Welcome to the GSM-Forum forums. You are currently viewing our boards as a guest which gives you limited access to view most discussions and access our other features. By joining our free community you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is fast, simple and absolutely free so please, join our community today! If you have any problems with the registration process or your account login, please contact contact us. |
| Register | FAQ | Donate | Forum Rules | ★. iPhone Unlock .★ | -= JTAG BOOM =- | Search | Today's Posts | Mark Forums Read |
| | #1 (permalink) |
| Freak Poster ![]() ![]() ![]() ![]() Join Date: Jan 2010
Member: 1210415 Status: Offline Thanks: 60
| atf problem new dear sir 2 3 day before i buy atf new one all driver ok version 6.30 scan ok but when i fls it doesn't read and not flash and not make rpl backup and safter operation failcan some tel what is it thks & regard nasir |
| | #3 (permalink) | |
| Product Supporter ![]() ![]() ![]() Join Date: Dec 2006 Location: Karachi, Pakistan Age: 22
Member: 643472 Status: Offline Sonork: 100.96901 Thanks: 6
| Quote:
did you restore box ? check your cable and post logs of error also. BR | |
| | #6 (permalink) |
| Freak Poster ![]() ![]() ![]() ![]() Join Date: Aug 2005 Location: Ahmedabad,gujarat,india. Age: 41
Member: 173509 Status: Offline Sonork: 100.1584320 Thanks: 130
| hi,i already post logs but there is no reply,here is log: HI I GOT NEW ATF WITH COMPACT SIZE,MY OLD BIG HARDWARE WORKS FINE BUT WHEN I TRY TO WORK WITH NEW ONE IT SHOW ERROR LIKE THIS: ATF Box is not in USB 2.0 Mode ============================================== * Go to "Product Support" tab and click the * "Restore Box" Button to fix the Box Firmware ** If Problem is Not Solved... 1. Make Sure you are NOT using USB HUBS 2. Make Sure your USB port is USB 2.0 3. Make Sure you are using the latest Drivers *** If Problem is STILL Not Solved 1. Use a THICKER USB Cable 2. Connect ATF Directly to the Root USB Port 3. Uninstall Drivers, Reboot PC, Reinstall **** If you are still Stuck... 1. Search your entire PC for "ftdibus.sys 2. Delete all "ftdibus.sys" files you find 3. Reboot PC... 4. Disconnect ATF Box and all Boxes from PC 5. Run C:\AdvanceBox Turbo Flasher\Driver\Remove_ATF_Drivers\Remove_ATF_Drive rs.bat 6. ReInstall ATF Software 7. Connect ATF Box Only to your USB Port I TRY ALL THING UNINSTALL,REMOVE DRIVER ETC BUT STILL NO LUCK.WHEN I TRY TO UPDATE FIRMWARD IT REPLY "QUERY NOT FOUND" ALSO GIVE ME THIS ERROR "Advance-Box Secure AES-128 Channel Open Port Success... Error return code 6 Error return code Elapsed time = 00:00:01" SO PLS SUPPORTER GIVE ME GUIDE WHT TO DO NEXT,THNX IN ADVANCE FOR ADVANCE BOX. :::SHABBIRHUSAIN::: |
| | #8 (permalink) | |
| Freak Poster ![]() ![]() ![]() ![]() Join Date: Sep 2007 Location: Nashik
Member: 578632 Status: Offline Thanks: 104
| Quote:
its problem of ur port is not 2.0 that y u r getting this massage use each on of port of motherboard ur problem 100% solve here is log AdvanceBox Turbo Flasher Found Driver Version : 00020601 Library Version : 00030119 Initialize Device.... Init TRY : 1 Box Name : ATF Lightning Box Firmware : LogiCore 8.15.10 Software Version : v6.50 AdvanceBox SN : DC4F122AF3A18C56BEF5430C BOX Status : ACTIVATED INIT : OK VBATT OFF... VBATT ON Setting VBATT Done!... ///////// /// /// /////// /////// ///////// /// /// /// /// // /// /// /// /// /// /// /// /////// /////// /// /// /// /// /// /// /// /// /// /// /// /// ///// /// /// /////// ////// ======================================= /// /// /// ///////// /////// ////// ///// /// /// /// /// // /// /// /// ///// /// /// /////// /// /// /// //// /// /// /// /// /// /// /// /// /// /// /// /// ////// | |
| Bookmarks |
| Thread Tools | |
| Display Modes | |
| New Nokia Software!!!!!!! | Jefferson | Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) | 73 | 05-15-2013 13:07 |
| How to upload a new firmware... | Brand | Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) | 28 | 08-30-2012 03:40 |
| Sim card sleep mode problem with 6130 | ratzfatz | Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) | 4 | 05-22-2012 11:13 |
| Seeking for flash nokia 5110 old version (3 version) can exchange for new | Tomas | Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) | 7 | 11-17-2011 17:08 |
| FREECALLING HACKED SIM CARDS AND PROGRAMMERS SEE FREECELL'S NEW SITE FOR MORE!!! | FREECELLUK | Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) | 0 | 06-26-1999 22:48 |
