04-07-2014, 07:59 | #1 (permalink) |
No Life Poster Join Date: Oct 1999 Location: Shenzhen, Hong Kong, Bangkok
Member: 611 Status: Offline Sonork: 100.33333 Thanks Meter: 29,604 | ATF Nokia X Simlock IMEI v11.20 Update!! Public Discussion Thread: Firmware Version Required : 11.0.00 Nokia X Android Ultimate Tool ATF Uses a Built-in ADB Layer and it will Shutdown any Running ADB Servers on your PC if it finds anything running. You DO NOT NEED TO INSTALL ADB and FASTBOOT. You DO NOT NEED tO enter any codes to the phone just to read phone info Just install the correct Nokia X Drivers from: C:\AdvanceBox Turbo Flasher\Driver\NOKIA_X_USB_DRIVERS\ Nokia X Android Flash Engine --> Supports Normal Phone and Dead Phone Flashing --> Supports Flashing Custom Images (LEWA OS, TWRP Recovery etc.) --> Supports Manual Flashing for: Kernel, BOOT, RECOVERY, MODEM, UDISK, USER DATA, VARIANT, and PRELOAD Partitions Nokia X Android ROOT Kit - First In The World for 1-Click OFFLINE Solution --> Just a 1 Click Solution --> Supports Nokia X Firmware version 10.0.3 and 11.1.1 --> NO NEED INTERNET CONNECTION - 100% OFFLINE and less than 5 Seconds --> Also supports Samsung, HTC, LG and other brand ROOTING Nokia X Android Google Service Installer - First In The World for 1-Click Solution --> Just a 1 Click Solution --> Installs Google Services on ROOTED Phone --> Installs Google Store, TTS, Hangouts and other Important Google Services --> Optionally Installs KitKat 4.4 Launcher to improve Nokia X User Interface --> Fully Tested and Optimized for Nokia X vesion 10.0.3 and 11.1.1 Nokia X Android IMEI and Simlock Backup and Restore - First In The World --> Reads and Saves Encrypted EFS and NVBK (Requires ROOT) --> This EFFECTIVELY Saves the Phone's IMEI, SIMLOCKS and other Important Tuning Values --> Saves in PLAIN BINARY FORMAT --> Writes EFS and NVBK Backup to Phones (No ROOT Required) --> Can be used to Fix/Repair IMEI and Simlock of Phones *** DO NOT USE THIS FOR ILLEGAL PURPOSES SUCH AS IMEI CLONING NOkia X other BASIC FUNCTIONS Supported - First In The World --> Easily Switch between Normal, Recovery and Bootloader Modes --> Reads Phone Info in Normal Mode --> Reads eMMC Partition Info in Bootloader Mode Infineon XG-221 --> Fixed Flashing Support for Asha 230 and 230 DS --> Added Support for Asha 230 and 230 DS Decrypt PM 120 Other Changes --> Fixed ATF JTAG Activation Button --> Complete Product Listing in Nokia.ini as of April 7, 2014 ******************************* ATF JTAG 1.0.7 Build 3919 ******************************* Change Log * Added Support for Custom eMMC Read/Write --> Supports ALL Nokia WIN7 and WIN8 Devices except Lumia 1520 and Lumia Icon --> MSM7x27A, MSM8x55T, MSM8x25, MSM8x27, MSM8x60, MSM8x30 --> Saves Dumps in PLAIN BINARY Format * Added Nokia X RM-980 FULL BOOT REPAIR - First In The World * Added Cherry Mobile Flare 2.1 FULL BOOT REPAIR - First In The World * Added Starmobile Diamond V3 FULL BOOT REPAIR - First In The World (Thanks to Mark Pineda) * Added Samsung I8150 FULL BOOT REPAIR * Added Samsung I8552 FULL BOOT REPAIR Download Official AFP Files Here: http://www.4shared.com/folder/c0N1po2w/ATF_JTAG_AFP_FILES.html Special Thanks --> For this update we give special thanks to WAJID who tested Nokia X Rooting --> Special thanks to Chainfire for a WONDERFUL SuperSU.apk --> Special thanks to Kasha*****a for preparing the Google Services Tweak Who will buy this if you can get more in ATF? __________________________________________________ ________________________ Buy only from ATF [Advance Turbo Flasher] authorized resellers: ATF [Advance Turbo Flasher] Authorized Distributors and Resellers List ATF [Advance Turbo Flasher] official web sites: International - http://www.advance-box.com/ ATF [Advance Turbo Flasher] official support forums: World Wide: Advance Turbo Flasher - GSM-Forum Indonesia: ATF (Advance Turbo Flasher)) Philippine: Gsmph Syria: Arabic Support (Syria) GsmVIP Chinese support forum : ATF Box Vietnam: Saigonmobile India: Advance Box - .:: GsmIndia ::. Official Iran Support Forum : ASANGSM FORUM Bangladesh: Advance Box - Dhaka Mobile Chinese Support forum : www.yananliuhuan.com The Master Piece |
The Following 62 Users Say Thank You to gsmfun For This Useful Post: |
04-07-2014, 08:01 | #2 (permalink) |
No Life Poster Join Date: Dec 2007
Member: 651945 Status: Offline Thanks Meter: 20,117 | ROOTING NOKIA X 10.0.3 and 11.1.1 in 1 Click BEFORE DOING THE STEPS BELOW: 1. If you Updated ATF via the Autoupdate Server, then it means you DO NOT HAVE ROOTING and GOOGLE Services Files on your PC. You need to download and install this: ATF_ANDROID_ROOT_AND_GOOGLE_Installer - Download - 4shared - Linus Hernandez or this Download links for ATF_Android_ROOT_and_GOOGLE_Installer.rar - Mirrorcreator - Upload files to multiple hosts 2. If you get "Index Out Of Bounds" Error, you need to: 2a. Open C:\AdvanceBox Turbo Flasher\AdvanceBox.ini using NOTEPAD 2b. Add 2 lines on the bottom of the file. Type it manually or just copy paste below: Code: [ANDROID] PhoneSelectedIndex=0 NOKIA X Drivers are here: http://174.120.45.27/tmp/NOKIA_X_USB_DRIVERS.rar ROOTING NOKIA X 10.0.3 and 11.1.1 in 1 Click Step 1: Step 2: There is no more Step 2... you are Done! B.R. Last edited by Advance-Box; 04-07-2014 at 08:49. |
The Following 38 Users Say Thank You to Advance-Box For This Useful Post: |
04-07-2014, 08:01 | #3 (permalink) |
Member: 651945 Status: Offline Thanks Meter: 20,117 | INSTALLING GOOGLE SERVICES and KITKAT 4.4 LAUNCHER for NOKIA X 10.0.3 and 11.1.1 in 1 Click Step 1: Step 2: There is no more Step 2... you are Done! B.R. Last edited by Advance-Box; 04-07-2014 at 09:44. |
The Following 29 Users Say Thank You to Advance-Box For This Useful Post: |
04-07-2014, 08:01 | #4 (permalink) |
Member: 651945 Status: Offline Thanks Meter: 20,117 | Backup IMEI + SIMLOCKS + Tuning Values for NOKIA X 10.0.3 and 11.1.1 in 1 Click FIRST IN THE WORLD Step 1: Step 2: There is no more Step 2... you are Done! B.R. Last edited by Advance-Box; 04-07-2014 at 08:52. |
The Following 21 Users Say Thank You to Advance-Box For This Useful Post: |
04-07-2014, 08:02 | #5 (permalink) |
Member: 651945 Status: Offline Thanks Meter: 20,117 | RESTORE IMEI + SIMLOCKS + Tuning Values for NOKIA X 10.0.3 and 11.1.1 FIRST IN THE WORLD *** DO NOT USE THIS TO CLONE OTHER PEOPLES IMEI AND SIMLOCKS !!! YOU WILL GO TO JAIL*** Step 1: B.R. Last edited by Advance-Box; 04-07-2014 at 08:53. |
The Following 17 Users Say Thank You to Advance-Box For This Useful Post: |
04-07-2014, 08:13 | #6 (permalink) |
Freak Poster Join Date: Oct 2007 Location: @GsmHosting.com Age: 39
Member: 601608 Status: Offline Sonork: 100.1590021 Thanks Meter: 150 | just an awesome update as always will that support unlock for nokia android based phone ?? and remove pattern without loss data ??? |
The Following 2 Users Say Thank You to The_Killer For This Useful Post: |
04-07-2014, 08:13 | #7 (permalink) |
No Life Poster Join Date: May 2006 Location: West Jerusalem
Member: 280342 Status: Offline Thanks Meter: 73 | Please supporter Activate ATF JTAG Activation. Transaction ID for this payment is sn 851332d3a 851332D3D88220F7B571F9A7 |
The Following User Says Thank You to shadigsm For This Useful Post: |
04-07-2014, 08:27 | #10 (permalink) |
No Life Poster Join Date: May 2012 Location: Firmwares
Member: 1761687 Status: Offline Sonork: 100.1669047 Thanks Meter: 494 | Where we can get USB drivers for New Nokia Android models? 10x |
The Following User Says Thank You to Mr.Firmware For This Useful Post: |
04-07-2014, 08:27 | #11 (permalink) |
04-07-2014, 08:30 | #13 (permalink) |
Member: 280342 Status: Offline Thanks Meter: 73 | JTAG Module: NOT ACTIVATED JTAG Module Activation Cost: 39 Credits ERROR: You DO NOT HAVE enough Credits! Purchase JTAG Credits at ATF Store |
04-07-2014, 08:35 | #14 (permalink) | |
Freak Poster Join Date: Jul 2009 Age: 34
Member: 1078009 Status: Offline Thanks Meter: 12 | Quote:
AWESOME!!!!! | |
The Following 5 Users Say Thank You to lordmaxey For This Useful Post: |
04-07-2014, 08:38 | #15 (permalink) |
Member: 651945 Status: Offline Thanks Meter: 20,117 | @fawad85 Open C:\AdvanceBox Turbo Flasher\AdvanceBox.ini Add in last line in bottom [ANDROID] PhoneSelectedIndex=0 B.R. P.S. If you updated only via AUTO UPDATE SERVER, you will need to download the ROOT and GOOGLE Files here: ATF_ANDROID_ROOT_AND_GOOGLE_Installer - Download - 4shared - Linus Hernandez or here Download links for ATF_Android_ROOT_and_GOOGLE_Installer.rar - Mirrorcreator - Upload files to multiple hosts If you do not install this, then you cannot ROOT or Install Google Services. |
The Following 12 Users Say Thank You to Advance-Box For This Useful Post: |
