11-27-2014, 17:29 | #1 (permalink) |
Freak Poster Join Date: Jul 2014 Location: Erode TAMILnadu INDIA
Member: 2231748 Status: Offline Sonork: whatsapp 09942395196 Thanks Meter: 107 | ATF team answer me Is ATF light dead or not? 1.Is ATF light dead or not? 2.let me know any atf still alive? 3.If working then why all boxes not activated ?(see peoples crying about atf light activation) |
11-28-2014, 06:24 | #2 (permalink) | |
No Life Poster Join Date: May 2013 Location: In Core Of eMMC
Member: 1950912 Status: Offline Sonork: 100.1654643(Offline) Thanks Meter: 403 | Quote:
Please read sticky threads before posting look here is reason>>>>>http://forum.gsmhosting.com/vbb/f609...-asap-1819744/ __________________ Best Regards Omi17 | |
11-28-2014, 15:28 | #3 (permalink) |
Member: 2231748 Status: Offline Sonork: whatsapp 09942395196 Thanks Meter: 107 | all your solutions done but cannot activate my atf lightening box ,have you try any lightening box till date please try first then post here and post only one proof i am awaiting as last 4 updates no use i remind you this is atf light i am working on xp ser3 |
11-28-2014, 15:41 | #4 (permalink) | |
No Life Poster Join Date: Apr 2011 Age: 58
Member: 1564612 Status: Offline Thanks Meter: 12,343 | Quote:
BR allumts | |
11-28-2014, 15:51 | #5 (permalink) |
Member: 2231748 Status: Offline Sonork: whatsapp 09942395196 Thanks Meter: 107 | thanks @allumts, see my problm, Driver Version : 00020416 Library Version : 00030118 Box Type : ATF Lightning Box Firmware : LogiCore 11.0.00 Software Version : v11.80 AdvanceBox SN : F6A473D59D3FABB8FB0B276B ERROR: Internet Connection Required Please Connect to the Internet and Try Again |
11-28-2014, 16:31 | #6 (permalink) | |
Member: 1564612 Status: Offline Thanks Meter: 12,343 | Not see alone? Quote:
Install, and Update Driver, are obsolete, (find in C:/AdvanceBox/Drivers/New Drivers XP/X32), and from "Product Support" tabulate>>> "Update Important File" reboot Atf sw BR allumts | |
11-28-2014, 17:39 | #7 (permalink) |
Member: 2231748 Status: Offline Sonork: whatsapp 09942395196 Thanks Meter: 107 | 09:44:36 : ================================================ 09:44:36 : Advance Turbo Flasher Found 09:44:36 : ================================================ 09:44:36 : Driver Version : 00020416 09:44:36 : Library Version : 00030118 09:44:38 : Box Type : ATF Lightning 09:44:38 : Box Firmware : LogiCore 11.0.00 09:44:38 : Software Version : v11.80 09:44:38 : AdvanceBox SN : F6A473D59D3FABB8FB0B276B 09:44:41 : 09:44:41 : ERROR: Internet Connection Required 09:44:41 : Please Connect to the Internet and Try Again 09:44:41 : 09:44:41 : 09:44:41 : ================================================ 09:44:41 : ATF SOFTWARE IS NOT ACTIVATED ON THIS PC 09:44:41 : Please Activate your ATF Software 09:44:41 : ================================================ 09:44:41 : 09:44:41 : * Follow these Instructions 09:44:41 : 1. Connect this PC to the INTERNET 09:44:41 : 2. Restart ATF Software 09:44:41 : 09:44:41 : 09:44:41 : 09:44:41 : ================================================ 09:44:41 : Box Successfully Initialized 09:44:41 : ================================================ 09:44:42 : my internet connection works fine ,av disabled and update imp files done, after restore box it shows parametre is incorrect ,and then why asks connect to internet can you help me to activate my box |
11-28-2014, 18:00 | #8 (permalink) | |
Now try this: 1. Close ATF Software 2. Go here: C:\AdvanceBox Turbo Flasher\OpenSSL\DLL_32-BIT *** YES 32-BIT *** 3. Copy 2 DLL there named: libeay32.dll ssleay32.dll 4. Paste it here: C:\AdvanceBox Turbo Flasher\ *** YES OVERWRITE FILES *** 5. Run ATF Software -------------- You Xp is 32 or 64Bit?...ok not import these procedure work the same for 64Bit. Can post screen of you ATF NET tabulate with open credits that you have here?, if not have the 49 credits you must need of purchase these first of activate this box. BR | |
11-28-2014, 19:02 | #9 (permalink) |
Member: 2231748 Status: Offline Sonork: whatsapp 09942395196 Thanks Meter: 107 | 11:00:08 : ================================================ 11:00:08 : Advance Turbo Flasher Found 11:00:08 : ================================================ 11:00:08 : Driver Version : 00021000 11:00:08 : Library Version : 00030207 11:00:10 : Box Type : ATF Lightning 11:00:10 : Box Firmware : LogiCore 11.0.00 11:00:10 : Software Version : v11.80 11:00:10 : AdvanceBox SN : F6A473D59D3FABB8FB0B276B 11:01:42 : 11:01:42 : ERROR: Internet Connection Required 11:01:42 : Please Connect to the Internet and Try Again 11:01:42 : 11:01:42 : 11:01:42 : ================================================ 11:01:42 : ATF SOFTWARE IS NOT ACTIVATED ON THIS PC 11:01:42 : Please Activate your ATF Software 11:01:42 : ================================================ 11:01:42 : 11:01:42 : * Follow these Instructions 11:01:42 : 1. Connect this PC to the INTERNET 11:01:42 : 2. Restart ATF Software 11:01:42 : 11:01:42 : 11:01:42 : all works done as your guidence ,Iam useing xp ser3 32bit os, still same problem , internet works fine ,no need to atf -network,i want atfbox actyvation sir, please analize my sn and actyvation |
11-28-2014, 19:15 | #10 (permalink) | |
Member: 1564612 Status: Offline Thanks Meter: 12,343 | @greatselvas, you write: Quote:
Atf light or nitro normally coming with this activated but i want put in exclusion that you problem isn't this, ok? Opent "ATF NET tabulate and click in "LOGIN in your Atf Net" post screen with 49 credits showing, if you Internet is working good must show this, server is full working. You Box not Show "Not Activate" so let me see this screen, after this need to wait @Advance Box for ceck you issue, try how i have write above and post this screen | |
11-28-2014, 19:25 | #11 (permalink) | |
From V.11,00 there's an RSA signing server, nothingh of bad. Just you Follow steps given by ATF software, a activation key will be made on your PC and than you can start using AdvanceBox.exe again This is the solution BR allumts | |
