07-01-2015, 11:09 | #34 (permalink) |
No Life Poster Join Date: Apr 2011 Age: 58
Member: 1564612 Status: Offline Thanks Meter: 12,343 | Depend of you SO are using, for Win 7 are 2.10.0.0 in Win Xp are different, just loock in Atf Folder "Atf New Drivers" and from device manager "Update Drivers" for you SO, if XP install for XP and ViceVersa BR allumts |
07-02-2015, 05:52 | #36 (permalink) |
No Life Poster Join Date: Dec 2012 Location: SRI LANKA
Member: 1857049 Status: Offline Sonork: 100.1627774 Thanks Meter: 208 | lumia 630 dead boot done............. Windows Phone 8/8.1/10 Flashing Started Loading Flash Files Please Wait... [DEAD BOOT REPAIR via USB is SUPPORTED] ================================================== ==== Windows Phone 8/8.1/10 Lumia Flasher ================================================== ==== If the Phone is ALIVE 1. Power On the Phone and Connect it to the USB Port If the Phone is DEAD 1. Connect Phone to the USB Port 2. Press and Hold the VOLUME DOWN and POWER Buttons 3. Wait until the Phone Vibrates Shortly... 4. Stop Pressing the Buttons... If the Phone is DEAD BOOT 1. Connect Phone to the USB Port 2. Install Correct Drivers: "Nokia Emergency Connectivity" Located at: C:\AdvanceBox Turbo Flasher\Driver\NOKIA_X2_USB_DRIVERS\ ================================================== ==== Recovery Handle Found! - (WinUSB) PBL Emergency Download Detected Start Sending Firehose Loader... Firehose Loader Sent! Executing Firehose Loader... Start Processing Firehose Payload... MSG_SIGNATURE Sent.... Validation is enabled. EMMC: size_in_sectors:15269888, mfr_id:144, oem_id:74, prod_rev:1, mfr_date:5/2014 MSG_HASHTABLE Sent.... MSG_XML_CONFIGURE_\8626_edl_fh_image_config.xml Sent... MSG_XML_PROGRAM_SBL1 Sent... start 53248, num 493 Finished sector address 53741 MSG_XML_PROGRAM_RPM Sent... start 65536, num 302 Finished sector address 65838 MSG_XML_PROGRAM_TZ Sent... start 69632, num 690 Finished sector address 70322 MSG_XML_PROGRAM_UEFI Sent... start 61440, num 2229 Finished sector address 63669 MSG_XML_PROGRAM_WINSECAPP Sent... start 73728, num 538 Finished sector address 74266 MSG_XML_PROGRAM_TZAPPS Sent... start 77824, num 1070 Finished sector address 78894 MSG_XML_PROGRAM_DBI Sent... start 57344, num 36 Finished sector address 57380 MSG_XML_ERASE_DDR Sent... start 36864, num 32 Finished address 36896 MSG_XML_ERASE_PLAT Sent... start 167936, num 16384 Finished address 184320 MSG_XML_ERASE_EFIESP Sent... start 184320, num 65536 Finished address 249856 MSG_XML_PROGRAM_8626_gpt_v1_0.bin Sent... start 0, num 34 Finished sector address 34 MSG_XML_POWER Sent... Firehose Payload All Sent! Waiting for USB Cycle... USB Cycle OK! Rebooting Phone... Nokia Phone Info Mode Initiated... Please wait upto 15 Seconds for SW Reset 1. Press and Hold the VOLUME DOWN and POWER 2. Wait until the Phone Reboots... 3. Wait until you see BIG "NOKIA" Logo 4. Stop Pressing the Buttons... Continuing Previous Boot... Please wait upto 30 Seconds for Boot Re-entry Boot Flash Mode Successful... Buffers Flushed OK... Phone Info Query Start... 1. Press and Hold the VOLUME DOWN and POWER 2. Wait until the Phone Reboots... 3. Wait until you see BIG "NOKIA" Logo 4. Stop Pressing the Buttons... Product Code: 059W061 Module Code: 0205737 Continuing Previous Boot... Please wait upto 30 Seconds for Boot Re-entry Boot Flash Mode Successful... Buffers Flushed OK... Phone Info Query Start... Blocks Returned: 0x09 Blocks Block ID 0x01 : 00241000 Block ID 0x1F : 01 Block ID 0x02 : 00240000 Block ID 0x03 : 00E90000 Block ID 0x05 : Nokia.MSM8226.P6112.2.0 Block ID 0x0D : 0001 Block ID 0x0F : 0301010100000101FF Block ID 0x10 : 01001F0000 Block ID 0x20 : 010000000100000004 Checking SD Card Size... Card Size: 0x00000000 Checking Platform Security Status... Platform Secure Boot Status: Active Secure FFU EFUSE Status: Active Debug Status: Active RDC Status: Not Active Authentication Status: Not Active UEFI Secure Boot Status: Active Checking Secure FFU Mode... Secure FFU Mode : Query Flash App Information... Flash App Information: 02021C023300 UEFI App: FLASH APP Flash App Protocol Version: 2.28 Flash App Implementation Version: 2.51 Query ROOT KEY HASH... ROOT_KEY_HASH: 24992314394C54B74827E99157E176F9023393E55590A8554E A3F2228064DEEC Query PUBLIC ID... PUBLIC_ID: 1611E4CA1456276E7751CDF24732A752B8CA37C3 Query eMMC Info... EMMC Manufacture ID: HYNIX EMMC Product SN : 01DAF9C6 EMMC_SIZE: 8 Gigabytes Query Battery Charge Status... BATTERY CHARGE_STATUS: 99% Sending Image Signatures... Image Signatures Accepted! Erasing Data Partition... Data Partition Erased Successfully Fixing Partitions... Preparing Buffers for DATA LOOP... Allocating System RAM OK! Start Sending DATA BLOCKS... Finished Sending all DATA BLOCKS! Exiting FLASH Mode via REBOOT... Exit FLASH Mode Successful! Flashing Done! Total Flashing Time : 00:30:22 |
07-03-2015, 22:21 | #37 (permalink) |
No Life Poster Join Date: Mar 2009 Location: SAUDI ARABIA
Member: 998872 Status: Offline Sonork: jan143 Thanks Meter: 295 | but this new version having problem in win 7 when i install virus detect and then not opening any solution for this problem pls guide me.. |
