Go Back   GSM-Forum > Product Support Sections > Hard/Software Products (official support) > Advance-Box
Old 10-16-2013, 21:45   #1 (permalink)
vazgsm's Avatar
Member: 111871
Sonork: 100.78975
Thanks Meter: 99
ATF software hangs on flashing rm-819 (lumia 800.2)
what I´ve got is this:
Windows Phone Flashing Started
OSBL File Found:
 RM801_13w11_prod_generic_nokia_osbl.esco
AMSS File Found:
 RM801_13w11_prod_generic_amss.esco
ADSP File Found:
 RM801_13w11_prod_generic_adsp.esco
WPOS File Found:
 RM819_13110_prod_200_01_boot.esco
USER AREA ERASE File Found:
 RM801_13w11_prod_generic_user_area_erase.esco
             Windows Phone Lumia Flasher
If the Phone is ALIVE
  1. Power On the Phone and Connect it to the USB Port
If the Phone is DEAD
  1. Press and Hold the VOLUME UP button
  2. Connect it to the USB Port while still Pressing
  3. Continue to Press the VOLUME UP button for 8 more
     seconds
--> 01B00BBB000000004B49434B
and then it just hangs like that, till I remove usb cable. when I do, it show that:
OSBL File Found:
AMSS File Found:
ADSP File Found:
WPOS File Found:
     seconds
<-- 0000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000F00102000000000A00AA55413A0001000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000012010002000000402104EE050000030200010000000000000000000012010002000000402104EE05000003020001000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000
--> 03B00BBB00000000
<-- 0000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000
ERROR: Data Rejected at SEQ 0x1
ERROR: Data Rejected at SEQ 0x2
Sending OSBL Certificate
HASH: 0C203F23776466E755E9955A9F8F9A39A0888B8E
Certificate Size: 452 Bytes
ERROR: Data Rejected at SEQ 0x3
Status     : WRITE OSBL CERTIFICATE FAILED
Phone is dead, does not show charging, or any signal besides entering nokia dload. According to customer, phone just turned off when she was installing whatsapp. would tp boot repair have any chance to solve it, as its boot was NOT tampered?
ps,: using other tools, they also hang with this phone, not just ATF. not driver problem, and I can flash other rm-819 successfully, problem is only with this specific phone.
br
Old 10-17-2013, 01:29   #2 (permalink)
vazgsm's Avatar
Member: 111871
Sonork: 100.78975
Thanks Meter: 99
Phone Care Suite error with this phone:
DTL Connection: Could not connect to media. DTL Back-End error code = 0x8400A403. DTL Back-End: Driver initialization failed. DCM status code = 0x84004424, Common USB DCM: USB preparation failed, last error code = 0x8007000D. .
   em FuseLib.DtlConnectionClass.ConnectToMedia()
   em Nokia.CareSuite.PlugIns.WezenRecovery.RecoveryConnectionManager..ctor(FuseLoader fuseLoader, IConnection connection, UserInteractionDelegate userInteractionDelegate)
   em Nokia.CareSuite.PlugIns.WezenRecovery.RecoveryDialog.RecoveryDialogModel.Flash()
   em Nokia.CareSuite.PlugIns.WezenRecovery.RecoveryDialog.RecoveryDialogModel.<HandleDownloadVariantPackageCompleted>b__7(Object state)
Old 10-17-2013, 14:26   #3 (permalink)
Bruno Rafael's Avatar
Member: 700706
Sonork: 100.1590381
Thanks Meter: 202
vaz, resolvi um desses a uns 5 dias via test point, e bastou regravar os boot´s com as opções:
M.B.R
SEC_BOOT ( SBL)
OSB DLOAD ( NOKIA)
depois apliquei a flash pela atf mesmo e foi de boa!!
Prazer Reve-lo Celio....qualquer problema posta ai ou me busca no MSN que agente arruma!
Abraço
traduzido para o ingles pelo google:
vaz, I decided one of these about 5 days via test point, and it was enough to rewrite the boot's options:
M.B.R
SEC_BOOT (SBL)
OSB DLOAD (NOKIA)
then applied the same flash by atf and it was good!
Pleasure Reve it ... no problem there or put me on MSN search agent that arranges!
hug
Old 10-17-2013, 15:23   #4 (permalink)
vazgsm's Avatar
Member: 111871
Sonork: 100.78975
Thanks Meter: 99
nice, I´ll do the boot repair then. Just didn´t want to loose time with phone that won´t turn on. Even though I didn´t see anything wrong with the board, I still suspected it could be hardware issue. I´ve got no problem with repair itself, but maybe it simply won´t make difference, so decided to ask before putting any effort into it.
i´ll try it out this afternoon, and let thread updated.
br
diz ae Bruno,
o lance é que o aparelho não foi mexido, não teve tentativa de flash ou root, ou qqer coisa que seja. E normalmente aparelhos que morrem assim não se resolve com reparo do boot. vou tentar assim mesmo, embora esteja com uma preguiça tremenda devido ao valor que foi cobrado nesse cel. odeio pegar telefone de amigo... cobra barato e fica com a responsa de resolver.
abcs,
Celio
Old 10-17-2013, 16:30   #5 (permalink)
Member: 700706
Sonork: 100.1590381
Thanks Meter: 202
o meu tbm era novo zerado, e morreu do nada....Juro que se eu pudesse iria ai fazer pra vc rsrsrs, porque o que vc me ajudou quando precisei nao cabe em um cordel..rsrs
Abraço
Page generated in 0.21137 seconds with 7 queries
