12-27-2013, 07:16 | #1 (permalink) |
No Life Poster Join Date: Jun 2011 Location: INDIA-TAMILNADU-TUTICORIN Age: 43
Member: 1591177 Status: Offline Thanks Meter: 85 | atf team help what is this problem ????? VBATT Powering Down <<<< VBATT Powering Up >>>> SET VCCIO Level Done SET BSI Load Done Booting Phone... CPU ID Response: A200341100 CPU Type: XG110 2.1B Phone Booted at after First attempt... ************************************************** **** TIME STARTS HERE ************************************************** **** Sending PBL 19456 bytes... PBL Successfully Sent... Sending SBL 65024 bytes... SBL Successfully Sent... Flash Chip Manufacturer: STMicroelectronics Flash Chip Type: M58WR064 64 Mbit (4Mb x 16) NOR Extended Information: Multiple Bank / Burst / 1.8v Processing Image File: C:\Wintesla\RM-769\rm769_007.700 FIRMWARE Image Found... Number of Sections: 03 FIRMWARE Certificate Block Sent Successfully... Processing Section 01 of 03 FIRMWARE Erase Block: 0x00000000~0x0001FFFE Start Erasing... Erasing Please Wait... Block Erase Done... Preparing Data Blocks... Data Size: 24576 bytes Data Checksum: F5BE Uploading Data Blocks to phone... FIRMWARE Data Blocks uploaded to phone... Processing Section 02 of 03 FIRMWARE Erase Block: 0x00800000~0x00BFFFFE Start Erasing... Erasing Please Wait... Block Erase Done... Preparing Data Blocks... Data Size: 4128768 bytes Data Checksum: F633 Uploading Data Blocks to phone... FIRMWARE Data Blocks uploaded to phone... Processing Section 03 of 03 FIRMWARE Erase Block: 0x00C5D000~0x00E5FFFE Start Erasing... Erasing Please Wait... Block Erase Done... Preparing Data Blocks... Data Size: 1697536 bytes Data Checksum: 58AF Uploading Data Blocks to phone... FIRMWARE Data Blocks uploaded to phone... Start Data Verification... (Please wait) Data Verification Successful... Processing Image File: C:\Wintesla\RM-769\rm769_007.700 PPM Image Found... Number of Sections: 03 PPM Certificate Block Sent Successfully... Processing Section 01 of 03 PPM Erase Block: 0x00100000~0x00105FFE ERROR: Erase PPM Block Failed !!! Flashing ERROR but using flash file v 8.10 this error ERROR : PHONE READ INFO FAILED VBATT Powering Down <<<< VBATT Powering Up >>>> SET VCCIO Level Done SET BSI Load Done Booting Phone... CPU ID Response: A200341100 CPU Type: XG110 2.1B Phone Booted at after First attempt... ************************************************** **** TIME STARTS HERE ************************************************** **** Sending PBL 19456 bytes... PBL Successfully Sent... Sending SBL 65024 bytes... SBL Successfully Sent... Flash Chip Manufacturer: STMicroelectronics Flash Chip Type: M58WR064 64 Mbit (4Mb x 16) NOR Extended Information: Multiple Bank / Burst / 1.8v Processing Image File: C:\Wintesla\101\1F1A6922_rm769_008.100 FIRMWARE Image Found... Number of Sections: 03 FIRMWARE Certificate Block Sent Successfully... Processing Section 01 of 03 FIRMWARE Erase Block: 0x00000000~0x0001FFFE Start Erasing... Erasing Please Wait... Block Erase Done... Preparing Data Blocks... Data Size: 24576 bytes Data Checksum: F5BE Uploading Data Blocks to phone... FIRMWARE Data Blocks uploaded to phone... Processing Section 02 of 03 FIRMWARE Erase Block: 0x00800000~0x00BFFFFE Start Erasing... Erasing Please Wait... Block Erase Done... Preparing Data Blocks... Data Size: 4128768 bytes Data Checksum: 676D Uploading Data Blocks to phone... FIRMWARE Data Blocks uploaded to phone... Processing Section 03 of 03 FIRMWARE Erase Block: 0x00C5D000~0x00E5FFFE Start Erasing... Erasing Please Wait... Block Erase Done... Preparing Data Blocks... Data Size: 1697536 bytes Data Checksum: 2FCD Uploading Data Blocks to phone... FIRMWARE Data Blocks uploaded to phone... Start Data Verification... (Please wait) Data Verification Successful... Processing Image File: C:\Wintesla\101\4BAEE741_rm769_008.10mo PPM Image Found... Number of Sections: 01 PPM Certificate Block Sent Successfully... Processing Section 01 of 01 PPM Erase Block: 0x00100000~0x00613BFE Start Erasing... Erasing Please Wait... Block Erase Done... Preparing Data Blocks... Data Size: 5323776 bytes Data Checksum: 69C9 Uploading Data Blocks to phone... PPM Data Blocks uploaded to phone... Start Data Verification... (Please wait) Data Verification Successful... Processing Image File: C:\Wintesla\101\D93FE908_rm7690_nai08.10mo_nlt CONTENT Image Found... Number of Sections: 01 CONTENT Certificate Block Sent Successfully... Processing Section 01 of 01 CONTENT Erase Block: 0x00E60000~0x00F49FFE Start Erasing... Erasing Please Wait... Block Erase Done... Preparing Data Blocks... Data Size: 958464 bytes Data Checksum: 53AF Uploading Data Blocks to phone... CONTENT Data Blocks uploaded to phone... Start Data Verification... (Please wait) Data Verification Successful... Exit Flash Mode Done... Time Elapse : 00:04:26 ************************************************** **** You must Factory Reset the phone to enable the ringtones and other customized settings to work ************************************************** **** Waiting For Phone to go Online... 5, 4, 3, 2, 1... ERROR : PHONE READ INFO FAILED phone status dead no water lock pl help me how to solve |
12-27-2013, 10:42 | #2 (permalink) |
No Life Poster Join Date: Dec 2007
Member: 651945 Status: Offline Thanks Meter: 20,118 | @kathirmobiles Your first logs shows that you loaded same file for MCU and for PPM... Of course this will cause an error. Processing Image File: C:\Wintesla\RM-769\rm769_007.700 Your Second Logs shows that your flash files are probably corrupted. Download Correct Flash Files Here: RM-769 - Download - 4shared |
12-29-2013, 05:28 | #3 (permalink) | |
Member: 1591177 Status: Offline Thanks Meter: 85 | Quote:
12-29-2013, 14:48 | #4 (permalink) |
Member: 651945 Status: Offline Thanks Meter: 20,118 | @kathirmobiles Then phone problem is not related to firmware. It can be related to PM imei simlock... or it can also be hardware problem. No solution on software side. |
