Unlock Server
Go Back   GSM-Forum > Product Support Sections > Hard/Software Products (official support) > Advance-Box
Old 11-05-2012, 04:49   #16 (permalink)
srinibas's Avatar
Member: 492222
Sonork: 100.1594126
Originally Posted by .::M Irfan::. View Post
i m using win 7 64 bit ultimate, driver install successfully software open succesfully also but when i click on check for update then nothing happen, also i have check (auto check update) and restart software but nothing happen, softwatre doesnot check for update auto!
br
Currently which version of ATF you are using ???
Br - srinibas
Old 11-05-2012, 04:51   #17 (permalink)
srinibas's Avatar
Member: 492222
Sonork: 100.1594126
thanks atf team now its working perfect, i have just disable antivirus and its work.
thats was my antivirus problem.
br
Thanks to know your problem solved . It is a basic tips that disable your AV during AUTO update / Important files .
Br - srinibas
Old 11-05-2012, 06:40   #18 (permalink)
.::RAM MOBILE::.'s Avatar
Member: 1681461
Sonork: 100.1637223
how to working windows 8 32-bit this Drivers
wbr ; tejaram
Old 11-05-2012, 07:12   #19 (permalink)
.::AZEEM::.'s Avatar
Member: 336212
Sonork: 100.1585000
Tested working good
Win8 32 bits
Win7 64 bits
The Following User Says Thank You to .::AZEEM::. For This Useful Post:
Old 11-05-2012, 07:50   #20 (permalink)
Member: 1087333
Atf always best box for nokia
Old 11-05-2012, 08:40   #21 (permalink)
srinibas's Avatar
Member: 492222
Sonork: 100.1594126
wbr ; tejaram
Cant understand your question ?
Br - srinibas
Old 11-05-2012, 09:56   #22 (permalink)
.::V!K@$H::.'s Avatar
Member: 1236722
Sonork: 100.1601546
gre8......................................
Old 11-05-2012, 12:47   #23 (permalink)
unlock.mk's Avatar
Member: 1671934
Sonork: 1612800
Post Good job ATF team
Hi, i just want to say that Multiple ATF box detected is FINNALY GONE !!! Thanks to the team of ATF. Great job with new drivers, so all my posts complaining was because of bugged ATF drivers. But that is history now.
I have just a couple of tiny errors, which i hope will be solved in next EXE.
Below are screenshots of those errors:
Old 11-05-2012, 13:56   #24 (permalink)
el-polaco's Avatar
Member: 1057178
Sonork: 100.1585354
WoW...Thnks ATF Team...
Windows 8 Proffessional support ;(
Are you Test OclHashCat under cmd in Windows 8?
Share iso image from OS!!..
best regard
polaco
Old 11-05-2012, 13:56   #25 (permalink)
Crazy Poster
Member: 1299198
very good very good team very good update
Old 11-06-2012, 14:42   #26 (permalink)
el-polaco's Avatar
Member: 1057178
Sonork: 100.1585354
best regard
polaco
Here another test under Windows 8 64bit.
Im Not have a HD In solid State like X-Shadow, But work fine
Now tested under win7*64 win8*64 winXPsp3*32
best regards
polaco
The Following User Says Thank You to el-polaco For This Useful Post:
Old 11-06-2012, 20:27   #27 (permalink)
Member: 1571557
Good update, good job, thanks keep up.
I like.
Old 11-07-2012, 12:12   #28 (permalink)
khandudecool01's Avatar
Member: 1566457
Sonork: 100.1602522
thanks atf team good update
Old 11-10-2012, 13:38   #29 (permalink)
Member: 407451
Need anything to run ATF under win 8 pro or only double click to the icon and work? Need to run as admin? Now in win 7 I run it as admin and win xp compatibility mode.
Old 11-23-2012, 02:55   #30 (permalink)
huyanten's Avatar
Member: 184637
I checked with windows 8 and ATF works fine
Page generated in 3.54548 seconds with 11 queries
