03-21-2010, 04:40 | #1 (permalink) |
Crazy Poster Join Date: Dec 2008
Member: 917156 Status: Offline Thanks Meter: 4 | ATF Please update the error can not be used to help AdvanceBox Turbo Flasher Found Driver Version : 00020422 Library Version : 00030119 Initialize Device.... Init TRY : 1 Init TRY : 2 Init TRY : 3 ****************************************** INIT : FAILED , CHECK YOUR BOX FIRMWARE ****************************************** |
03-21-2010, 05:16 | #3 (permalink) |
No Life Poster Join Date: May 2007 Location: Alien Nation
Member: 515413 Status: Offline Thanks Meter: 146 | AdvanceBox Turbo Flasher Found Driver Version : 00020422 Library Version : 00030119 Initialize Device.... Init TRY : 1 Init TRY : 2 Init TRY : 3 ****************************************** INIT : FAILED , CHECK YOUR BOX FIRMWARE ****************************************** error occured with my ATF too.,so wait product support to confirmation about error.. BR |
03-21-2010, 05:26 | #4 (permalink) |
Freak Poster Join Date: Mar 2005 Location: inside USB cable Age: 41
Member: 128122 Status: Offline Thanks Meter: 256 | install this update http://www.advance-box.com/atfsoft/A...010.0.1.22.exe After installation extract update 4.5 and copy paste it in installation folder of ATF, replace file if exist. Run exe then update firmware. |
03-21-2010, 05:35 | #5 (permalink) | |
Member: 515413 Status: Offline Thanks Meter: 146 | Quote:
03-21-2010, 06:12 | #9 (permalink) |
Member: 128122 Status: Offline Thanks Meter: 256 | Code: AdvanceBox Turbo Flasher Found Driver Version : 00020422 Library Version : 00030119 Initialize Device.... Init TRY : 1 Box Name : AdvanceBox Turbo Box Firmware : LogiCore 3.21.10 Software Version : v0.0.4.5 AdvanceBox SN : B57E17A0C7A4ED6DC97700D0 BOX Status : ACTIVATED INIT : OK VBATT OFF ... VBATT ON Setting VBATT Done!... //////////// //// //// //////// //////// ////////// //// //// //// /// // /// /// /// /// //// //// //// //////// //////// /// /// //// //// //// /// /// /// /// /// /// //// //////// /// /// //////// /////// At first attempt box firmware update failed... I uninstalled drivers and uninstall last update. Then install this http://www.advance-box.com/atfsoft/A...010.0.1.22.exe After installation install drivers again and then extract 4.5 update to the installation folder of ATF, note: some files exist already you need to overwrite that with the files comes with 4.5 update. |
03-21-2010, 21:42 | #10 (permalink) | |
Moderator Join Date: Oct 2009 Location: Poland Age: 42
Member: 1139057 Status: Offline Sonork: 100.109924 Thanks Meter: 4,428 | Quote:
NEW FIRMWARE IS Box Firmware : LogiCore 3.21.20 | |
03-21-2010, 22:15 | #11 (permalink) |
No Life Poster Join Date: Jan 2000 Location: GSM Forum
Member: 871 Status: Offline Thanks Meter: 602 | This problem can be solved now in the latest version 4.60 ... When the ATF Box is updating, it will take some time. Usually about 2 minutes to 5 minutes depending on your current CPU load and the number of USB devices connected to your PC. When firmware update is disrupted/stopped at any time, you can still use the "RESTORE" firmware button to fix and upgrade your box firmware. Before updating the firmware, I strongly suggest rebooting your PC and disconnecting any other USB devices. You can also temporarily disable your anti-virus softwares just to make sure the update will not fail as most of our files are packed with Themida. B.R. X-Shadow |
03-22-2010, 14:24 | #12 (permalink) |
No Life Poster Join Date: May 2006 Location: MOBILE SOFTZONE BHUBANESWAR IN
Member: 271478 Status: Offline Sonork: 1590868 Thanks Meter: 1,070 | Init TRY : 1 Box Name : AdvanceBox Turbo Box Firmware : LogiCore 3.21.10 Software Version : v4.6 AdvanceBox SN : C5BC7762D8A06439C79E60B5 BOX Status : ACTIVATED INIT : OK AdvanceBox Turbo Flasher Found Driver Version : 00020422 Library Version : 00030119 Initialize Device.... Init TRY : 1 Box Name : AdvanceBox Turbo Box Firmware : LogiCore 3.21.10 Software Version : v4.6 AdvanceBox SN : C5BC7762D8A06439C79E60B5 BOX Status : ACTIVATED INIT : OK ImageFile:c:\Program Files\Nokia\Phoenix\Products\RH-105\rh105_05.71mg PhoneType : DCT4 Algorithm : DCT4 ALGORITHM Supported Hardwares : > 2292 Secondary Sending Speed : 100000Hz Algorithm Sending Speed : 6500000Hz Program Sending Speed : 6500000Hz Message Reading Speed : 51000Hz Number of Blocks : 73 Entry Point: 0x00D2 Is128k: True Boot Check, Please wait... DCT4 Failed to BOOT Flashing FAILED... Flashing ERROR Time Elapse : 00:00:00 |
03-22-2010, 14:28 | #13 (permalink) |
No Life Poster Join Date: Mar 2005 Location: Facebook: Java John Age: 43
Member: 122246 Status: Offline Sonork: 100.50000 Thanks Meter: 4,993 | akhil_bbsr can you catch me on yahoo messenger so i can help you |
The Following 2 Users Say Thank You to Javajohn For This Useful Post: |
Hello, installed MXKEY 1.7, POTATO platform can not be used, CHK error | chgood | MXKEY Nokia Flasher and Unlocker (by Alim Hape) | 5 | 03-28-2010 12:56 |
Can not unlock T469! Reading the error code! Not have access to support part of the! | liufeifei | Z3X-Team Products | 7 | 12-23-2009 09:11 |
Problem with blackberry 7290 ? Version too old or current firmware can not be used? | gsmnice | FuriousGold | 8 | 05-12-2009 13:40 |
Box can not be connected to unlock bb5 help! | wagnei | JAF No Tp Unlocker by Cinek | 6 | 04-14-2009 19:59 |
downloading flash file is so hard and can not be used | karouk | Universalbox | 0 | 02-20-2007 15:25 |
