> not used
   Revision ID       : 0000
 5 Sub Block ID      : 10  STORAGE_DEVICE_ID_BB5
   Block Length      : 0B
   Device Type       : MuxOneNAND  03
   Device Index      : 00
   Manufacturer Code : 00EC ->
   Device ID         : 0040 -> KAT00F00RA
   Revision ID       : 0241
 6 Sub Block ID      : 35  NAND_DRIVER_VERSION_BB5
   Block Length      : 09
   Data              :
SearchForBootstrap_DCT5  : No Error - 0 (0x00)
Flash Descriptor
   Device ID         : 0040
   Revision ID       : 0000
   Size              : 10000000 (256 MB)
   VPP Info          : 0000
   Erase10s          : 1E
   Block1s           : 32
   BErase1s          : 02
   Reserved0         : 00
   Reserved1         : 00
   Reserved2         : 00
CMT Algorithm Loader: C:\AdvanceBox Turbo Flasher\Nokia\BB5_Loader\BB5_USBLoaders\RAPUv21_XSR17_alg.fg
Algorithm Loader Sent...
FUR_Control_AddClient_BB5() ASIC_INDEX_CMT (Ready)
FUR control Ok
 START READING RPL DATA
Reading : NPC... OK!
Reading : CCC... OK!
Reading : HWC... OK!
Reading : R&D... OK!
RPL Backup was Successful...
 Plain RPL saved to:
 C:\AdvanceBox Turbo Flasher\Nokia\Backup\358279042220416\358279042220416_52427.rpl
Pabub KEY Request
PhoneInfoRequest_BB5 (Asic Index 00 )
PHONE_INFO_RESPONSE_BB5
  PAPUB_KEYS_HASH_RESP_BB5 2A
    BB Asic Index   : 00
CMT PAPUBKEYS HASH:
 ACE39760399CD7A3FE439DCC52111C24D435D533
ImagePath: C:\Nokia Firmware\Products\RM-763\
ImageFilename: rm763__13.44.mcusw
Read Type : FIASCO_BB5_DO_NOT_READ_CERTIFICATE (01)
Sending STORE_CERTIFICATE_REQUEST_BB5 (CMT  00 only)
Certificate 1
  ASIC Index  : CMT  0
Certificate 2
  ASIC Index  : CMT  0
Certificate 3
  ASIC Index  : CMT  0
Certificate 4
  ASIC Index  : CMT  0
STORE_CERTIFICATE_REQUEST_BB5 : 61 04 2B 0D 4E 50 43 00 00 00 00 00 00 00 00 00 00 2B 0D 43 43 43 00 00 00 00 00 00 00 00 00 00 2B 0D 48 57 43 00 00 00 00 00 00 00 00 00 00 2B 0D 52 26 44 00 00 00 00 00 00 00 00 00 00 D3
STORE_CERTIFICATE_REQUEST_BB5 : No Error - 0 (0x00)
ProcessPartitionInfo_DCT5...
Partition Info
    Partition Blocks :   1
     1   PARTITION_INFO_BB5
            BB ASIC Index     : 0x00 CMT
            Device Type       : 0x03 MuxOneNAND
            Device Index      : 0x00
            Partition Version : 00010000
            Spare             : FFFFFFFF
            Num Partitions    : 00000004
            Partition    1
              Attribute       : 00000002  RO
              Start Address   : 00140000
            Partition    2
              ID              : 00000008  FILESYSTEM
              Attribute       : 00000001  RW
              Start Address   : 03980000
            Partition    3
              Start Address   : 0F080000
            Partition    4
              Start Address   : 0F680000
PARTITION_INFO_REQUEST_BB5 : 64012F4F00030000010000FFFFFFFF00000004000000030000000200140000031C00000000000800000001039800000B7000000000000A000000010F080000006000000000000B000000010F68000000300000F0
PARTITION_INFO_REQUEST_BB5 : No Error - 0 (0x00)
ProcessPartitionInfo_DCT5 : No Error - 0 (0x00)
StartErase_DCT5...
BlockLength  :  0xE9  (233)
ERASE Blocks :  0x04  (4)
     0   ERASE_AREA_BB5 0x12
            Block Length     : 0x53 (83)
            Device Index     : 0x00
               0             : 00040000-000403FF
               1             : 000C0000-0013FFFF
               2             : 00140000-004BFFFF
               3             : 004C0000-0073FFFF
               4             : 00740000-0147FFFF
               5             : 00160000-0017FFFF
               6             : 03300000-0397FFFF
               7             : 0F080000-0F67FFFF
               8             : 01480000-0253FFFF
               9             : 02540000-026BFFFF
     1   FORMAT_PARTITION_BB5 0x19
            Block Length     : 0x2F (47)
            Device Index     : 0x00
            Format Info ID   : 0x02000000
            Format Info      : 00000000000000080000000000000002000000640000000200000002000000010000000000000000
     2   FORMAT_PARTITION_BB5 0x19
            Device Index     : 0x00
            Format Info      : 000000000000000A0000000100000002000000640000000200000002000000010000000000000000
     3   FORMAT_PARTITION_BB5 0x19
            Device Index     : 0x00
            Format Info      : 000000000000000B0000000000000002000000640000000200000002000000010000000000000000
ERASE_REQUEST_BB5 : 500A120B00030000040000000403FF120B000300000C00000013FFFF120B00030000140000004BFFFF120B000300004C00000073FFFF120B000300007400000147FFFF120B000300001600000017FFFF120B000300033000000397FFFF120B0003000F0800000F67FFFF120B000300014800000253FFFF120B00030002540000026BFFFFDC
FORMAT_REQUEST_BB5 : 5001192F00030000000002000000000000000800000000000000020000006400000002000000020000000100000000000000003E
FORMAT_REQUEST_BB5 : 5001192F00030000000002000000000000000A00000001000000020000006400000002000000020000000100000000000000003B
FORMAT_REQUEST_BB5 : 5001192F00030000000002000000000000000B00000000000000020000006400000002000000020000000100000000000000003B
Successfully erased..
Total blocks to write : 330
>>  CMT Rootkey Hash CERT : KEYS
>>  CMT Rootkey Hash CERT : PAPUBKEYS
>>  CMT Rootkey Hash CERT : DSP0
>>  CMT Rootkey Hash CERT : MCUSW
>>  CMT Rootkey Hash CERT : MCUSW1
>>  CMT Rootkey Hash CERT : GENIO_INIT
>>  CMT Rootkey Hash CERT : ISA+DYNSW
>>  CMT Rootkey Hash CERT : ADA
>>  CMT Rootkey Hash CERT : PRIMAPP
>>  CMT Rootkey Hash CERT : PASUBTOC
>>  CMT Rootkey Hash CERT : RAP3NAND
>>  CMT Rootkey Hash CERT : UPDAPP
>>  CMT Rootkey Hash CERT : ISA+EXTDRV
ImageFilename: rm763__13.44.ppm_q
StartErase_DCT5...
BlockLength  :  0x0E  (14)
ERASE Blocks :  0x01  (1)
            Block Length     : 0x0B (11)
            Device Index     : 0x00
               0             : 026C0000-032FFFFF
ERASE_REQUEST_BB5 : 5001120B000300026C0000032FFFFF40
Total blocks to write : 76
ImageFilename: rm763__13.44_001.image_q_ctv_hk_9m701
StartErase_DCT5...
BlockLength  :  0x3F  (63)
ERASE Blocks :  0x02  (2)
            Device Index     : 0x00
               0             : 03980000-0F07FFFF
            Device Index     : 0x00
ERASE_REQUEST_BB5 : 5001120B000300039800000F07FFFF2F
Total blocks to write : 367
ContinueFlash_DCT5 Complete
Continue Flash Complete :  : No Error - 0 (0x00)
Status_BB5 STATUS_REQUEST_BB5..
1  Sub Block ID      : 15 STATUS_NAND_OK_BB5
          Block Length      :  0F
          BB ASIC Index     :  00
          Device Type       :  03
          Device Type       :  00
          Num Bad Blocks    :  00000005
          Additional Bad    :  00000005
          Correctable ECC   :  00000000
FlashInfo.RestartMode : 2
Flashing Done...
Total Flashing Time (Erase + Flashing) : 00:00:22
(Booting time is NOT Included)
Waiting for Phone to Start-Up..(Max 150 seconds)
Elapsed Time: 5 Seconds...
Elapsed Time: 10 Seconds...
Elapsed Time: 15 Seconds...
Elapsed Time: 20 Seconds...
Elapsed Time: 25 Seconds...
Elapsed Time: 30 Seconds...
Elapsed Time: 35 Seconds...
Elapsed Time: 40 Seconds...
Elapsed Time: 45 Seconds...
Elapsed Time: 50 Seconds...
Elapsed Time: 55 Seconds...
Elapsed Time: 60 Seconds...
Elapsed Time: 65 Seconds...
Elapsed Time: 70 Seconds...
Elapsed Time: 75 Seconds...
Elapsed Time: 80 Seconds...
Elapsed Time: 85 Seconds...
Elapsed Time: 90 Seconds...
Elapsed Time: 95 Seconds...
Elapsed Time: 100 Seconds...
Elapsed Time: 105 Seconds...
Elapsed Time: 110 Seconds...
Elapsed Time: 115 Seconds...
Elapsed Time: 120 Seconds...
Elapsed Time: 125 Seconds...
Elapsed Time: 130 Seconds...
Elapsed Time: 135 Seconds...
Elapsed Time: 140 Seconds...
Elapsed Time: 145 Seconds...
Elapsed Time: 150 Seconds...
 WARNING: Phone is not in the Required Mode...
 Disconnect the Phone and Power it Up Manually.
Scanning USB Ports...
             Basic Phone Information
MCU Version: V 13.44 04-11-11 RM-763 (c) Nokia
IMEI Plain : 358279042220416
IMEI Spare : A358279042220410
IMEI SV    : 33582790422204104F
Phone Model: Nokia 303
Category   : Phone
Phone Type : RM-763
            Extended Phone Information
Product Serial Number: E119969AI
Product Code         : 059J1G7
Module Code          : 0205121
Basic Production Code: 059G7H1
Long Production SN   : 0
PPM SW Version       : V 13.44 04-11-11 RM-763 (c) Nokia             Q
BT MCM Version       : 4217-v924
MCU SW Version       : V 13.44 04-11-11 RM-763 (c) Nokia
HW Version           : 2000
RFIC Version         : |Alli_4.b.1
DSP Version          : 104_MP5.1_13.44
LCD Version          : TPO
FWID Version         : iV 13.44 04-11-11 RM-763 (c) Nokia            V 13.44 04-11-11 RM-763 (c) Nokia             Q 059J1G7 001
Content Pack Version : Content: ctv HK V 13.44 04-11-11 RM-763 (c) Nokia
AHNE Version         : 21
RETU Version         : 51
TAHVO Version        : 00
Wireless LAN ID      : 14:36:05:73:B2:11
Bluetooth ID         : 14:36:05:73:5C:21
CS Type              : GSM850, GSM900, GSM1800, GSM1900, WCDMA I, WCDMA II, WCDMA IV, WCDMA V, WCDMA VIII
               Simlock Information
SIMLOCK TABLE :
SIMLOCK_TYPE             : PA_SL3 (15-digit NCK)
SIMLOCK_TEST             : PASSED
SECURITY_TEST           : PASSED
SECURITY_CODE          : 12345
PHONE_MODE              : TEST
          Dynamic Camera Configuration
DCC ID  : 0C219802
DCC Ver: 004005
Status   : OK
FACTORY SET TO : Full Factory Set
 OK
FACTORY SET TO : User Data
 OK
FACTORY SET TO : Leave Factory
 OK
FACTORY SET TO : Service Center
 OK
FACTORY SET TO : Software Upgrade
 OK
FACTORY SET TO : Production Tune
 OK
Here is the Phone:
Always Tested Flashing
Come and Join the Experience...
The Following 7 Users Say Thank You to Advance-Box For This Useful Post:
Old 12-07-2011, 10:55   #2 (permalink)
asad_nomy7's Avatar
Member: 570093
Thanks Meter: 871
Alwaya The First.thanks ATF team.
Old 12-07-2011, 11:18   #3 (permalink)
mianjabbar's Avatar
Member: 481915
Sonork: 100.1604233
Thanks Meter: 451
great work , hard working team but silent in door work..........
thanks
MIANLINKS
Old 12-07-2011, 15:01   #4 (permalink)
.::Gsm-Play::.'s Avatar
Member: 1615596
Sonork: 100.1607045
Thanks Meter: 663
Arrow
Thnx atf team very good info.always first...................our team
Old 12-08-2011, 03:03   #5 (permalink)
zishanm's Avatar
Member: 1535468
Sonork: 100.161922
Thanks Meter: 120
thanks atf team is very nice feed back...............is good workssssssssssssssssssssssssssssssssssssssssssssss sss
Old 12-08-2011, 06:00   #6 (permalink)
Nadeem Waris's Avatar
Member: 1080718
Sonork: 100.1596539 QQ-2710826805
Thanks Meter: 1,801
Great job thanks ATF team thanks alot
The Following User Says Thank You to Nadeem Waris For This Useful Post:
Old 12-11-2011, 13:30   #7 (permalink)
Member: 865077
Sonork: appi
Thanks Meter: 3
nokia 7230 flashing 4 usb mode pls help
Old 12-11-2011, 13:37   #8 (permalink)
easir.comilla_e's Avatar
Member: 1488757
Thanks Meter: 90
boss....nokia..6303ci...rm-638...flash.file.me...link...
Old 12-11-2011, 13:40   #9 (permalink)
Member: 1488757
Thanks Meter: 90
Nokia 303 RM-763 flash file holp me
The Following User Says Thank You to easir.comilla_e For This Useful Post:
Old 12-11-2011, 13:41   #10 (permalink)
Member: 296577
Thanks Meter: 126
brother just download this and your problem solved 1000000%
NAVIFIRM_V1.5.2.rar - 4shared.com - online file sharing and storage - download
Old 12-11-2011, 13:55   #11 (permalink)
Member: 1488757
Thanks Meter: 90
Old 12-12-2011, 08:48   #12 (permalink)
Member: 1488757
Thanks Meter: 90
Old 12-12-2011, 10:17   #13 (permalink)
Member: 494057
Thanks Meter: 2
Atf box vs mt box?
dear sir i wana buy a box for my shop pls sagest me witch box goog for nokia mobile set withc saport sl3 and rpl files i have atf light but its not good now i wana buy MT box or ATF box rply me now thx.
The Following User Says Thank You to baloch_mobile For This Useful Post:
Seeking for flash nokia 5110 old version (3 version) can exchange for new Tomas Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 8 10-14-2017 20:29
Page generated in 0.47613 seconds with 8 queries
