04-06-2011, 07:59 | #2 (permalink) |
No Life Poster Join Date: Dec 2007
Member: 651945 Status: Offline Thanks Meter: 20,118 | @VM_SODHA Bro, select "Infineon" from the Drop down list... Then you will see it, C1-01 RM-607,, USB ONLY Connection. B.R. |
The Following User Says Thank You to Advance-Box For This Useful Post: |
04-06-2011, 08:45 | #4 (permalink) |
Member: 651945 Status: Offline Thanks Meter: 20,118 | @VM_SODHA Yes, you care correct... Simlocks of this phone is actually BB5... But CPU of phone is Infineon... And flashing the phone uses Infineon Protocol. That is why I put it in Infineon :O) Anyway, Problem solved :O) B.R. |
04-06-2011, 09:39 | #5 (permalink) | |
No Life Poster Join Date: Jul 2008 Location: BHARAT Age: 42
Member: 823633 Status: Offline Thanks Meter: 1,705 | Quote:
Code: 11:17:21 : Number of Image Files: 3 11:17:21 : 11:17:21 : Processing Image File : 11:17:21 : rm607__04.40.mcusw 11:17:21 : CMT Type : 11:17:21 : CMT Algorithm : 11:17:21 : Secondary Sending Speed : 0Hz 11:17:21 : Algorithm Sending Speed : 0Hz 11:17:21 : Program Sending Speed : 0Hz 11:17:21 : Message Reading Speed : 0Hz 11:17:21 : Number of Blocks : 0 11:17:21 : Entry Point: 0x0000 11:17:21 : Page Format : -1 11:17:21 : MAX PAGE : 0x00000000 11:17:21 : 11:17:27 : Number of Image Files: 3 11:17:27 : 11:17:27 : Processing Image File : 11:17:27 : rm607__04.40.mcusw 11:17:27 : CMT Type : 11:17:27 : CMT Algorithm : 11:17:27 : Secondary Sending Speed : 0Hz 11:17:27 : Algorithm Sending Speed : 0Hz 11:17:28 : Program Sending Speed : 0Hz 11:17:28 : Message Reading Speed : 0Hz 11:17:28 : Number of Blocks : 0 11:17:28 : Entry Point: 0x0000 11:17:28 : Page Format : -1 11:17:28 : MAX PAGE : 0x00000000 11:17:28 : 13:06:18 : Number of Image Files: 3 13:06:19 : 13:06:19 : Processing Image File : 13:06:19 : rm607__04.40.mcusw 13:06:19 : Processing Image File : 13:06:19 : rm607__04.40.ppm_mr 13:06:19 : Processing Image File : 13:06:19 : rm607__04.40.image_mr_059B0Z1 13:06:19 : []: Found 1 active devices. 13:06:19 : [Nokia C1-01 USB Phonet]: Opening Connection 13:06:19 : [Nokia C1-01 USB Phonet]: Port opened OK! 13:06:19 : 13:06:19 : SW: V 03.35 02-12-10 RM-607 (c) Nokia 13:06:19 : IMEI: 356976048396973 13:06:19 : 13:06:19 : START FULL PM BACKUP 13:06:19 : Please Wait... 13:06:39 : Reading : PM 0~400... OK! 13:06:39 : FULL PM Backup Saved to: 13:06:39 : C:\AdvanceBox Turbo Flasher\Nokia\Backup\356976048396973\USB_FULL_BACKUP_V 03.35 02-12-10 RM-607 (c) Nokia_356976048396973__10639.pm 13:06:39 : 13:06:39 : 13:06:39 : Reading battery value : 4295 mV 13:06:39 : Rebooting Phone... 13:06:39 : 13:06:40 : 13:06:40 : 13:06:40 : AUTO SELECTED DEAD USB FLASHING... 13:06:40 : 13:06:40 : If Flashing DOES NOT Start in 5 Seconds, 13:06:40 : Then Perform Steps 1, 2, 3 and 4... 13:06:40 : 13:06:40 : 1. Remove USB and Battery... 13:06:40 : 2. Insert USB. 13:06:40 : 3. Insert Battery. (Some phones boot automatically) 13:06:40 : 4. Please Power on phone shortly.. 13:06:40 : 13:06:44 : ERROR: BOOTING FAILED... 13:06:44 : Sending PBL... 13:06:44 : ERROR: PBL was NOT Accepted 13:07:01 : ERROR: No Flash Files Loaded 13:07:01 : 13:07:16 : Number of Image Files: 3 13:07:16 : 13:07:16 : Processing Image File : 13:07:16 : rm607__04.40.mcusw 13:07:16 : Processing Image File : 13:07:16 : rm607__04.40.ppm_mh 13:07:16 : Processing Image File : 13:07:16 : rm607__04.40.image_mh_0595598 13:07:17 : []: Found 1 active devices. 13:07:17 : [Nokia C1-01 USB Phonet]: Opening Connection 13:07:17 : [Nokia C1-01 USB Phonet]: Port opened OK! 13:07:17 : 13:07:17 : SW: V 03.35 02-12-10 RM-607 (c) Nokia 13:07:17 : IMEI: 356976048396973 13:07:17 : 13:07:17 : START FULL PM BACKUP 13:07:17 : Please Wait... 13:07:37 : Reading : PM 0~400... OK! 13:07:37 : FULL PM Backup Saved to: 13:07:37 : C:\AdvanceBox Turbo Flasher\Nokia\Backup\356976048396973\USB_FULL_BACKUP_V 03.35 02-12-10 RM-607 (c) Nokia_356976048396973__10737.pm 13:07:37 : 13:07:37 : 13:07:37 : Reading battery value : 4300 mV 13:07:38 : Rebooting Phone... 13:07:38 : 13:07:38 : 13:07:38 : 13:07:38 : AUTO SELECTED DEAD USB FLASHING... 13:07:38 : 13:07:38 : If Flashing DOES NOT Start in 5 Seconds, 13:07:38 : Then Perform Steps 1, 2, 3 and 4... 13:07:38 : 13:07:38 : 1. Remove USB and Battery... 13:07:38 : 2. Insert USB. 13:07:38 : 3. Insert Battery. (Some phones boot automatically) 13:07:38 : 4. Please Power on phone shortly.. 13:07:38 : 13:07:40 : 13:07:40 : Infineon USB Boot: F00A1FB300020303010100FF 13:07:40 : Sending PBL... 13:07:43 : PBL Successfully Sent... 13:07:43 : Sending SBL... 13:07:43 : SBL Successfully Sent... 13:07:43 : Setting Transmission Speed Done... 13:07:43 : Flash Chip Manufacturer: Samsung Electronics Corp. 13:07:43 : Flash Boot Successful... 13:07:43 : 13:07:43 : 13:07:43 : 13:07:43 : Current File : rm607__04.40.mcusw 13:07:43 : Image Type : Main Firmware 13:07:43 : Sections : 05 13:07:43 : Compile Name: rm607__04.40.mcusw_ebl_psi.fls 13:07:44 : Data Size : 26217904 Bytes 13:07:44 : 13:07:44 : Sending Certificate Block 13:07:44 : FIRMWARE Certificate Block Sent Successfully... 13:07:44 : Processing Section 01 of 05 13:07:44 : FIRMWARE Erase Block: 0x40000000~0x4001FFFE 13:07:44 : Start Erasing... 13:07:44 : Erasing Please Wait... 13:07:44 : Block Erase Done... 13:07:44 : Preparing Data Blocks... 13:07:44 : Data Size: 131072 bytes 13:07:44 : Data Checksum: 8F75 13:07:44 : Uploading Data Blocks to phone... 13:07:44 : Block Write Successful... 13:07:44 : FIRMWARE Data Blocks uploaded to phone... 13:07:44 : Processing Section 02 of 05 13:07:44 : FIRMWARE Erase Block: 0x40040000~0x4007FFFE 13:07:44 : Start Erasing... 13:07:44 : Erasing Please Wait... 13:07:45 : Block Erase Done... 13:07:45 : Preparing Data Blocks... 13:07:45 : Data Size: 262144 bytes 13:07:45 : Data Checksum: 0000 13:07:45 : Uploading Data Blocks to phone... 13:07:46 : Block Write Successful... 13:07:46 : FIRMWARE Data Blocks uploaded to phone... 13:07:46 : Processing Section 03 of 05 13:07:46 : FIRMWARE Erase Block: 0x40080000~0x4009FFFE 13:07:46 : Start Erasing... 13:07:46 : Erasing Please Wait... 13:07:46 : Block Erase Done... 13:07:46 : Preparing Data Blocks... 13:07:46 : Data Size: 131072 bytes 13:07:46 : Data Checksum: 865C 13:07:46 : Uploading Data Blocks to phone... 13:07:46 : Block Write Successful... 13:07:46 : FIRMWARE Data Blocks uploaded to phone... 13:07:46 : Processing Section 04 of 05 13:07:46 : FIRMWARE Erase Block: 0x400A0000~0x4019FFFE 13:07:46 : Start Erasing... 13:07:46 : Erasing Please Wait... 13:07:48 : Block Erase Done... 13:07:48 : Preparing Data Blocks... 13:07:48 : Data Size: 1048576 bytes 13:07:48 : Data Checksum: 62BA 13:07:48 : Uploading Data Blocks to phone... 13:07:50 : Block Write Successful... 13:07:50 : FIRMWARE Data Blocks uploaded to phone... 13:07:50 : Processing Section 05 of 05 13:07:50 : FIRMWARE Erase Block: 0x40400000~0x41BFFFFE 13:07:50 : Start Erasing... 13:07:50 : Erasing Please Wait... 13:08:37 : Block Erase Done... 13:08:37 : Preparing Data Blocks... 13:08:37 : Data Size: 24641536 bytes 13:08:37 : Data Checksum: 1A47 13:08:37 : Uploading Data Blocks to phone... 13:09:22 : Block Write Successful... 13:09:22 : FIRMWARE Data Blocks uploaded to phone... 13:09:22 : Data Verification Successful... 13:09:22 : 13:09:22 : 13:09:22 : Current File : rm607__04.40.ppm_mh 13:09:22 : Image Type : PPM Image 13:09:23 : Sections : 01 13:09:23 : Compile Name: package_mh.ppm_ebl_psi.fls 13:09:23 : Data Size : 4014208 Bytes 13:09:23 : 13:09:23 : Sending Certificate Block 13:09:23 : PPM Certificate Block Sent Successfully... 13:09:23 : Processing Section 01 of 01 13:09:23 : PPM Erase Block: 0x41C00000~0x421FFFFE 13:09:23 : Start Erasing... 13:09:23 : Erasing Please Wait... 13:09:35 : Block Erase Done... 13:09:36 : Preparing Data Blocks... 13:09:36 : Data Size: 4010864 bytes 13:09:36 : Data Checksum: D98F 13:09:36 : Uploading Data Blocks to phone... 13:09:43 : Block Write Successful... 13:09:43 : PPM Data Blocks uploaded to phone... 13:09:43 : Data Verification Successful... 13:09:43 : 13:09:43 : 13:09:43 : Current File : rm607__04.40.image_mh_0595598 13:09:43 : Image Type : CONTENT Package 13:09:43 : Sections : 01 13:09:43 : Compile Name: package_mh_0595598.image.fls 13:09:43 : Data Size : 12717328 Bytes 13:09:43 : 13:09:43 : Sending Certificate Block 13:09:43 : CONTENT Certificate Block Sent Successfully... 13:09:43 : Processing Section 01 of 01 13:09:43 : CONTENT Erase Block: 0x42200000~0x43E5FFFE 13:09:44 : Start Erasing... 13:09:44 : Erasing Please Wait... 13:10:44 : Block Erase Done... 13:10:45 : Preparing Data Blocks... 13:10:45 : Data Size: 12713984 bytes 13:10:45 : Data Checksum: 1BAE 13:10:45 : Uploading Data Blocks to phone... 13:11:07 : Block Write Successful... 13:11:07 : CONTENT Data Blocks uploaded to phone... 13:11:07 : Data Verification Successful... 13:11:08 : Total Flashing Time (Erase + Flashing) : 00:03:25 13:11:08 : (Booting time is NOT Included) 13:11:08 : 13:11:08 : Waiting for Phone to Start-Up..(Max 100 seconds) 13:11:08 : 13:11:08 : If Windows is Installing Drivers... 13:11:08 : Phone Polling MIGHT Exit Automatically. 13:11:13 : Elapsed Time: 5 Seconds... 13:11:18 : Elapsed Time: 10 Seconds... 13:11:23 : Elapsed Time: 15 Seconds... | |
04-06-2011, 09:54 | #6 (permalink) |
Member: 651945 Status: Offline Thanks Meter: 20,118 | Here too :O) Code: Number of Image Files: 3 Processing Image File : rm607__03.35.mcusw Processing Image File : rm607__03.35.ppm_ms Processing Image File : rm607__03.35.image_ms_059F2M3 AUTO SELECTED DEAD USB FLASHING... If Flashing DOES NOT Start in 5 Seconds, Then Perform Steps 1, 2, 3 and 4... 1. Remove USB and Battery... 2. Insert USB. 3. Insert Battery. (Some phones boot automatically) 4. Please Power on phone shortly.. Infineon USB Boot: F00A1FB300020303010100FF Sending PBL... PBL Successfully Sent... Sending SBL... SBL Successfully Sent... Setting Transmission Speed Done... Flash Chip Manufacturer: Intel Electronics Corp. Flash Boot Successful... Current File : rm607__03.35.mcusw Image Type : Main Firmware Sections : 05 Compile Name: rm607__03.35.mcusw_ebl_psi.fls Data Size : 26217904 Bytes Sending Certificate Block FIRMWARE Certificate Block Sent Successfully... Processing Section 01 of 05 FIRMWARE Erase Block: 0x40000000~0x4001FFFE Start Erasing... Erasing Please Wait... Block Erase Done... Preparing Data Blocks... Data Size: 131072 bytes Data Checksum: A830 Uploading Data Blocks to phone... Block Write Successful... FIRMWARE Data Blocks uploaded to phone... Processing Section 02 of 05 FIRMWARE Erase Block: 0x40040000~0x4007FFFE Start Erasing... Erasing Please Wait... Block Erase Done... Preparing Data Blocks... Data Size: 262144 bytes Data Checksum: 0000 Uploading Data Blocks to phone... Block Write Successful... FIRMWARE Data Blocks uploaded to phone... Processing Section 03 of 05 FIRMWARE Erase Block: 0x40080000~0x4009FFFE Start Erasing... Erasing Please Wait... Block Erase Done... Preparing Data Blocks... Data Size: 131072 bytes Data Checksum: 865C Uploading Data Blocks to phone... Block Write Successful... FIRMWARE Data Blocks uploaded to phone... Processing Section 04 of 05 FIRMWARE Erase Block: 0x400A0000~0x4019FFFE Start Erasing... Erasing Please Wait... Block Erase Done... Preparing Data Blocks... Data Size: 1048576 bytes Data Checksum: 097B Uploading Data Blocks to phone... Block Write Successful... FIRMWARE Data Blocks uploaded to phone... Processing Section 05 of 05 FIRMWARE Erase Block: 0x40400000~0x41BFFFFE Start Erasing... Erasing Please Wait... Block Erase Done... Preparing Data Blocks... Data Size: 24641536 bytes Data Checksum: C5EE Uploading Data Blocks to phone... Block Write Successful... FIRMWARE Data Blocks uploaded to phone... Data Verification Successful... Current File : rm607__03.35.ppm_ms Image Type : PPM Image Sections : 01 Compile Name: package_ms.ppm_ebl_psi.fls Data Size : 3558500 Bytes Sending Certificate Block PPM Certificate Block Sent Successfully... Processing Section 01 of 01 PPM Erase Block: 0x41C00000~0x421FFFFE Start Erasing... Erasing Please Wait... Block Erase Done... Preparing Data Blocks... Data Size: 3555156 bytes Data Checksum: 120C Uploading Data Blocks to phone... Block Write Successful... PPM Data Blocks uploaded to phone... Data Verification Successful... Current File : rm607__03.35.image_ms_059F2M3 Image Type : CONTENT Package Sections : 01 Compile Name: package_ms_059F2M3.image.fls Data Size : 12061968 Bytes Sending Certificate Block CONTENT Certificate Block Sent Successfully... Processing Section 01 of 01 CONTENT Erase Block: 0x42200000~0x43E5FFFE Start Erasing... Erasing Please Wait... Block Erase Done... Preparing Data Blocks... Data Size: 12058624 bytes Data Checksum: 25D1 Uploading Data Blocks to phone... Block Write Successful... CONTENT Data Blocks uploaded to phone... Data Verification Successful... Total Flashing Time (Erase + Flashing) : 00:06:47 (Booting time is NOT Included) Waiting for Phone to Start-Up..(Max 100 seconds) If Windows is Installing Drivers... Phone Polling MIGHT Exit Automatically. Elapsed Time: 5 Seconds... Elapsed Time: 10 Seconds... Elapsed Time: 15 Seconds... Elapsed Time: 20 Seconds... MCU: V 03.35 02-12-10 RM-607 (c) Nokia IMEI: 355962041369952 Model : J C1-01 Product Serial Number: HUB713492 Product Code : 0596365 Module Code : 0204427 Basic Production Code: 0585582 Default SN Type : 0 MCU SW Version : V 03.35 02-12-10 RM-607 (c) Nokia MS BT MCM Version : 19b5-22012 PPM Version : V 03.35 02-12-10 RM-607 (c) Nokia HW Version : 1000 RFIC Version : 96 LCD Version : AUO Content Pack Version : Content: ms_059F2M3 V 03.35 02-12-10 RM-607 (c) Nokia ********** SIMLOCK INFO ********** CONFIG_DATA : 0010100000000000 PROFILE_BITS : 800000000003000B Asic : 11 Provider : Default Test Operator Block [1] 1:Open 2:Open 3:Open 4:Open 5:Open Block [2] 1:Open 2:Open 3:Open 4:Open 5:Open Block [3] 1:Open 2:Open 3:Open 4:Open 5:Open Block [4] 1:Open 2:Open 3:Open 4:Open 5:Open Block [5] 1:Open 2:Open 3:Open 4:Open 5:Open Block [6] 1:Open 2:Open 3:Open 4:Open 5:Open Block [7] 1:Open 2:Open 3:Open 4:Open 5:Open ST_SIMLOCK_TEST : PASSED ST_LCD_TEST : PASSED SECURITY_CODE : 12345 MASTER_CODE : 0044016052 PHONE_MODE : TEST MODE ================================================ Dynamic Camera Configuration ================================================ DCC ID : NI00CS00000401022E05 DCC Ver: 001004 Status : OK FACTORY SET TO : Full Factory Set OK FACTORY SET TO : User Data OK FACTORY SET TO : Leave Factory OK FACTORY SET TO : Service Center OK FACTORY SET TO : Software Upgrade OK FACTORY SET TO : Production Tune OK Life timer data is not yet used... Life timer: ----:-- |
