10-05-2015, 19:12 | #1 (permalink) |
Freak Poster Join Date: Jan 2010 Location: In GSM Field
Member: 1207045 Status: Offline Sonork: 100.1617234 Thanks Meter: 58 | Atf Sucsesfuly flash nokia lumia 925 Windows Phone 8/8.1/10 Lumia Flasher ================================================== ==== If the Phone is ALIVE 1. Power On the Phone and Connect it to the USB Port If the Phone is DEAD 1. Connect Phone to the USB Port 2. Press and Hold the VOLUME DOWN and POWER Buttons 3. Wait until the Phone Vibrates Shortly... 4. Stop Pressing the Buttons... If the Phone is DEAD BOOT 1. Connect Phone to the USB Port 2. Install Correct Drivers: "Nokia Emergency Connectivity" Located at: C:\AdvanceBox Turbo Flasher\Driver\NOKIA_X2_USB_DRIVERS\ ================================================== ==== Nokia Phone Info Mode Initiated... Please wait upto 15 Seconds for SW Reset Version: 1.1.1.3 Product Code: 059T0P0 Module Code: 0205431 Continuing Previous Boot... Please wait upto 30 Seconds for Boot Re-entry Boot Flash Mode Successful... Buffers Flushed OK... Phone Info Query Start... Blocks Returned: 0x07 Blocks Block ID 0x01 : 00241000 Block ID 0x02 : 00240000 Block ID 0x03 : 01D5A000 Block ID 0x05 : Nokia.MSM8960.P6023.3.2.1 Block ID 0x0D : 0001 Block ID 0x0F : 0301010100000101FF Block ID 0x10 : 01001F0000 Checking SD Card Size... Card Size: 0x00000000 Checking Platform Security Status... Platform Secure Boot Status: Active Secure FFU EFUSE Status: Active Debug Status: Active RDC Status: Not Active Authentication Status: Not Active UEFI Secure Boot Status: Active Checking Secure FFU Mode... Secure FFU Mode : Query Flash App Information... Flash App Information: 020112020200 UEFI App: FLASH APP Flash App Protocol Version: 1.18 Flash App Implementation Version: 2.2 Query ROOT KEY HASH... ROOT_KEY_HASH: CD84376222AAF204C85119532BF34EA55C8844E4CEA35F3E50 8D25AA34D96637 Query PUBLIC ID... PUBLIC_ID: 60579649B267E8E21DB308AB8F59D3385E9B4B33 Query eMMC Info... EMMC Manufacture ID: TOSHIBA EMMC Product SN : 4C494579 EMMC_SIZE: 16 Gigabytes Query Battery Charge Status... BATTERY CHARGE_STATUS: 13% Sending Image Signatures... Image Signatures Accepted! Erasing Data Partition... Data Partition Erased Successfully Fixing Partitions... Preparing Buffers for DATA LOOP... Allocating System RAM OK! Start Sending DATA BLOCKS... Finished Sending all DATA BLOCKS! Exiting FLASH Mode via REBOOT... Exit FLASH Mode Successful! |
