04-04-2013, 15:19 | #1 (permalink) |
Freak Poster Join Date: Oct 2009 Location: bangladesh
Member: 1142388 Status: Offline Sonork: 100.1617280 Thanks Meter: 85 | atf nokia lumia 710 flashing poblem Windows Phone Flashing Started OSBL File Found: RM803_12w18_prod_generic_nokia_osbl.esco AMSS File Found: RM803_12w18_prod_generic_amss.esco ADSP File Found: RM803_12w18_prod_generic_adsp.esco WPOS File Found: RM803_12180_prod_250_01_boot.esco USER AREA ERASE File Found: RM803_12w18_prod_generic_user_area_erase.esco ================================================== ==== Windows Phone Lumia Flasher ================================================== ==== If the Phone is ALIVE 1. Power On the Phone and Connect it to the USB Port If the Phone is DEAD 1. Press and Hold the VOLUME UP button 2. Connect it to the USB Port while still Pressing the VOLUME UP button 3. Continue to Press the VOLUME UP button for 8 more seconds ================================================== ==== Sending OSBL Certificate HASH: C72DBA3ABED42215584093FA9DE247381D6062B4 Certificate Size: 452 Bytes Status : WRITE OSBL CERTIFICATE SUCCESS Sending OSBL Data Blocks [BLOCK 1 0x00000000~0x000EA227] Data Size: 0x000EA228 Bytes SHA-256 : 8958B125792783B8738B72F8E583DFEA ---------- : B56CD367044EB16EDEA9BACAE740F77E ERROR: Data Rejected at SEQ 0x12 Status : OSBL WRITE FAILED plasehelp br, gsm_uzzal |
04-05-2013, 06:51 | #5 (permalink) |
No Life Poster Join Date: Dec 2007
Member: 651945 Status: Offline Thanks Meter: 20,118 | @gsm_uzzal Was the TP wires still connected when you tried to flash the phone? Sometimes the wires will cause Problem in normal flashing. After removing wires It will be ok. B.R. |
10-04-2013, 09:12 | #7 (permalink) |
Freak Poster Join Date: Jan 2011 Location: haryana in fatehabad Age: 36
Member: 1503356 Status: Offline Thanks Meter: 110 | lumia 710 dead flashing after ok with atf box Windows Phone Flashing Started OSBL File Found: RM803_11w48_prod_generic_nokia_osbl.esco AMSS File Found: RM803_11w46_5_prod_generic_amss.esco ADSP File Found: RM803_11w46_5_prod_generic_adsp.esco WPOS File Found: RM803_11465_prod_246_01_boot.esco USER AREA ERASE File Found: RM803_11w46_5_prod_generic_user_area_erase.esco ================================================== ==== Windows Phone Lumia Flasher ================================================== ==== If the Phone is ALIVE 1. Power On the Phone and Connect it to the USB Port If the Phone is DEAD 1. Press and Hold the VOLUME UP button 2. Connect it to the USB Port while still Pressing the VOLUME UP button 3. Continue to Press the VOLUME UP button for 8 more seconds ================================================== ==== --> 01B00BBB000000004B49434B <-- 01B00BBB000000004B49434B00000000000000000000000000 00000000000000000000000000000000000000000000000000 00000000000000000000000000000000000000000000000000 00000000000000000000000000000000000000000000000000 00000000000000000000000000000000000000000000000000 00000000000000000000000000000000000000000000000000 00000000000000000000000000000000000000000000000000 00000000000000000000000000000000000000000000000000 00000000000000000000000000000000000000000000000000 00000000000000000000000000000000000000000000000000 00000000000000000000000000000000000000000000000000 00000000000000000000000000000000000000000000000000 00000000000000000000000000000000000000000000000000 00000000000000000000000000000000000000000000000000 00000000000000000000000000000000000000000000000000 00000000000000000000000000000000000000000000000000 00000000000000000000000000000000000000000000000000 00000000000000000000000000000000000000000000000000 00000000000000000000000000000000000000000000000000 00000000000000000000000000000000000000000000000000 000000000000000000000000 --> 03B00BBB00000000 <-- 04B00BBB1000000001000100050001010A000000F074844E00 00000000000000000000000000000000000000000000000000 00000000000000000000000000000000000000000000000000 00000000000000000000000000000000000000000000000000 00000000000000000000000000000000000000000000000000 00000000000000000000000000000000000000000000000000 00000000000000000000000000000000000000000000000000 00000000000000000000000000000000000000000000000000 00000000000000000000000000000000000000000000000000 00000000000000000000000000000000000000000000000000 00000000000000000000000000000000000000000000000000 00000000000000000000000000000000000000000000000000 00000000000000000000000000000000000000000000000000 00000000000000000000000000000000000000000000000000 00000000000000000000000000000000000000000000000000 00000000000000000000000000000000000000000000000000 00000000000000000000000000000000000000000000000000 00000000000000000000000000000000000000000000000000 00000000000000000000000000000000000000000000000000 00000000000000000000000000000000000000000000000000 000000000000000000000000 --> 01B00BBB000000004B49434B <-- 01B00BBB000000004B49434B00000000000000000000000000 00000000000000000000000000000000000000000000000000 00000000000000000000000000000000000000000000000000 00000000000000000000000000000000000000000000000000 00000000000000000000000000000000000000000000000000 00000000000000000000000000000000000000000000000000 00000000000000000000000000000000000000000000000000 00000000000000000000000000000000000000000000000000 00000000000000000000000000000000000000000000000000 00000000000000000000000000000000000000000000000000 00000000000000000000000000000000000000000000000000 00000000000000000000000000000000000000000000000000 00000000000000000000000000000000000000000000000000 00000000000000000000000000000000000000000000000000 00000000000000000000000000000000000000000000000000 00000000000000000000000000000000000000000000000000 00000000000000000000000000000000000000000000000000 00000000000000000000000000000000000000000000000000 00000000000000000000000000000000000000000000000000 00000000000000000000000000000000000000000000000000 000000000000000000000000 Sending OSBL Certificate HASH: C72DBA3ABED42215584093FA9DE247381D6062B4 Certificate Size: 452 Bytes Status : WRITE OSBL CERTIFICATE SUCCESS Sending OSBL Data Blocks [BLOCK 1 0x00000000~0x000E8E27] Data Size: 0x000E8E28 Bytes SHA-256 : 535FE3FFF49F5268B35FFAC0574DC305 ---------- : F599FB8DD024C3D8725B2C0FCB2942A6 Status : OSBL WRITE SUCCESS Sending AMSS Certificate HASH: C72DBA3ABED42215584093FA9DE247381D6062B4 Certificate Size: 449 Bytes Status : WRITE AMSS CERTIFICATE SUCCESS Sending AMSS Data Blocks (Please Wait for 25 Seconds...) Status : AMSS WRITE SUCCESS Sending ADSP Certificate HASH: C72DBA3ABED42215584093FA9DE247381D6062B4 Certificate Size: 449 Bytes Status : WRITE ADSP CERTIFICATE SUCCESS Sending ADSP Data Blocks (Please Wait for 25 Seconds...) Status : ADSP WRITE SUCCESS Sending WPOS Certificate HASH: C72DBA3ABED42215584093FA9DE247381D6062B4 Certificate Size: 1748 Bytes Status : WRITE WPOS CERTIFICATE SUCCESS Sending WPOS Data Blocks [BLOCK 1 0x00000000~0x00FFFFFF] Data Size: 0x01000000 Bytes SHA-256 : 6B3EEFAA3825D4ADFD6B31DDED529467 ---------- : C970929EB50006E22EECE8FEC0C61FCB Status : WPOS WRITE SUCCESS [BLOCK 2 0x01000000~0x016573FF] Data Size: 0x00657400 Bytes SHA-256 : 30A3CAFE1702EE223926F270FF2FC040 ---------- : 04950931333436CBB6128A8BD69E98DE Status : WPOS WRITE SUCCESS [BLOCK 3 0x01697400~0x01FFFFFF] Data Size: 0x00968C00 Bytes SHA-256 : 750310128F59F3E5BE33CBB656991FDF ---------- : E2D282A47643A97861BE73CADC26A80C Status : WPOS WRITE SUCCESS [BLOCK 4 0x02000000~0x02FFFFFF] Data Size: 0x01000000 Bytes SHA-256 : E976923E3E62F4349847D47368C223EF ---------- : 7E7A96A3A857BB27E9CD426536464530 Status : WPOS WRITE SUCCESS [BLOCK 5 0x03000000~0x03FFFFFF] Data Size: 0x01000000 Bytes SHA-256 : 67E9D4AF82732E8D072A088CBFB031D7 ---------- : DA261AD0BFFF200A7B55C4448B05660E Status : WPOS WRITE SUCCESS [BLOCK 6 0x04000000~0x04FFFFFF] Data Size: 0x01000000 Bytes SHA-256 : 93988E62CD34682A085CC3078EAFE0D1 ---------- : D38792A9A7F736AC101E35D2720C0A4A Status : WPOS WRITE SUCCESS [BLOCK 7 0x05000000~0x05FFFFFF] Data Size: 0x01000000 Bytes SHA-256 : 5B8664492686DE7CED6C98AE40EC4F81 ---------- : 9D59E4ACF8DA009C88C5F47FFB8E2D06 Status : WPOS WRITE SUCCESS [BLOCK 8 0x06000000~0x06FFFFFF] Data Size: 0x01000000 Bytes SHA-256 : 63BEA079D1F59FC1903FC04945D5D9E6 ---------- : 04EF7C7F40D859A1E872CD6303303460 Status : WPOS WRITE SUCCESS [BLOCK 9 0x07000000~0x07FFFFFF] Data Size: 0x01000000 Bytes SHA-256 : 215C451CE77072B42471ADC5EAEBA53A ---------- : BA7CEA1330806F8BB43D27DDE6B7844C Status : WPOS WRITE SUCCESS [BLOCK 10 0x08000000~0x08FFFFFF] Data Size: 0x01000000 Bytes SHA-256 : E80ADA48A80B69520D07A172B7E02A77 ---------- : 9B46CE63AED4C84107C76759C9796FAE Status : WPOS WRITE SUCCESS [BLOCK 11 0x09000000~0x09FFFFFF] Data Size: 0x01000000 Bytes SHA-256 : E7BA8B66E6FB94A1B1B81CB5075B4F44 ---------- : E952DFA330C5665F0E1DCCC465AB2BE7 Status : WPOS WRITE SUCCESS [BLOCK 12 0x0A000000~0x0AFFFFFF] Data Size: 0x01000000 Bytes SHA-256 : 0B9109536ACE420EA35A28405CD7CF7E ---------- : FF3584605499B680F6F4DAB7FA64F16F Status : WPOS WRITE SUCCESS [BLOCK 13 0x0B000000~0x0BFFFFFF] Data Size: 0x01000000 Bytes SHA-256 : 13B0EB26C5B94432C4A23D35F58BD4A5 ---------- : 67C5B205AA668D105E8E4A9DCF09141E Status : WPOS WRITE SUCCESS [BLOCK 14 0x0C000000~0x0CFFFFFF] Data Size: 0x01000000 Bytes SHA-256 : 19607CA38E70126AC77F1FCF26FFE06E ---------- : 1CFEE113EFE67D7FE1C7DA5DE0A10BDE Status : WPOS WRITE SUCCESS [BLOCK 15 0x0D000000~0x0DFFFFFF] Data Size: 0x01000000 Bytes SHA-256 : 8E7AB98B8CB96DD9B75EF23B4F66F182 ---------- : AF69A08CAE81B7C815A742A6CA8B2C7D Status : WPOS WRITE SUCCESS [BLOCK 16 0x0E000000~0x0EFFFFFF] Data Size: 0x01000000 Bytes SHA-256 : 7210E13A56698ECBFF214DF873386010 ---------- : 7240E41BAFA99B3DE1F04E6D795E7C45 Status : WPOS WRITE SUCCESS [BLOCK 17 0x0F000000~0x0FFFFFFF] Data Size: 0x01000000 Bytes SHA-256 : 76D08AD1960C2ED9BD836C0ECF67C5E8 ---------- : 2BF6B9DE329110C77E8D2D51416300AF Status : WPOS WRITE SUCCESS [BLOCK 18 0x10000000~0x10FFFFFF] Data Size: 0x01000000 Bytes SHA-256 : 82053D1347991E98324003186232E235 ---------- : FDB84E9866D5F4B4622C5236A26B5172 Status : WPOS WRITE SUCCESS [BLOCK 19 0x11000000~0x11FFFFFF] Data Size: 0x01000000 Bytes SHA-256 : CE16BE3D8E9BF26CA5BF4C817C00691D ---------- : 5AF606A4191DDD42B27D6A75A9E34E1D Status : WPOS WRITE SUCCESS [BLOCK 20 0x12000000~0x12FFFFFF] Data Size: 0x01000000 Bytes SHA-256 : 3DD79408435D9EAE8881E21E6A78F251 ---------- : FA1C9BEB92428F6E9A03B743354503A8 Status : WPOS WRITE SUCCESS [BLOCK 21 0x13000000~0x13FFFFFF] Data Size: 0x01000000 Bytes SHA-256 : 3977B756FD729FF70162F600A2D10E56 ---------- : 8EE0019BBDB86B3B18A07F0D3EEAA24F Status : WPOS WRITE SUCCESS [BLOCK 22 0x14000000~0x14FFFFFF] Data Size: 0x01000000 Bytes SHA-256 : C1B0DFAE124D4D6434C5B960A4CFEF82 ---------- : F495FDCD8994DBF6257204D255B254EE Status : WPOS WRITE SUCCESS [BLOCK 23 0x15000000~0x15FFFFFF] Data Size: 0x01000000 Bytes SHA-256 : 759BDF05C9E62BFA99B64BF0747C0FE1 ---------- : A533CCA7A784E948BB67F758DD89B824 Status : WPOS WRITE SUCCESS [BLOCK 24 0x16000000~0x16FFFFFF] Data Size: 0x01000000 Bytes SHA-256 : 90277D0103509F7A5CB89AD139E94268 ---------- : 25F32232CFF1C514EDF173C1D746B001 Status : WPOS WRITE SUCCESS [BLOCK 25 0x17000000~0x17FFFFFF] Data Size: 0x01000000 Bytes SHA-256 : 373554FAC3292CECCAB1148536ECA10C ---------- : 82DF622A465F336850441044AF19E91A Status : WPOS WRITE SUCCESS [BLOCK 26 0x18000000~0x18FFFFFF] Data Size: 0x01000000 Bytes SHA-256 : 3DE122FD921533D5B4510DBE4AD8F716 ---------- : 2A9C8A4966CFC8C732F3B65A7D7A9CC3 Status : WPOS WRITE SUCCESS [BLOCK 27 0x19000000~0x19FFFFFF] Data Size: 0x01000000 Bytes SHA-256 : 55D8385508D3FDE71222037E73510320 ---------- : 00A66F778619C26FEAF99DEA034CE56A Status : WPOS WRITE SUCCESS [BLOCK 28 0x1A000000~0x1A7619FF] Data Size: 0x00761A00 Bytes SHA-256 : BEB74F4EC5DE5E8FB2859840FEF5E484 ---------- : DE23D6CDC44F27B1CC249F54E9D38EDE Status : WPOS WRITE SUCCESS Sending USER AREA ERASE Certificate HASH: C72DBA3ABED42215584093FA9DE247381D6062B4 Certificate Size: 396 Bytes Status : WRITE ERASE CERTIFICATE SUCCESS Erasing USER AREA Status : ERASE SUCCESS --> 01B00BBB000000004B49434B <-- 01B00BBB000000004B49434B00000000000000000000000000 00000000000000000000000000000000000000000000000000 00000000000000000000000000000000000000000000000000 00000000000000000000000000000000000000000000000000 00000000000000000000000000000000000000000000000000 00000000000000000000000000000000000000000000000000 00000000000000000000000000000000000000000000000000 00000000000000000000000000000000000000000000000000 00000000000000000000000000000000000000000000000000 00000000000000000000000000000000000000000000000000 00000000000000000000000000000000000000000000000000 00000000000000000000000000000000000000000000000000 00000000000000000000000000000000000000000000000000 00000000000000000000000000000000000000000000000000 00000000000000000000000000000000000000000000000000 00000000000000000000000000000000000000000000000000 00000000000000000000000000000000000000000000000000 00000000000000000000000000000000000000000000000000 00000000000000000000000000000000000000000000000000 00000000000000000000000000000000000000000000000000 000000000000000000000000 --> 02B00BBB00000000 Flashing Done! Total Flashing Time (Erase + Flashing) : 00:04:33 Last edited by r4raja007; 10-04-2013 at 09:21. |
The Following User Says Thank You to r4raja007 For This Useful Post: |
10-04-2013, 09:16 | #8 (permalink) |
Member: 1503356 Status: Offline Thanks Meter: 110 | lumia 710 info with atf Scanning USB Ports... Switching to NOKIA MODE [NCSD] Polling Ports... (Please Wait) ================================================ Basic Phone Information ================================================ SW Version : 1600.3007.7740.11465 IMEI Plain : 359300040361678 HW Version : 112.1402.2.1 Phone Type : RM-803 Product Code : 059M5L8 Basic Product Code: 059H4J0 Module Code : 0204985 PSN Number : MOL164211 NCSD Version : 1.5 Variant Information: Country Variant India RETAIL MODE India Black ================================================ Extended Phone Information ================================================ Public ID : CA3BA1F4C9F23EDD285B7EEB9C36F988 Wireless Lan ID: 6C:E9:07:27:F8:01:00:00 Bluetooth ID : 6C:E9:07:1B:C3:05:00:00:00:00:00:00 ================================================== ==== Selected VPL File: RM803_059M5L8_1600.3007.7740.11465_006.vpl ================================================== ==== Variant Details : Nokia 710 RM-803 Country Variant India RETAIL MODE India Black Software Version : 1600.3007.7740.11465 Product Type : RM-803 Product Code : 059M5L8 Variant Version : 006 |
