Go Back   GSM-Forum > Product Support Sections > Hard/Software Products (official support) > Advance-Box
Old 02-27-2012, 15:11   #1 (permalink)
Member: 817970
Thanks Meter: 61
ATF Nokia X2-02 RM-694 USB Flashing Problem - [SOLVED]
i Click On Flash Button And This Massage
Here is the Screenshot:
Any Sloution ATF-TEAM
ATF Nokia X2-02 RM-694 USB Flashing (First In The World)
Old 02-27-2012, 15:22   #2 (permalink)
..::Angel::..'s Avatar
Member: 643472
Sonork: 100.96901
Thanks Meter: 16,487
Hi,
Download attached Nokia.ini file and this phone will be in
Infineon tab afterwards. Do flash via USB cable like we do
C1-01, C2-00 etc.
Extract ini here: x:\AdvanceBox Turbo Flasher\Nokia
The Following 2 Users Say Thank You to ..::Angel::.. For This Useful Post:
Old 02-27-2012, 16:04   #3 (permalink)
Member: 817970
Thanks Meter: 61
My Problem Problem Solve - Very Fast Support
Thank You ATF-TEAM
[B]Here are the Logs:
Number of Image Files: 3
Processing Image File :
 rm694__10.89.mcusw
 rm694__10.89.ppm_m_a
 rm694__10.89.image_m_a_059D1B3
AUTO SELECTED DEAD USB FLASHING...
 If Flashing DOES NOT Start in 5 Seconds,
 Then Perform Steps 1, 2, 3 and 4...
1. Remove USB and Battery...
2. Insert USB.
3. Insert Battery. (Some phones boot automatically)
4. Please Power on phone shortly...
Infineon USB Boot: F00A1FB300020303010100FF
Sending PBL...
PBL Successfully Sent...
Sending SBL...
SBL Successfully Sent...
Setting Transmission Speed Done...
Flash Chip Manufacturer: Samsung Electronics Corp.
Flash Boot Successful...
Sections         : 04
Current File    : rm694__10.89.mcusw
Compile Name: rm694__10.89.mcusw_ebl_psi.fls
Image Type   : Main Firmware
Data Size       : 27528584 Bytes
Sending Certificate Block
FIRMWARE Certificate Block Sent Successfully...
 Processing Section 01 of 04
FIRMWARE Erase Block: 0x40000000~0x4001FFFE
Start Erasing...
Erasing Please Wait...
Block Erase Done...
Preparing Data Blocks...
Data Size: 131072 bytes
Data Checksum: CCF5
Uploading Data Blocks to phone...
Block Write Successful...
FIRMWARE Data Blocks uploaded to phone...
 Processing Section 02 of 04
FIRMWARE Erase Block: 0x40040000~0x4005FFFE
Start Erasing...
Block Erase Done...
Data Checksum: 7ACE
 Processing Section 03 of 04
FIRMWARE Erase Block: 0x40060000~0x4015FFFE
Start Erasing...
Block Erase Done...
Data Size: 1048576 bytes
Data Checksum: BB99
 Processing Section 04 of 04
FIRMWARE Erase Block: 0x40280000~0x41BFFFFE
Start Erasing...
Block Erase Done...
Data Size: 26214400 bytes
Data Checksum: 709E
Data Verification Successful...
Sections         : 01
Current File    : rm694__10.89.ppm_m_a
Compile Name: package_m_a.ppm_ebl_psi.fls
Image Type   : PPM Image
Data Size       : 4462372 Bytes
PPM Certificate Block Sent Successfully...
 Processing Section 01 of 01
PPM Erase Block: 0x41C00000~0x422FFFFE
Start Erasing...
Block Erase Done...
Data Size: 4459028 bytes
Data Checksum: FF1E
PPM Data Blocks uploaded to phone...
Sections         : 01
Current File    : rm694__10.89.image_m_a_059D1B3
Compile Name: package_m_a_059D1B3.image.fls
Image Type   : CONTENT Package
Data Size       : 14421264 Bytes
CONTENT Certificate Block Sent Successfully...
CONTENT Erase Block: 0x42300000~0x43E1FFFE
Start Erasing...
Block Erase Done...
Data Size: 14417920 bytes
Data Checksum: 7CB8
CONTENT Data Blocks uploaded to phone...
Total Flashing Time (Erase + Flashing) : 00:03:22
(Booting time is NOT Included)
Waiting for Phone to Start-Up..(Max 150 seconds)
Elapsed Time: 5 Seconds...
Elapsed Time: 10 Seconds...
Elapsed Time: 15 Seconds...
Elapsed Time: 20 Seconds...
Elapsed Time: 25 Seconds...
Elapsed Time: 30 Seconds...
Elapsed Time: 35 Seconds...
Elapsed Time: 40 Seconds...
Elapsed Time: 45 Seconds...
Elapsed Time: 50 Seconds...
Elapsed Time: 55 Seconds...
Operation Cancelled...
Scanning USB Ports...
             Basic Phone Information
MCU Version: V 10.89 22-11-11 RM-694 (c) Nokia
IMEI Plain : 357879040462000
IMEI Spare : A357879040462000
IMEI SV    : 33578790404620002F
Phone Model: K        X2-02
Category   : Entry
Phone Type : RM-694
            Extended Phone Information
Product Serial Number: 6D867A3AH
Product Code         : 059D1B3
Module Code          : 0204922
Basic Production Code: 059C943
Long Production SN   : 0
PPM SW Version       : V 10.89 22-11-11 RM-694 (c) Nokia             M_A
BT MCM Version       : 19e2-47026
MCU SW Version       : V 10.89 22-11-11 RM-694 (c) Nokia
HW Version           : 1000
RFIC Version         : Dummy RFIC version
LCD Version          : AUO
FWID Version         : kV 10.89 22-11-11 RM-694 (c) Nokia            V 10.89 22-11-11 RM-694 (c) Nokia             M_A 059D1B3 001
Content Pack Version : Content: m_a_059D1B3 V 10.89 22-11-11 RM-694 (c) Nokia
Bluetooth ID         : B0:5C:E5:F5:C8:B8
CS Type              : GSM900, GSM1800
  ********** SIMLOCK INFO  **********
CONFIG_DATA  : 0010100000000000
PROFILE_BITS : 800000000003000B
ASIC         : 11
PROVIDER     : Default Test Operator
   Block [1]  1:Open 2:Open 3:Open 4:Open 5:Open
   Block [2]  1:Open 2:Open 3:Open 4:Open 5:Open
   Block [3]  1:Open 2:Open 3:Open 4:Open 5:Open
   Block [4]  1:Open 2:Open 3:Open 4:Open 5:Open
   Block [5]  1:Open 2:Open 3:Open 4:Open 5:Open
   Block [6]  1:Open 2:Open 3:Open 4:Open 5:Open
   Block [7]  1:Open 2:Open 3:Open 4:Open 5:Open
SIMLOCK_TYPE             : PA_SL3 (15-digit NCK)
SIMLOCK_TEST             : PASSED
SECURITY_TEST           : PASSED
SECURITY_CODE          : 63699
PHONE_MODE              : TEST
          Dynamic Camera Configuration
DCC ID  : 094B2F01
DCC Ver: 009021
Status   : OK
FACTORY SET TO : Full Factory Set
 OK
FACTORY SET TO : User Data
 OK
FACTORY SET TO : Leave Factory
 OK
FACTORY SET TO : Service Center
 OK
FACTORY SET TO : Software Upgrade
 OK
FACTORY SET TO : Production Tune
 OK
RESET LIFE TIMER TO : 0000:00
 OK
ATF Nokia X2-02 RM-694 USB Flashing Done
Old 04-15-2013, 19:57   #4 (permalink)
Member: 712150
Thanks Meter: 25
x2-02 fleshing problem
rm694__11.84.mcusw
rm694__11.84.ppm_m_a
rm694__11.84.image_m_a_059D1B3_059P1X1_298_01
If Phone Booting does not Start in 5 Seconds,
2. Insert USB.
Sending PBL...
Sending SBL...
Unique Data: 12200C0E9016281B
Original Product Code: 059N3X8
Reading : CCC... OK!
Reading : HWC... OK!
Reading : NPC... OK!
RPL Backup was Successful...
Plain RPL saved to:
C:\AdvanceBox Turbo Flasher\Nokia\Backup\355497051107505\3554970511075 05_121537.rpl
Data Sections : 04
Current File : rm694__11.84.mcusw
Compile Name: rm694__11.84.mcusw_ebl_psi.fls
Start Erasing...
Block Erase Done...
Data Checksum: CCF5
Start Erasing...
Block Erase Done...
Data Checksum: 7ACE
Start Erasing...
Block Erase Done...
Data Checksum: D645
Start Erasing...
Block Erase Done...
Data Checksum: 75C8
Processing Section 05
FIRMWARE Erase Block: 0x43E20000~0x43E5FFFE
Start Erasing...
Block Erase Done...
Data Sections : 01
Current File : rm694__11.84.ppm_m_a
Data Size : 4460624 Bytes
Start Erasing...
Block Erase Done...
Data Size: 4457280 bytes
Data Checksum: FC40
Data Sections : 01
Current File : rm694__11.84.image_m_a_059D1B3_059P1X1_298_01
Compile Name: rm694__11.84.image_m_a_059D1B3_059P1X1_298_01.fls
Data Size : 14814480 Bytes
Start Erasing...
Block Erase Done...
Data Size: 14811136 bytes
Data Checksum: 305F
CONTENT Erase Block: 0x43E60000~0x43F3FFFE
Start Erasing...
Block Erase Done...
Total Flashing Time (Erase + Flashing) : 00:02:49
Old 04-16-2013, 05:20   #5 (permalink)
Member: 712150
Thanks Meter: 25
rm694__11.84.mcusw
2. Insert USB.
Sending PBL...
Sending SBL...
Plain RPL saved to:
Data Sections : 04
Start Erasing...
Block Erase Done...
Data Checksum: CCF5
Start Erasing...
Block Erase Done...
Data Checksum: 7ACE
Start Erasing...
Block Erase Done...
Data Checksum: D645
Start Erasing...
Block Erase Done...
Data Checksum: 75C8
Start Erasing...
Block Erase Done...
Data Sections : 01
Start Erasing...
Block Erase Done...
Data Checksum: FC40
Data Sections : 01
Start Erasing...
Block Erase Done...
Data Checksum: 305F
Start Erasing...
Block Erase Done...
Report Post
Old 04-16-2013, 10:22   #6 (permalink)
Member: 643472
Sonork: 100.96901
@vivekphl
Flashing looks fine, what's the problem then ???
Old 04-16-2013, 17:30   #7 (permalink)
fahad ali khan's Avatar
Member: 1771086
Thanks Meter: 2,403
rm694__11.84.mcusw
2. Insert USB.
Sending PBL...
Sending SBL...
Plain RPL saved to:
Data Sections : 04
Start Erasing...
Block Erase Done...
Data Checksum: CCF5
Start Erasing...
Block Erase Done...
Data Checksum: 7ACE
Start Erasing...
Block Erase Done...
Data Checksum: D645
Start Erasing...
Block Erase Done...
Data Checksum: 75C8
Start Erasing...
Block Erase Done...
Data Sections : 01
Start Erasing...
Block Erase Done...
Data Checksum: FC40
Data Sections : 01
Start Erasing...
Block Erase Done...
Data Checksum: 305F
Start Erasing...
Block Erase Done...
Report Post
ui setting not ok brother
Old 05-30-2014, 08:42   #8 (permalink)
Member: 2195774
how to flash nokia mobile with phonix software .
Old 07-02-2015, 11:19   #9 (permalink)
Member: 1400174
Sonork: benard
Thanks Meter: 2
Number of Image Files: 1
rm607__06.15.image_f_0595551
2. Insert USB.
Sending PBL...
Sending SBL...
ERROR: ReqSetProtConf FAILED
any solution plz
Old 03-14-2016, 19:41   #10 (permalink)
Member: 2189830
Sonork: 100.1678166
Thanks Meter: 5
Card found: S/N : 1C35BC00 , v0130
Registered to: gsm
Connect phone on selected interface...
Core : v2.13 , BB5XG FlashEngine : v9.9
Selected FlashSettings : Manual
Check FlashFiles, Please, wait...
Files Set for Flashing :
MCU : rm694__12.04.mcusw
PPM : rm694__12.04.ppm_mh
CNT : rm694__12.04.image_mh_059F290_059N4H2_292_02
Flashing phone now...
[Gen] Rules accepted for : XGOLD Generation
Check files done...
-> SWversion check skipped : Dead mode selected
Dead Mode is Selected
Waiting for USB device...
-> If Windows say "Unrecognized device" / Operation not start
-> Or if Phone start charge - just reinsert battery
-> If flashing freeze - reinsert cable/battery and try again
--- Press phone's power button or insert usb cable! ---
-> Phone not found..
Elapsed: 00:00:36
Check files done...
Connection opened successfully
IF Boot Init : 0xF0
IF Resp Len : 0x0A
IF xCPUID : XGOLD 213 [XMM2130 QUANTUM]
IF Resp Data : 1FB300020303010100FF
Sending EBL Loader ...
EBL Loader Ok, 01
EBL Loader ready, AA
Sending EBL ...
EBL sent Ok
EBL : Quantum_Bootloader_10.46_M1S1
Speed accepted, use 6.500.000
FLASHID : 89008289
FLIC conf set, RST set
Boot done!
Check keys...
Check done. Image can be flashed
Backup enabled, will read all certificates
Reading CCC
Reading HWC
Reading NPC
IMEI 1 : 352868055112563
IMEI 2 : 352868055112571
PCcode : 059F295
NPC Certificate saved...
CCC Certificate saved...
HWC Certificate saved...
RPL saved : C:\InfinityBox\BEST\Backup\Cert\352868055112563_XG 213_CRT.rpl
Settings : EDM [0x8] , Block Mode , Fast CRC , Verify
===Flashing [MCU]===
File : rm694__12.04.mcusw
Image : rm694__12.04.mcusw_ebl_psi.fls
Sec-pack found, sending ...
Sec-pack sent
Found 5 region(s)
Processing Region 1/5
Erase , Start : 0x40000000 , Len : 0x00020000
Erasing, wait ...
Erase done, time : 00:00:00
Write , Start : 0x40000000 , Len : 0x00020000
Flashing , wait ...
Region flash done, time : 00:00:00
Processing Region 2/5
Erase , Start : 0x40040000 , Len : 0x00020000
Erasing, wait ...
Write , Start : 0x40040000 , Len : 0x00020000
Flashing , wait ...
Processing Region 3/5
Erase , Start : 0x40060000 , Len : 0x00100000
Erasing, wait ...
Erase done, time : 00:00:06
Write , Start : 0x40060000 , Len : 0x00100000
Flashing , wait ...
Region flash done, time : 00:00:01
Processing Region 4/5
Erase , Start : 0x40280000 , Len : 0x01980000
Erasing, wait ...
Erase done, time : 00:02:00
Write , Start : 0x40280000 , Len : 0x01900000
Flashing , wait ...
Region flash done, time : 00:00:31
Processing Region 5/5
Erase , Start : 0x43E20000 , Len : 0x00040000
[ERR_hReqFlashEraseStart] : 8401410040000000
Error...
-> Check cable, flashfile, try again from this file
Elapsed: 00:02:58
Check files done...
IF Boot Init : 0xF0
IF Resp Len : 0x0A
EBL Loader Ok, 01
Sending EBL ...
EBL sent Ok
FLASHID : 89008289
Boot done!
Check keys...
Reading CCC
Reading HWC
Reading NPC
PCcode : 059F295
RPL saved : C:\InfinityBox\BEST\Backup\Cert\352868055112563_2n d_XG213_CRT.rpl
Sec-pack sent
Found 5 region(s)
Erasing, wait ...
Flashing , wait ...
Erasing, wait ...
Flashing , wait ...
Erasing, wait ...
Erase done, time : 00:00:07
Flashing , wait ...
Erasing, wait ...
Erase done, time : 00:02:04
Flashing , wait ...
Error...
Elapsed: 00:02:58
Check files done...
IF Boot Init : 0xF0
IF Resp Len : 0x0A
EBL Loader Ok, 01
Sending EBL ...
EBL sent Ok
FLASHID : 89008289
Boot done!
Check keys...
Reading CCC
Reading HWC
Reading NPC
PCcode : 059F295
Sec-pack sent
Found 5 region(s)
Erasing, wait ...
Erase done, time : 00:00:01
Flashing , wait ...
Erasing, wait ...
Flashing , wait ...
Erasing, wait ...
Flashing , wait ...
Erasing, wait ...
Erase done, time : 00:02:01
Flashing , wait ...
Error...
Elapsed: 00:03:12
Old 07-06-2016, 15:49   #11 (permalink)
Member: 2595172
thanks for programmmmmmmm ))
New Nokia Software!!!!!!! Jefferson Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 52 12-30-2016 07:17
Need software upgrade for Nokia 5110 ptkrf Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 30 02-24-2016 09:21
Page generated in 0.54155 seconds with 9 queries
