Go Back   GSM-Forum > Product Support Sections > Hard/Software Products (official support) > Advance-Box
Old 09-10-2010, 15:33   #16 (permalink)
Member: 639817
I am using firefox and I still have the same problem even though javascript is enabled. I can go on everything except updates and support. plz help
Old 09-11-2010, 04:26   #17 (permalink)
sansari's Avatar
Member: 755709
Sonork: 100.1592000 Momo...
nice move big team you re the best.
Old 11-23-2010, 12:47   #18 (permalink)
Crazy Poster
Member: 1029731
Sonork: 0000
FAILED , CHECK YOUR BOX FIRMWARE
help me
Old 11-23-2010, 12:47   #19 (permalink)
Crazy Poster
Member: 1029731
Sonork: 0000
my atf problem pls hel me
Old 11-24-2010, 10:00   #20 (permalink)
Crazy Poster
Member: 1029731
Sonork: 0000
my atf problem ==============================================
ATF Box is not in USB 2.0 Mode
* Go to "Product Support" tab and click the
* "Restore Box" Button to fix the Box Firmware
** If Problem is Not Solved...
1. Make Sure you are NOT using USB HUBS
2. Make Sure your USB port is USB 2.0
3. Make Sure you are using the latest Drivers
*** If Problem is STILL Not Solved
1. Use a THICKER USB Cable
2. Connect ATF Directly to the Root USB Port
3. Uninstall Drivers, Reboot PC, Reinstall
**** If you are still Stuck...
1. Search your entire PC for "ftdibus.sys
2. Delete all "ftdibus.sys" files you find
3. Reboot PC...
4. Disconnect ATF Box and all Boxes from PC
5. Run C:\AdvanceBox Turbo Flasher\Driver\Remove_ATF_Drivers\Remove_ATF_Drive rs.bat
6. ReInstall ATF Software
7. Connect ATF Box Only to your USB Port
8. Install the Correct Drivers
INIT : FAILED , CHECK YOUR BOX FIRMWARE
Old 01-07-2011, 10:50   #21 (permalink)
neilthirumuttam's Avatar
Member: 15903
Sonork: 100.1583162
whenever trying to go 4 support for full flash file download from exe itself
it says Please open support area from ATF Software
Y THIS ERROR IS ?
im trying to get some infinion fones
regards,
NEIL
Old 01-19-2011, 17:32   #22 (permalink)
Crazy Poster
Member: 1371631
Sonork: nyetikojha@yahoo.com
main problem atf box dct4 bus chake fail eroer
Old 03-08-2011, 07:33   #23 (permalink)
Y.P.Y's Avatar
Member: 1010502
Sonork: whats this?!
ATF 7.10 Direct Link From ATF SERVER
http://174.120.45.27/atfupdate/?dir=...AdvanceBox.exe
Old 05-02-2011, 07:43   #24 (permalink)
riajul1988's Avatar
Member: 1511441
Sonork: 100.1604057
Originally Posted by frozenice View Post
Hi,
when you encounter loging in to our support site
and you never saw the folders / directories
and only you can see is the loading animation..
1. if you use IEx please make atf support site as trusted site.
in this way javascript will execute properly. because the directory list
need javascript to be enabled.
2. Enable javascript on your browser (Mozilla / Safari). maybe its disabled.
or disable anything that prevents ATF site to execute javascript and curl.
3. Your using a browser (ex IE) browser 4 or lower or other browser that does not
support new web technologies..
I have tested it on FF 3.0 - 3.5 and IE 8.0 with javascript enabled.
if still problem exist.
you may sonork me so can find a work around.
on the next update. i will alert a notice if needed to enable the browsers javascript or to check if its disabled.
you may also try to change your default browser from IE to FF
Setting Firefox as the default browser does not work | Troubleshooting | Firefox Help
br
i having problem for ATF support site.
i use win7 & Mozilla Firefox 4.0 Beta 4
all ready Enable javascript but don't work ATF support site all ways blank
please help
Old 05-02-2011, 16:07   #25 (permalink)
Member: 1000479
Sonork: 100.1638119
hi ATF team
i have a pro with my atf when i open atf application it shows a error box
system error, code 5
access is denied
please help me
Old 05-02-2011, 16:19   #26 (permalink)
Member: 1000479
Sonork: 100.1638119
hi ATF team
access is denied
please help me
Old 05-10-2011, 14:55   #27 (permalink)
riajul1988's Avatar
Member: 1511441
Sonork: 100.1604057
Mozilla Firefox 4.0 Beta 4, Google Chrome , Opera
same problem all ways blank ATF support site
Old 05-10-2011, 17:04   #28 (permalink)
..::Angel::..'s Avatar
Member: 643472
Sonork: 100.96901
Hello.
Select 'Venus' in software and download flash files from there.
Old 05-10-2011, 17:23   #29 (permalink)
Member: 1524293
atf best supporter and resaller
who is the best supporter in ap of atf please send all poles
Old 06-05-2011, 04:42   #30 (permalink)
Member: 1591187
como ago para activar mi caja avance turbo flasher con que version lo puedo hacer yo tengo la version 750 y solo me sale box not found
no one can unlock 6110 05.40 25-5-99 fondas Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) 12 09-02-2012 19:17
Need help to make a site for free software hicom Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) 3 10-14-1999 22:57
I need passwords for new bontiek sites programs Zahooo Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) 4 09-10-1999 22:42
FREECALLING HACKED SIM CARDS AND PROGRAMMERS SEE FREECELL'S NEW SITE FOR MORE!!! FREECELLUK Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) 0 06-26-1999 22:48
Page generated in 0.37934 seconds with 11 queries
