Unlock Server
Go Back   GSM-Forum > Product Support Sections > Hard/Software Products (official support) > Advance-Box
Old 08-16-2012, 14:11   #1 (permalink)
gsmfun's Avatar
Member: 611
Sonork: 100.33333
ATF SL3 Simlock Recovery v9.02 AUTO-Update!! Discussion Thread:
Introducing The ATF Simlock Recovery Module v1.0
Introduction:
In the past, when a dead Nokia BB5 SL3 Phone comes to your shop, it was only
possible for you to backup the IMEI via a Backup RPL Function. There was no
way for you to backup a possibly 100% working SIMLOCK inside the phone because
you needed Local/Test Mode in order to get the PM Backups. Dead Phones cannot
give you Local/Test Mode at all, so you cannot backup the Simlocks even if you
wanted to.
Now here comes the Solution... The ATF Simlock Recovery Module v1.0 will allow
you to BACKUP SIMLOCKS from a DEAD PHONE! Just a 1-click solution for Recovery
Level 1 and Level 2 for NON-CORRUPTED SIMLOCKS on a DEAD PHONE.
Even if your phone SIMLOCKS are CORRUPTED, The ATF Network can still attempt to
perform a Level 3 Recovery from it, but it will cost you some ATF SL3 Credits.
Here is a Short Description about the three Simlock Recovery Levels:
Recovery Level 1:
* FREE for ALL ATF BOX Users (DOES NOT NEED CREDITS or ATF NETWORK ACTIVATION)
* Phone DOES NOT need to be AUthorized
* 100% Stand Alone
* Supports ALL SL3 XSR3 NAND Blocks for RAPUv1, RAPUv2, RAPIDO, RAPG3v4 and BCM21351
* Supports ALL SL3 XSR2 NAND Blocks for RAPUv1, RAPUv2, RAPIDO, RAPG3v4 and BCM21351
* Supports ALL SL3 NOR Blocks for RAP3Gv3 (FULL PM RECOVERY)
* Supports ALL SL2 NOR Blocks for RAP3Gv3 (FULL PM RECOVERY)
* Supports ALL SL1 NOR Blocks for RAP3Gv3 (FULL PM RECOVERY)
* Supports USB or FBUS Connection (FBUS ONLY FOR RAP3Gv3)
* Recover from DUMP FILE or from Connected PHONE
* Super Fast Recovery, BUT SIMLOCKS WILL NOT BE VERIFIED
* The output file is a REGULAR PM FILE with PM 120 Sections 0, 1, 2 and 3
* DOES NOT SUPPORT FULLY ERASED PHONES
* SUCCESS RATE = 70% if the CORRECT SIMLOCKS ARE STILL INSIDE THE FLASH DUMP
Recovery Level 2:
* FREE for ALL ATF Network Users (DOES NOT NEED CREDITS)
* Phone NEEDS to be Authorized via The ATF Network
* Stand Alone ONLY AFTER PHONE IS AUTHORIZED via The ATF Network
* Supports ALL SL3 NOR Blocks for RAP3Gv3 (FULL PM RECOVERY + RECOVER ORIGINAL SIMLOCKS if SIMLOCKS are OVERWRITTEN)
* Recover from Connected PHONE ONLY
* Recovery Time will depend on Fragmentation Level of the XSR Blocks
* SIMLOCKS WILL BE VERIFIED (Since Phone is already Authorized)
* SUCCESS RATE = 95% if the CORRECT SIMLOCKS ARE STILL INSIDE THE FLASH DUMP
Recovery Level 3:
* Needs SL3 Credits and only available for ATF Network Activated Users
* Recovery is performed by our Servers (NOT STAND ALONE)
* Recovery Time will depend on CURRENT TASK LOAD on the ATF Simlock Recovery Server
* POSSIBLE TO SUPPORT OVERWRITTEN PM 120 Blocks with Wrong PM 120 Blocks
* POSSIBLE TO SUPPORT FULLY ERASED PHONES
* DOES NOT SUPPORT WRONG FLASHED PHONES with WRONG FIRMWARE (Repartitioned NANDs)
* SUCCESS RATE = 95% if the Phone is not wrongly Repartitioned by a wrong Firmware
IMPORTANT INFORMATION:
1. Level 1 Recovered Simlocks are NOT VERFIED to be Working (NOT GUARANTEED)
2. Level 2 Recovered Simlocks are 100% VERIFIED and Guaranteed to WORK
3. Level 3 Recovered Simlocks are 100% VERIFIED and Guaranteed to WORK
Summary:
If your phone is DEAD, but the SIMLOCKS are 100% OK, then the ATF Simlock
Recovery Module will recover your simlocks for you via Recovery Level 1 or 2.
If your phone is DEAD, and the SIMLOCKS are possibly corrupted, then the
ATF Simlock Recovery Module will recover your simlocks for you via Recovery
Level 3 + ATF SL3 Credits.
Box Firmware Update:
New ATF Firmware LogiCore 10.3.15 for ATF Chrome, ATF Lightning and ATF Nitro Boxes
Other Updates:
* MEEGO PHONE Authorization EVEN IF 20-digit SL3 Code is detected.
* Shows full RPL (Certificates) Information during Backup RPL on BB5 Phones.
--> Checks Original IMEI
--> Checks Original Product Code
--> Checks PA_PUBLIC_ID
--> Checks PA_PUBLIC_KEYS_HASH
--> Checks Original BT ID
--> Checks Original WLAN ID
* New option in Settings "Select USB Connection by Default when ATF Software Starts"
* Cross Flashing is now IMPOSSIBLE if Phone has good IMEI (NO MORE WRONG FIRMWARES)
* Flash File CRC32 is now CHECKED BY DEFAULT on Flash Files downloaded from NaviFirm etc...
* Other small tweaks which I already forgot to mention...
Who will buy this if you can get more in ATF?
__________________________________________________ ________________________
Buy only from ATF [Advance Turbo Flasher] authorized resellers:
ATF [Advance Turbo Flasher] Authorized Distributors and Resellers List
ATF [Advance Turbo Flasher] official web sites:
International - http://www.advance-box.com/
ATF [Advance Turbo Flasher] official support forums:
World Wide: Advance Turbo Flasher - GSM-Forum
Indonesia: ATF (Advance Turbo Flasher))
Philippine: Gsmph
Syria: Arabic Support (Syria) GsmVIP
Chinese support forum : ATF Box
Vietnam: Saigonmobile
India: Advance Box - .:: GsmIndia ::.
Official Iran Support Forum : ASANGSM FORUM
Bangladesh: Advance Box - Dhaka Mobile
Chinese Support forum : www.yananliuhuan.com
The Master Piece
Advance Turbo Flasher v9.01
Release Date: August 17, 2012
QUICK FIX UPDATE:
* Fixed FBUS Flashing ERROR about Corrupted Entries @ XXXXXX 0x55 ERRORS
* Fixed CRC32 File Checking on Small-Sized Flash Files
* Now shows Current SL3 BF Unlock and SL3 Simlock Recovery (Level 3) Cost
Advance Turbo Flasher v9.02
Release Date: August 18, 2012
QUICK FIX UPDATE:
* FBUS Readt Full Flash Chip 0 MB ERROR
* Fixed GUI in Support Tab
Update your ATF Setups NOW!
Update AdvanceBox.exe is now available via the AUTO UPDATE Function
The Following 336 Users Say Thank You to gsmfun For This Useful Post:
Old 08-16-2012, 14:15   #2 (permalink)
Member: 1222089
Sonork: 100.1583019
Great update by Advancebox Team
Regards
Smartgsm
The Following 6 Users Say Thank You to Smart-gsm For This Useful Post:
Old 08-16-2012, 14:17   #3 (permalink)
Member: 407669
grate up date thanksssssssssssssssssssssssssssssssssssssss
Old 08-16-2012, 14:21   #4 (permalink)
Member: 636569
Sonork: 100.1620925
waaaaaaw.....grate update bro.....
The Following 2 Users Say Thank You to lages_79 For This Useful Post:
Old 08-16-2012, 14:21   #5 (permalink)
xxxman's Avatar
Member: 59185
Sonork: 100.1593175
DOWNLOAD HERE:
Offical Hotfile Mirror
Offical Mirrorcreator Mirror
The Following 37 Users Say Thank You to xxxman For This Useful Post:
Old 08-16-2012, 14:23   #6 (permalink)
guljee786's Avatar
Member: 762034
Sonork: 100.1585274
Great update thanx ATF team........
Guljee
Old 08-16-2012, 14:25   #7 (permalink)
pshycoboy's Avatar
Member: 1597314
boom update atf team,level 3 how much credit consumtion?
The Following User Says Thank You to pshycoboy For This Useful Post:
Old 08-16-2012, 14:26   #8 (permalink)
Tanha0321's Avatar
Member: 314003
Sonork: 100.1608368
ATF hote nokia flasher box & nice update
Old 08-16-2012, 14:27   #9 (permalink)
Member: 1738848
Sonork: 1001604198
thanks....and love you atf team
Old 08-16-2012, 14:28   #10 (permalink)
SHIJILFONOTLY's Avatar
Member: 351924
Sonork: 100.1581941
nice..................................
very big updates
i like it
sl3 simlock recovery
i hope more on the way
Old 08-16-2012, 14:29   #11 (permalink)
viewprofile's Avatar
Member: 1784151
Sonork: www.make.my/gsmhosting
superb.............
Old 08-16-2012, 14:31   #12 (permalink)
GSM_HABIB's Avatar
Member: 1199125
Sonork: 100.1609676
wow bomb bomb update
Old 08-16-2012, 14:34   #13 (permalink)
alex_030385's Avatar
Member: 875541
Sonork: 100.1604468
broom!!! nice hardwork team a simple dangerous attitude i like it team...
The Following User Says Thank You to alex_030385 For This Useful Post:
Old 08-16-2012, 14:35   #14 (permalink)
Member: 1144411
Sonork: 100.1593619
Hi,
World First, for sure
br
The Following 2 Users Say Thank You to maroc11 For This Useful Post:
Old 08-16-2012, 14:36   #15 (permalink)
Yasir Ali's Avatar
Member: 270869
Sonork: 100.1600061
how much credit of repair SIMLOCK DATA CORRUPTED
==== FREE DOWNLOAD ==== site updated cimbalo GSM Mobile Links 31 04-29-2012 20:43
Nokia 6150 5.02 Stupid Security Code!!! Ringnet Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) 10 05-04-2000 01:27
Software update HitMan Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) 0 12-13-1999 18:54
SimLock Level 4 counter HitMan Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) 0 11-11-1999 23:17
N6150 simlock open??? Tommy Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) 2 05-21-1999 09:31
vBulletin Optimisation provided by vB Optimise v2.5.2 (Lite) - vBulletin Mods & Addons Copyright © 2013 DragonByte Technologies Ltd. ()
Page generated in 0.97239 seconds with 12 queries
