08-17-2012, 14:55 | #211 (permalink) | |
No Life Poster Join Date: Dec 2007
Member: 651945 Status: Offline Thanks Meter: 20,118 | Quote:
@icu778 1. You think dead phones can read PM ? 2. Do you know how to take PMM blocks from XSR partitioned area of NAND Flash ? 3. You think all problems in corrupted simlocks is related to PM 120 0 only ? Our solution is nothing related to your Psychedelic "ascii art" which you could have just made very simple by telling people to download the simlock PM 120-0 block that matches to their product code from Navifirm and write it to their phone. Very simple just to remove SHA-1 20 bytes from the simlock.bin, and copy paste the rest to notepad as PM [120] 0=.... No need to make some elaborate colorful ascii analysis. We take simlock data directly from flash chip, so it does not matter if phone is dead or alive... It is nothing related to your colorful post. We do not fix PM 120 manually with your colorful ascii art info... We do not take Simlocks from RPL... Do you understand what you are talking about? Click RPL Backup button and do you see SIMLOCKS inside??? Or you mean you buy RPL from some provider and convert RPL into PM??? What for? Original RPL is not accepted by your phone? What are you trying to do? | |
08-17-2012, 15:18 | #214 (permalink) |
No Life Poster Join Date: Feb 2005 Location: HYD[INDIA] Age: 43
Member: 115144 Status: Offline Sonork: 100.1590698 Thanks Meter: 498 | Example : Sl3 5130 Simlock Data Corrupted.............. Hi Sir X-shadow, Thanx for this solution........... Example : Sl3 5130 Simlock Data Corrupted.............. Is it possible to recovery corrupted simlock data from level2 or we can use level3 Service................ Please tel me Clearly............ I am waiting for purchage atf nitro network activated, i have already atf metal box but not activated so........... I am waiting ur Answer.......... BR, Srinivas Reddy |
08-17-2012, 15:21 | #215 (permalink) | |
No Life Poster Join Date: Apr 2007 Location: M W Balasore,Odisha,INDIA Age: 52
Member: 492222 Status: Offline Sonork: 100.1594126 Thanks Meter: 10,377 | Quote:
Br - srinibas | |
08-17-2012, 15:24 | #216 (permalink) | |
Cant say from which level you can recover the data. for better information read - Release.txt from ATF folder on your PC Br - srinibas | |
08-17-2012, 15:46 | #217 (permalink) |
No Life Poster Join Date: Jun 2009 Location: SouthAmericaUnlockers Age: 52
Member: 1057178 Status: Offline Sonork: Kfe~Labs Co.- Thanks Meter: 568 | ATF Team I Testing this process with a Phone In Good State.. Here Log.. Nokia X-3 Basic Phone Information ================================================ MCU Version: V 03.60 21-10-09 RM-540 (c) Nokia IMEI Plain : 357977035354784 IMEI Spare : A357977035354780 IMEI SV : 33579770353547806F Phone Model: Nokia X3-00 Category : Live Phone Phone Type : RM-540 ================================================ Extended Phone Information ================================================ Product Serial Number: GBN156216 Product Code : 0595835 Module Code : 0204201 Basic Production Code: 0578316 Long Production SN : 0 PPM SW Version : V 03.60 21-10-09 RM-540 (c) Nokia L BT MCM Version : 1673-46034 MCU SW Version : V 03.60 21-10-09 RM-540 (c) Nokia HW Version : 4000 RFIC Version : 0831 DSP Version : ICPR91_09w39_RC LCD Version : SEIKO Content Pack Version : Content: claro_ar_bk_rd V 03.60 21-10-09 RM-540 (c) Nokia AHNE Version : 41 RETU Version : 40 TAHVO Version : 00 Bluetooth ID : EC:9B:5B:CA:EA:A2 CS Type : GSM850, GSM900, GSM1800, GSM1900 ================================================ Simlock Information ================================================ CONFIG KEY : 8000000000000000 PROVIDER KEY : 7242100000000000 NETWORK NAME : MRR MORROCO S.A;MORROCO [GSM] LOCK COUNTERS : KEYPRESS 0/3, FBUS 0/10 SIMLOCK TABLE : Block [1] 1:Close Block [2] 1:Close Block [3] 1:Close SIMLOCK STATE : LOCKED SIMLOCK_TYPE : PA_SL3 (15-digit NCK) SIMLOCK_TEST : PASSED SECURITY_TEST : PASSED SECURITY_CODE : 210303 PHONE_MODE : TEST ================================================ Dynamic Camera Configuration ================================================ DCC ID : NI00IIIIRR0301035420 DCC Ver: 003008 Status : OK When i Check for recovered Process say.. Dumping PMM Partition FlashInfo.RestartMode : Test Mode ================================================== ===== ATF SL3 Simlock Recovery Module v1.0 ================================================== ===== STATUS: Mounting Flash Dump... STATUS: Searching for Simlock Table... STATUS: Simlock Table FOUND! STATUS: Simlock Hashes FOUND! REPORT: Simlock Signature was NOT FOUND! REPORT: Simlock Recovery FAILED! REPORT: Try Level 2 or Level 3 Recovery REPORT: Total Elapsed Time 00:01:27 I Think, Is Because the Phone is in good State..(display Hard problem) Solved. But I dont Know why say REPORT: Simlock Signature was NOT FOUND! REPORT: Simlock Recovery FAILED! Should be say, SimLock is Ok Not Need Recovery Process! Br Polaco |
08-17-2012, 15:53 | #218 (permalink) |
Member: 651945 Status: Offline Thanks Meter: 20,118 | @el-polaco Yes, because you did Level 1 -- Try doing Level 2 and post results... Level 1 cannot verify simlocks, so if phone is fragmented, then it cannot get anything. |
08-17-2012, 15:57 | #219 (permalink) |
Freak Poster Join Date: Mar 2007
Member: 465286 Status: Offline Thanks Meter: 77 | Quote: |
08-17-2012, 16:06 | #220 (permalink) | |
Member: 1057178 Status: Offline Sonork: Kfe~Labs Co.- Thanks Meter: 568 | Work X-3 test - Level 2 Ok - Free Quote:
Dumping PMM Partition FlashInfo.RestartMode : Test Mode ================================================== ===== ATF SL3 Simlock Recovery Module v1.0 ================================================== ===== STATUS: Mounting Flash Dump... STATUS: PMM Storage Found at 0x000FC000 STATUS: Defragmenting XSR3 Blocks REPORT: XSR3 Fragmentation Level VERY HIGH REPORT: Defragmentation might take HOURS! Slow Process But Work Perfect Best Regard Polaco | |
The Following User Says Thank You to el-polaco For This Useful Post: |
08-17-2012, 16:08 | #221 (permalink) | |
Member: 492222 Status: Offline Sonork: 100.1594126 Thanks Meter: 10,377 | Quote: Think twice about it . Just answer here , can your solution extract PM file from a dead phone ( if hardware part OK ) ??? | |
08-17-2012, 16:29 | #222 (permalink) |
Member: 651945 Status: Offline Thanks Meter: 20,118 | @srinibas Don't mind him... He thinks Simlocks can be extracted from RPL made from Backup RPL Function... Totally missing the point, and I doubt he will ever understand even if you explain to him in full color. |
The Following User Says Thank You to Advance-Box For This Useful Post: |
08-17-2012, 16:29 | #223 (permalink) |
08-17-2012, 16:33 | #224 (permalink) |
No Life Poster Join Date: Jun 2011 Location: sonu
Member: 1595511 Status: Offline Sonork: nnn Thanks Meter: 121 | Dumping PMM Partition ================================================== ===== ATF SL3 Simlock Recovery Module v1.0 ================================================== ===== STATUS: Mounting Flash Dump... REPORT: XSR Blocks Not Found! Only XSR SL3 NAND Partitions are Supported! REPORT: Recovery FAILED! REPORT: Total Elapsed Time 00:00:36 hellp |
08-17-2012, 17:02 | #225 (permalink) |
No Life Poster Join Date: Feb 2008 Location: Brazil Age: 41
Member: 700706 Status: Offline Sonork: 100.1590381 Thanks Meter: 208 | No reply for me? http://forum.gsmhosting.com/vbb/8680551-post221.html Please guive-me one solution... |
==== FREE DOWNLOAD ==== site updated | cimbalo | GSM Mobile Links | 31 | 04-29-2012 20:43 |
Nokia 6150 5.02 Stupid Security Code!!! | Ringnet | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 10 | 05-04-2000 01:27 |
SimLock Level 4 counter | HitMan | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 0 | 11-12-1999 00:17 |
N6150 simlock open??? | Tommy | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 2 | 05-21-1999 09:31 |
