09-11-2013, 14:12 | #1 (permalink) | ||
Junior Member Join Date: Sep 2012 Location: di hatimu
Member: 1811020 Status: Offline Thanks Meter: 0 | ATF problem update firmware.. help (ATF BIG BOX) I try to restore and update again but still same problem i can work with ver 9.50 or 9.60 , but can't with ver 10.10 or 10.11 Quote:
thanks... | ||
09-11-2013, 16:19 | #2 (permalink) |
No Life Poster Join Date: Apr 2007 Location: M W Balasore,Odisha,INDIA Age: 52
Member: 492222 Status: Offline Sonork: 100.1594126 Thanks Meter: 10,377 | Just follow this , all will OK 1. Disconnect any phones connected to ATF Box 2. Go to "Product Support Tab" 3. Go to "Box Tools" Section 4. Click "Update Firmware" button Br - srinibas |
The Following User Says Thank You to srinibas For This Useful Post: |
09-11-2013, 17:08 | #3 (permalink) |
Member: 1811020 Status: Offline Thanks Meter: 0 | I try at many time after update release until today. But I found this report error return code 6 I try with other pc.. But same report. My box is default pcb.. Not modified. |
09-11-2013, 18:13 | #4 (permalink) |
No Life Poster Join Date: Dec 2007
Member: 651945 Status: Offline Thanks Meter: 20,118 | @vexian09 ERROR CODE 6, means it cannot detect correct chip ID. It can be because some legs of the the 2 BIG IC on the ATF PCB are not connected ok. So if you rehot the chips and make sure all legs are ok, this will fix your problem. |
09-12-2013, 05:23 | #5 (permalink) |
Member: 1811020 Status: Offline Thanks Meter: 0 | Advance-Box I check and resolder two big chip legs... after that, i try to update again.. but still same problem error.. :.why i can't upload screenshoot pict in this thread |
09-12-2013, 10:42 | #6 (permalink) |
Member: 1811020 Status: Offline Thanks Meter: 0 | after rehot then same problem... Can you show me where the chip that makes this problem. whether from FTDI or the ACTE. thanks please contact me on ym: vexian_vians |
