Go Back   GSM-Forum > Product Support Sections > Hard/Software Products (official support) > Advance-Box
Old 12-23-2012, 08:24   #76 (permalink)
..::Angel::..'s Avatar
Member: 643472
Sonork: 100.96901
@shoaibrao
I have checked and we don't have this problem. So it MUST be something
from your side. You may need to make fresh INSTALLATION of ATF Setup 9.40!
Old 12-23-2012, 08:30   #77 (permalink)
shoaibrao's Avatar
Member: 412843
Sonork: 100.1604902
Originally Posted by pakistan786 View Post
just unistall atf setup
then delete the folder
of atf setup in c drive
then restart pc and again install setup
problem will be solved
Have You Read My Post?
Plz Dont Argue With Out Reading
Old 12-23-2012, 13:34   #78 (permalink)
faizanbhatti94's Avatar
Member: 265129
Sonork: 100.1597027
Originally Posted by shoaibrao View Post
Some Thing Wrong When Flash To Infineon Models Like 1616-2(Rm-125)
I Tried To Change Skin
I Updated Important Files
Uninstalled And Installed Again MainSetUp
Also Uninstalled Drivers Then Installed Again
But Same
But When Installed Old Version 7.30 Working Well
ATF Team Plz Check It
Thanks Anticipation.....
same problem with me
Old 12-24-2012, 05:16   #79 (permalink)
Member: 1380501
Same problem With Me ............
Old 12-24-2012, 05:59   #80 (permalink)
srinibas's Avatar
Member: 492222
Sonork: 100.1594126
Delete this - C:\AdvanceBox Turbo Flasher\Data
If not OK then change the skin ti iMetal from setting , Post result
Br - srinibas
Old 12-24-2012, 08:51   #81 (permalink)
Member: 643472
Sonork: 100.96901
What do you mean by "same problem with me" ?
Old 12-24-2012, 09:09   #82 (permalink)
deepakgarg's Avatar
Member: 220603
Sonork: 100.1624258
even atf is disconnected it shows serial number even after fresh install
this problem occurs only after 9.40
Old 12-24-2012, 09:21   #83 (permalink)
Member: 643472
Sonork: 100.96901
@deepakgarg
Write me PM with your team viewer details.
Old 12-24-2012, 09:50   #84 (permalink)
bre786's Avatar
Member: 6200
Sonork: 100.33330
Goood Update.................................!
Old 12-24-2012, 10:00   #85 (permalink)
shoaibrao's Avatar
Member: 412843
Sonork: 100.1604902
Br - srinibas
Same Problem After Deleting Data Folder And Changing Skin.....
Old 12-24-2012, 16:01   #86 (permalink)
Member: 1263652
some thing wrong when flash to infineon models like 1616-2(rm-125)
i tried to change skin
i updated important files
uninstalled and installed again mainsetup
also uninstalled drivers then installed again
but same
but when installed old version 7.30 working well
atf team plz check it
thanks anticipation.....
same problem also with me .... Help please..!!!!
Old 12-24-2012, 20:28   #87 (permalink)
Member: 1263652
sorry ... problem solved
then delete the folder of atf setup in c drive
Old 01-19-2013, 18:12   #88 (permalink)
Member: 185279
Red face
Hi, I have a N8, with V111.040 only show Nokia and stuck, I can't put in Local mode, how can I repair it ?
Without local mode can I repair CMLA ?
Thank you.
Old 01-28-2013, 15:57   #89 (permalink)
Crazy Poster
Member: 1779651
Sonork: 100.1603336
thanks for good updates aft team every time you work hard
Old 02-03-2013, 05:31   #90 (permalink)
..:::YMG:::..'s Avatar
Member: 667126
Extended Phone Information
Product Serial Number: CTE808954
Product Code : 0539240
Basic Production Code: 0536420
MCU SW Version : V 05wk07v48.1 28-08-07 RM-84 (c) Nokia.
HW Version : 7005
RFIC Version : 150a160f
DSP Version : rolf_05wk07v29p1
AHNE Version : 22
RETU Version : 32
TAHVO Version : 53
Bluetooth ID : 00:1C4:28:50:70
Simlock Information
CONFIG KEY : 0000000000000000
PROVIDER KEY : 2440700000000000
NETWORK NAME : Nokia Default;Finland
LOCK COUNTERS : KEYPRESS 0/3, FBUS 0/10
SIMLOCK TABLE :
Block [1] 1:Open 2:Open 3:Open 4:Open 5:Open
Block [2] 1:Open 2:Open 3:Open 4:Open 5:Open
Block [3] 1:Open 2:Open 3:Open 4:Open 5:Open
Block [4] 1:Open 2:Open 3:Open 4:Open 5:Open
Block [5] 1:Open 2:Open 3:Open 4:Open 5:Open
Block [6] 1:Open 2:Open 3:Open 4:Open 5:Open
Block [7] 1:Open 2:Open 3:Open 4:Open 5:Open
SIMLOCK STATE : Not Locked
SIMLOCK_TYPE : PA_SL1
SIMLOCK_TEST : PASSED
SECURITY_TEST : PASSED
CMLA_KEY : ABSENT
SUPER_DONGLE_TEST : PASSED
SL1/SL2 Phone detected
PHONE_MODE : NORMAL
Page generated in 0.67308 seconds with 11 queries
