01-24-2014, 04:50 | #1 (permalink) | |
Freak Poster Join Date: Feb 2005 Location: 289 Quang Trung, Ha Dong. Age: 44
Member: 113443 Status: Offline Thanks Meter: 27 | ATF not active, pls help me! Quote:
Thanks advance! | |
01-25-2014, 15:31 | #3 (permalink) |
Junior Member Join Date: Jan 2014
Member: 2114238 Status: Offline Sonork: ramco_tr Thanks Meter: 0 | hi i have to same problem ================================================ Advance Turbo Flasher Found ================================================ Driver Version : 00020824 Library Version : 00030207 Box Type : ATF Lightning Box Firmware : LogiCore 10.3.80 Software Version : v10.61 AdvanceBox SN : E91586F9CF47A953D26***** Box Status : NOT ACTIVATED |
01-25-2014, 15:46 | #4 (permalink) |
No Life Poster Join Date: Dec 2006 Location: Karachi, Pakistan Age: 33
Member: 643472 Status: Offline Sonork: 100.96901 Thanks Meter: 16,589 | Hi, you both should contact your reseller regarding this problem. They have requested us to block these boxes' serial numbers. However, the error message from ATF software itself is very clear... BR |
01-25-2014, 15:52 | #5 (permalink) |
Member: 2114238 Status: Offline Sonork: ramco_tr Thanks Meter: 0 | ATF box was more than 2 years to get I called the seller said I can not help in this regard been more than two years because What should I do about it sorry for my bad english I use to translate |
01-25-2014, 17:15 | #6 (permalink) |
Member: 643472 Status: Offline Sonork: 100.96901 Thanks Meter: 16,589 | Hi, we cannot help you in this regard, only your reseller you bought the box from can help you. BR |
The Following User Says Thank You to ..::Angel::.. For This Useful Post: |
