ATF Nokia X2-02 RM-694 USB Flashing Problem - [SOLVED] ATF Nokia X2-02 RM-694 USB Flashing Problem :confused: i Click On Flash Button And This Massage Here is the Screenshot: http://img836.imageshack.us/img836/4181/184858.jpg http://img805.imageshack.us/img805/7108/184807.jpg Any Sloution ATF-TEAM :confused: http://forum.gsmhosting.com/vbb/f609...world-1413729/ |
1 Attachment(s) Hi, Download attached Nokia.ini file and this phone will be in Infineon tab afterwards. Do flash via USB cable like we do C1-01, C2-00 etc. Extract ini here: x:\AdvanceBox Turbo Flasher\Nokia BR |
My Problem Problem Solve :) - Very Fast Support ;) Thank You ATF-TEAM ;) Here is the Screenshot: http://img513.imageshack.us/img513/9100/204011.jpg [B]Here are the Logs: Code: Number of Image Files: 3 http://img442.imageshack.us/img442/5489/204057.jpg http://img515.imageshack.us/img515/5710/204101.jpg ATF Nokia X2-02 RM-694 USB Flashing Done |
x2-02 fleshing problem Number of Image Files: 3 Processing Image File : rm694__11.84.mcusw Processing Image File : rm694__11.84.ppm_m_a Processing Image File : rm694__11.84.image_m_a_059D1B3_059P1X1_298_01 AUTO SELECTED DEAD USB FLASHING... If Phone Booting does not Start in 5 Seconds, Then Perform Steps 1, 2, 3 and 4... 1. Remove USB and Battery... 2. Insert USB. 3. Insert Battery. (Some phones boot automatically) 4. Please Power on phone shortly... Infineon USB Boot: F00A1FB300020303010100FF Sending PBL... PBL Successfully Sent... Sending SBL... SBL Successfully Sent... Setting Transmission Speed Done... Flash Chip Manufacturer: Samsung Electronics Corp. Flash Boot Successful... Unique Data: 12200C0E9016281B Original Product Code: 059N3X8 Reading : CCC... OK! Reading : HWC... OK! Reading : NPC... OK! RPL Backup was Successful... Plain RPL saved to: C:\AdvanceBox Turbo Flasher\Nokia\Backup\355497051107505\3554970511075 05_121537.rpl Data Sections : 04 Current File : rm694__11.84.mcusw Compile Name: rm694__11.84.mcusw_ebl_psi.fls Image Type : Main Firmware Data Size : 27528584 Bytes Sending Certificate Block FIRMWARE Certificate Block Sent Successfully... Processing Section 01 FIRMWARE Erase Block: 0x40000000~0x4001FFFE Start Erasing... Erasing Please Wait... Block Erase Done... Preparing Data Blocks... Data Size: 131072 bytes Data Checksum: CCF5 Uploading Data Blocks to phone... Block Write Successful... FIRMWARE Data Blocks uploaded to phone... Processing Section 02 FIRMWARE Erase Block: 0x40040000~0x4005FFFE Start Erasing... Erasing Please Wait... Block Erase Done... Preparing Data Blocks... Data Size: 131072 bytes Data Checksum: 7ACE Uploading Data Blocks to phone... Block Write Successful... FIRMWARE Data Blocks uploaded to phone... Processing Section 03 FIRMWARE Erase Block: 0x40060000~0x4015FFFE Start Erasing... Erasing Please Wait... Block Erase Done... Preparing Data Blocks... Data Size: 1048576 bytes Data Checksum: D645 Uploading Data Blocks to phone... Block Write Successful... FIRMWARE Data Blocks uploaded to phone... Processing Section 04 FIRMWARE Erase Block: 0x40280000~0x41BFFFFE Start Erasing... Erasing Please Wait... Block Erase Done... Preparing Data Blocks... Data Size: 26214400 bytes Data Checksum: 75C8 Uploading Data Blocks to phone... Block Write Successful... FIRMWARE Data Blocks uploaded to phone... Processing Section 05 FIRMWARE Erase Block: 0x43E20000~0x43E5FFFE Start Erasing... Erasing Please Wait... Block Erase Done... Data Verification Successful... Data Sections : 01 Current File : rm694__11.84.ppm_m_a Compile Name: package_m_a.ppm_ebl_psi.fls Image Type : PPM Image Data Size : 4460624 Bytes Sending Certificate Block PPM Certificate Block Sent Successfully... Processing Section 01 PPM Erase Block: 0x41C00000~0x422FFFFE Start Erasing... Erasing Please Wait... Block Erase Done... Preparing Data Blocks... Data Size: 4457280 bytes Data Checksum: FC40 Uploading Data Blocks to phone... Block Write Successful... PPM Data Blocks uploaded to phone... Data Verification Successful... Data Sections : 01 Current File : rm694__11.84.image_m_a_059D1B3_059P1X1_298_01 Compile Name: rm694__11.84.image_m_a_059D1B3_059P1X1_298_01.fls Image Type : CONTENT Package Data Size : 14814480 Bytes Sending Certificate Block CONTENT Certificate Block Sent Successfully... Processing Section 01 CONTENT Erase Block: 0x42300000~0x43E1FFFE Start Erasing... Erasing Please Wait... Block Erase Done... Preparing Data Blocks... Data Size: 14811136 bytes Data Checksum: 305F Uploading Data Blocks to phone... Block Write Successful... CONTENT Data Blocks uploaded to phone... Processing Section 02 CONTENT Erase Block: 0x43E60000~0x43F3FFFE Start Erasing... Erasing Please Wait... Block Erase Done... Data Verification Successful... Total Flashing Time (Erase + Flashing) : 00:02:49 (Booting time is NOT Included) Waiting for Phone to Start-Up..(Max 150 seconds) |
x2-02 fleshing problem Number of Image Files: 3 Processing Image File : rm694__11.84.mcusw Processing Image File : rm694__11.84.ppm_m_a Processing Image File : rm694__11.84.image_m_a_059D1B3_059P1X1_298_01 AUTO SELECTED DEAD USB FLASHING... If Phone Booting does not Start in 5 Seconds, Then Perform Steps 1, 2, 3 and 4... 1. Remove USB and Battery... 2. Insert USB. 3. Insert Battery. (Some phones boot automatically) 4. Please Power on phone shortly... Infineon USB Boot: F00A1FB300020303010100FF Sending PBL... PBL Successfully Sent... Sending SBL... SBL Successfully Sent... Setting Transmission Speed Done... Flash Chip Manufacturer: Samsung Electronics Corp. Flash Boot Successful... Unique Data: 12200C0E9016281B Original Product Code: 059N3X8 Reading : CCC... OK! Reading : HWC... OK! Reading : NPC... OK! RPL Backup was Successful... Plain RPL saved to: C:\AdvanceBox Turbo Flasher\Nokia\Backup\355497051107505\3554970511075 05_121537.rpl Data Sections : 04 Current File : rm694__11.84.mcusw Compile Name: rm694__11.84.mcusw_ebl_psi.fls Image Type : Main Firmware Data Size : 27528584 Bytes Sending Certificate Block FIRMWARE Certificate Block Sent Successfully... Processing Section 01 FIRMWARE Erase Block: 0x40000000~0x4001FFFE Start Erasing... Erasing Please Wait... Block Erase Done... Preparing Data Blocks... Data Size: 131072 bytes Data Checksum: CCF5 Uploading Data Blocks to phone... Block Write Successful... FIRMWARE Data Blocks uploaded to phone... Processing Section 02 FIRMWARE Erase Block: 0x40040000~0x4005FFFE Start Erasing... Erasing Please Wait... Block Erase Done... Preparing Data Blocks... Data Size: 131072 bytes Data Checksum: 7ACE Uploading Data Blocks to phone... Block Write Successful... FIRMWARE Data Blocks uploaded to phone... Processing Section 03 FIRMWARE Erase Block: 0x40060000~0x4015FFFE Start Erasing... Erasing Please Wait... Block Erase Done... Preparing Data Blocks... Data Size: 1048576 bytes Data Checksum: D645 Uploading Data Blocks to phone... Block Write Successful... FIRMWARE Data Blocks uploaded to phone... Processing Section 04 FIRMWARE Erase Block: 0x40280000~0x41BFFFFE Start Erasing... Erasing Please Wait... Block Erase Done... Preparing Data Blocks... Data Size: 26214400 bytes Data Checksum: 75C8 Uploading Data Blocks to phone... Block Write Successful... FIRMWARE Data Blocks uploaded to phone... Processing Section 05 FIRMWARE Erase Block: 0x43E20000~0x43E5FFFE Start Erasing... Erasing Please Wait... Block Erase Done... Data Verification Successful... Data Sections : 01 Current File : rm694__11.84.ppm_m_a Compile Name: package_m_a.ppm_ebl_psi.fls Image Type : PPM Image Data Size : 4460624 Bytes Sending Certificate Block PPM Certificate Block Sent Successfully... Processing Section 01 PPM Erase Block: 0x41C00000~0x422FFFFE Start Erasing... Erasing Please Wait... Block Erase Done... Preparing Data Blocks... Data Size: 4457280 bytes Data Checksum: FC40 Uploading Data Blocks to phone... Block Write Successful... PPM Data Blocks uploaded to phone... Data Verification Successful... Data Sections : 01 Current File : rm694__11.84.image_m_a_059D1B3_059P1X1_298_01 Compile Name: rm694__11.84.image_m_a_059D1B3_059P1X1_298_01.fls Image Type : CONTENT Package Data Size : 14814480 Bytes Sending Certificate Block CONTENT Certificate Block Sent Successfully... Processing Section 01 CONTENT Erase Block: 0x42300000~0x43E1FFFE Start Erasing... Erasing Please Wait... Block Erase Done... Preparing Data Blocks... Data Size: 14811136 bytes Data Checksum: 305F Uploading Data Blocks to phone... Block Write Successful... CONTENT Data Blocks uploaded to phone... Processing Section 02 CONTENT Erase Block: 0x43E60000~0x43F3FFFE Start Erasing... Erasing Please Wait... Block Erase Done... Data Verification Successful... Total Flashing Time (Erase + Flashing) : 00:02:49 (Booting time is NOT Included) Waiting for Phone to Start-Up..(Max 150 seconds) Report Post |
@vivekphl Flashing looks fine, what's the problem then ??? |
ui setting not ok brother |
how to flash nokia mobile with phonix software . |
Number of Image Files: 1 Processing Image File : rm607__06.15.image_f_0595551 AUTO SELECTED DEAD USB FLASHING... If Phone Booting does not Start in 5 Seconds, Then Perform Steps 1, 2, 3 and 4... 1. Remove USB and Battery... 2. Insert USB. 3. Insert Battery. (Some phones boot automatically) 4. Please Power on phone shortly... Infineon USB Boot: F00A1FB300020303010100FF Sending PBL... PBL Successfully Sent... Sending SBL... SBL Successfully Sent... ERROR: ReqSetProtConf FAILED any solution plz |
Card found: S/N : 1C35BC00 , v0130 Registered to: gsm Connect phone on selected interface... Core : v2.13 , BB5XG FlashEngine : v9.9 Selected FlashSettings : Manual Check FlashFiles, Please, wait... Files Set for Flashing : MCU : rm694__12.04.mcusw PPM : rm694__12.04.ppm_mh CNT : rm694__12.04.image_mh_059F290_059N4H2_292_02 Flashing phone now... [Gen] Rules accepted for : XGOLD Generation Check files done... -> SWversion check skipped : Dead mode selected Dead Mode is Selected Waiting for USB device... -> If Windows say "Unrecognized device" / Operation not start -> Or if Phone start charge - just reinsert battery -> If flashing freeze - reinsert cable/battery and try again --- Press phone's power button or insert usb cable! --- -> Phone not found.. :( Elapsed: 00:00:36 Connect phone on selected interface... Core : v2.13 , BB5XG FlashEngine : v9.9 Selected FlashSettings : Manual Check FlashFiles, Please, wait... Files Set for Flashing : MCU : rm694__12.04.mcusw PPM : rm694__12.04.ppm_mh CNT : rm694__12.04.image_mh_059F290_059N4H2_292_02 Flashing phone now... [Gen] Rules accepted for : XGOLD Generation Check files done... -> SWversion check skipped : Dead mode selected Dead Mode is Selected Waiting for USB device... -> If Windows say "Unrecognized device" / Operation not start -> Or if Phone start charge - just reinsert battery -> If flashing freeze - reinsert cable/battery and try again --- Press phone's power button or insert usb cable! --- Connection opened successfully IF Boot Init : 0xF0 IF Resp Len : 0x0A IF xCPUID : XGOLD 213 [XMM2130 QUANTUM] IF Resp Data : 1FB300020303010100FF Sending EBL Loader ... EBL Loader Ok, 01 EBL Loader ready, AA Sending EBL ... EBL sent Ok EBL : Quantum_Bootloader_10.46_M1S1 Speed accepted, use 6.500.000 FLASHID : 89008289 FLIC conf set, RST set Boot done! Check keys... Check done. Image can be flashed Backup enabled, will read all certificates Reading CCC Reading HWC Reading NPC IMEI 1 : 352868055112563 IMEI 2 : 352868055112571 PCcode : 059F295 NPC Certificate saved... CCC Certificate saved... HWC Certificate saved... RPL saved : C:\InfinityBox\BEST\Backup\Cert\352868055112563_XG 213_CRT.rpl Settings : EDM [0x8] , Block Mode , Fast CRC , Verify ===Flashing [MCU]=== File : rm694__12.04.mcusw Image : rm694__12.04.mcusw_ebl_psi.fls Sec-pack found, sending ... Sec-pack sent Found 5 region(s) Processing Region 1/5 Erase , Start : 0x40000000 , Len : 0x00020000 Erasing, wait ... Erase done, time : 00:00:00 Write , Start : 0x40000000 , Len : 0x00020000 Flashing , wait ... Region flash done, time : 00:00:00 Processing Region 2/5 Erase , Start : 0x40040000 , Len : 0x00020000 Erasing, wait ... Erase done, time : 00:00:00 Write , Start : 0x40040000 , Len : 0x00020000 Flashing , wait ... Region flash done, time : 00:00:00 Processing Region 3/5 Erase , Start : 0x40060000 , Len : 0x00100000 Erasing, wait ... Erase done, time : 00:00:06 Write , Start : 0x40060000 , Len : 0x00100000 Flashing , wait ... Region flash done, time : 00:00:01 Processing Region 4/5 Erase , Start : 0x40280000 , Len : 0x01980000 Erasing, wait ... Erase done, time : 00:02:00 Write , Start : 0x40280000 , Len : 0x01900000 Flashing , wait ... Region flash done, time : 00:00:31 Processing Region 5/5 Erase , Start : 0x43E20000 , Len : 0x00040000 [ERR_hReqFlashEraseStart] : 8401410040000000 Error... -> Check cable, flashfile, try again from this file Connect phone on selected interface... Elapsed: 00:02:58 Connect phone on selected interface... Core : v2.13 , BB5XG FlashEngine : v9.9 Selected FlashSettings : Manual Check FlashFiles, Please, wait... Files Set for Flashing : MCU : rm694__12.04.mcusw PPM : rm694__12.04.ppm_mh CNT : rm694__12.04.image_mh_059F290_059N4H2_292_02 Flashing phone now... [Gen] Rules accepted for : XGOLD Generation Check files done... -> SWversion check skipped : Dead mode selected Dead Mode is Selected Waiting for USB device... -> If Windows say "Unrecognized device" / Operation not start -> Or if Phone start charge - just reinsert battery -> If flashing freeze - reinsert cable/battery and try again --- Press phone's power button or insert usb cable! --- Connection opened successfully IF Boot Init : 0xF0 IF Resp Len : 0x0A IF xCPUID : XGOLD 213 [XMM2130 QUANTUM] IF Resp Data : 1FB300020303010100FF Sending EBL Loader ... EBL Loader Ok, 01 EBL Loader ready, AA Sending EBL ... EBL sent Ok EBL : Quantum_Bootloader_10.46_M1S1 Speed accepted, use 6.500.000 FLASHID : 89008289 FLIC conf set, RST set Boot done! Check keys... Check done. Image can be flashed Backup enabled, will read all certificates Reading CCC Reading HWC Reading NPC IMEI 1 : 352868055112563 IMEI 2 : 352868055112571 PCcode : 059F295 NPC Certificate saved... CCC Certificate saved... HWC Certificate saved... RPL saved : C:\InfinityBox\BEST\Backup\Cert\352868055112563_2n d_XG213_CRT.rpl Settings : EDM [0x8] , Block Mode , Fast CRC , Verify ===Flashing [MCU]=== File : rm694__12.04.mcusw Image : rm694__12.04.mcusw_ebl_psi.fls Sec-pack found, sending ... Sec-pack sent Found 5 region(s) Processing Region 1/5 Erase , Start : 0x40000000 , Len : 0x00020000 Erasing, wait ... Erase done, time : 00:00:00 Write , Start : 0x40000000 , Len : 0x00020000 Flashing , wait ... Region flash done, time : 00:00:00 Processing Region 2/5 Erase , Start : 0x40040000 , Len : 0x00020000 Erasing, wait ... Erase done, time : 00:00:00 Write , Start : 0x40040000 , Len : 0x00020000 Flashing , wait ... Region flash done, time : 00:00:00 Processing Region 3/5 Erase , Start : 0x40060000 , Len : 0x00100000 Erasing, wait ... Erase done, time : 00:00:07 Write , Start : 0x40060000 , Len : 0x00100000 Flashing , wait ... Region flash done, time : 00:00:01 Processing Region 4/5 Erase , Start : 0x40280000 , Len : 0x01980000 Erasing, wait ... Erase done, time : 00:02:04 Write , Start : 0x40280000 , Len : 0x01900000 Flashing , wait ... Region flash done, time : 00:00:31 Processing Region 5/5 Erase , Start : 0x43E20000 , Len : 0x00040000 [ERR_hReqFlashEraseStart] : 8401410040000000 Error... -> Check cable, flashfile, try again from this file Connect phone on selected interface... Elapsed: 00:02:58 Connect phone on selected interface... Core : v2.13 , BB5XG FlashEngine : v9.9 Selected FlashSettings : Manual Check FlashFiles, Please, wait... Files Set for Flashing : MCU : rm694__12.04.mcusw PPM : rm694__12.04.ppm_mh CNT : rm694__12.04.image_mh_059F290_059N4H2_292_02 Flashing phone now... [Gen] Rules accepted for : XGOLD Generation Check files done... -> SWversion check skipped : Dead mode selected Dead Mode is Selected Waiting for USB device... -> If Windows say "Unrecognized device" / Operation not start -> Or if Phone start charge - just reinsert battery -> If flashing freeze - reinsert cable/battery and try again --- Press phone's power button or insert usb cable! --- Connection opened successfully IF Boot Init : 0xF0 IF Resp Len : 0x0A IF xCPUID : XGOLD 213 [XMM2130 QUANTUM] IF Resp Data : 1FB300020303010100FF Sending EBL Loader ... EBL Loader Ok, 01 EBL Loader ready, AA Sending EBL ... EBL sent Ok EBL : Quantum_Bootloader_10.46_M1S1 Speed accepted, use 6.500.000 FLASHID : 89008289 FLIC conf set, RST set Boot done! Check keys... Check done. Image can be flashed Backup enabled, will read all certificates Reading CCC Reading HWC Reading NPC IMEI 1 : 352868055112563 IMEI 2 : 352868055112571 PCcode : 059F295 NPC Certificate saved... CCC Certificate saved... HWC Certificate saved... RPL saved : C:\InfinityBox\BEST\Backup\Cert\352868055112563_2n d_XG213_CRT.rpl Settings : EDM [0x8] , Block Mode , Fast CRC , Verify ===Flashing [MCU]=== File : rm694__12.04.mcusw Image : rm694__12.04.mcusw_ebl_psi.fls Sec-pack found, sending ... Sec-pack sent Found 5 region(s) Processing Region 1/5 Erase , Start : 0x40000000 , Len : 0x00020000 Erasing, wait ... Erase done, time : 00:00:01 Write , Start : 0x40000000 , Len : 0x00020000 Flashing , wait ... Region flash done, time : 00:00:00 Processing Region 2/5 Erase , Start : 0x40040000 , Len : 0x00020000 Erasing, wait ... Erase done, time : 00:00:00 Write , Start : 0x40040000 , Len : 0x00020000 Flashing , wait ... Region flash done, time : 00:00:00 Processing Region 3/5 Erase , Start : 0x40060000 , Len : 0x00100000 Erasing, wait ... Erase done, time : 00:00:06 Write , Start : 0x40060000 , Len : 0x00100000 Flashing , wait ... Region flash done, time : 00:00:01 Processing Region 4/5 Erase , Start : 0x40280000 , Len : 0x01980000 Erasing, wait ... Erase done, time : 00:02:01 Write , Start : 0x40280000 , Len : 0x01900000 Flashing , wait ... Region flash done, time : 00:00:31 Processing Region 5/5 Erase , Start : 0x43E20000 , Len : 0x00040000 [ERR_hReqFlashEraseStart] : 8401410040000000 Error... -> Check cable, flashfile, try again from this file Connect phone on selected interface... Elapsed: 00:03:12 Connect phone on selected interface... |
thanks for programmmmmmmm ;))) |
