10-18-2012, 01:25 | #1 (permalink) |
No Life Poster Join Date: Jun 2009 Location: SouthAmericaUnlockers Age: 52
Member: 1057178 Status: Offline Sonork: Kfe~Labs Co.- Thanks Meter: 568 | ATF Not Found and Multiple ATF I not run Mprog, Today work Perfect with ATF, but Now say, Multiple ATF Found, and before (ATF Not Found) Where is the Problem!!! ^^^^^^^ ||||||| Multi-ATF =============================================== Multiple ATF Boxes Detected =============================================== Goto Multi-ATF Tab and Select the ATF Box Serial Number that you want to use for this ATF Software Window... ///////// /// /// /////// /////// ///////// /// /// /// /// // /// /// /// /// /// /// /// /////// /////// /// /// /// /// /// /// /// /// /// /// /// /// ///// /// /// /////// ////// ======================================= /// /// /// ///////// /////// ////// ///// /// /// /// /// // /// /// /// ///// /// /// /////// /// /// /// //// /// /// /// /// /// /// /// /// /// /// /// /// ////// ======================================= +++++++++++++++++++++++++++++++++++++++++++++++ I dont Know What happend With ATF Waiting a Solution Polaco |
10-18-2012, 02:01 | #2 (permalink) |
Member: 1057178 Status: Offline Sonork: Kfe~Labs Co.- Thanks Meter: 568 | Hi... Is a Error in Windows XP, I have 3 WinXp and all is Stoped in 9.12 Update. After Reinstal FTD Full Library, ATF Not Found, Repairing and cleaning DLL and Ftd, restart, 2 ATF Found!! I really Genius But The Most Important, go to my Windows 7 64 Bit, all is ok witn My Box, No EPT or repair eep or Mprog Soft. Not a Hardware Box Problem! Finally, Updating up to 9.12 in Windows 7, show error Exeption Bla Bla.... Is a Ftd Error. Not Touch Nothing with Mprog, Just Choice Good Prgramable Port and ATF Ftdi.... problem Solved. Drivers Problem atf ftdi.png - 4shared.com - photo sharing - download image - The_polack Free Download Server Here Full detail for Fix. Best Regards Polaco |
10-18-2012, 02:55 | #3 (permalink) |
Member: 1057178 Status: Offline Sonork: Kfe~Labs Co.- Thanks Meter: 568 | Solved Under Seven 64 But No in XP, Today is ok, then 2 atf found, then Not ATF Found, and Now, this error, and ATF Work but Not stable, How to solve This error.. On Windows 7 Is Ok, I need Work and my XpSP3 atf xp error ftd.JPG - 4shared.com - photo sharing - download image - The_polack Free Download Server i Know is a problem FTD Because today Work with Other tool with Old Ftd, now, cant Fix this drivers problem Waiting ideas... Polaco |
10-18-2012, 14:40 | #4 (permalink) |
Member: 1057178 Status: Offline Sonork: Kfe~Labs Co.- Thanks Meter: 568 | Solved under Windows 7 and XP. Drivers Problem http://forum.gsmhosting.com/vbb/f609...ected-1552865/ Thnks X-Shadow for Help in Real Time. Polaco |
10-18-2012, 16:28 | #5 (permalink) |
Member: 1057178 Status: Offline Sonork: Kfe~Labs Co.- Thanks Meter: 568 | Solved and Windows 7 and Windows XP Now.- Solution For Ftdi driver & Usb Flash Driver Fixed (inside picture) Windows XP atf error solved.JPG - 4shared.com - photo sharing - download image - The_polack Free Download Server Br Polaco |
