04-04-2015, 16:57 | #1 (permalink) |
Freak Poster Join Date: Sep 2007
Member: 592531 Status: Offline Sonork: 100.1641625 Thanks Meter: 17 | Atf team please help me ATF Box is not in USB 2.0 Mode ============================================== * Go to "Product Support" tab and click the * "Restore Box" Button to fix the Box Firmware ** If Problem is Not Solved... 1. Make Sure you are NOT using USB HUBS 2. Make Sure your USB port is USB 2.0 3. Make Sure you are using the latest Drivers *** If Problem is STILL Not Solved 1. Use a THICKER USB Cable 2. Connect ATF Directly to the Root USB Port 3. Uninstall Drivers, Reboot PC, Reinstall **** If you are still Stuck... 1. Search your entire PC for "ftdibus.sys 2. Delete all "ftdibus.sys" files you find 3. Reboot PC... 4. Disconnect ATF Box and all Boxes from PC 5. Run C:\AdvanceBox Turbo Flasher\Driver\Remove_ATF_Drivers\Remove_ATF_Drive rs.bat 6. ReInstall ATF Software 7. Connect ATF Box Only to your USB Port 8. Install the Correct Drivers ************************************************ INIT : FAILED , CHECK YOUR BOX FIRMWARE ************************************************ |
04-04-2015, 19:54 | #2 (permalink) |
No Life Poster Join Date: Mar 2009 Location: Kathmandu,Nepal Age: 46
Member: 983663 Status: Offline Sonork: 100.1623270 Thanks Meter: 551 | 12.10 full install and check ATF Offcial Support Area > |
04-05-2015, 07:52 | #4 (permalink) | |
No Life Poster Join Date: Feb 2010 Location: Koronadal City, Ph/Riyadh, KSA
Member: 1240161 Status: Offline Thanks Meter: 159 | You don't need anybody's help bro., instructions were already given. Just do the following steps.. Quote:
04-05-2015, 13:59 | #6 (permalink) |
Freak Poster Join Date: Jul 2011 Location: CABA, Argentina
Member: 1607814 Status: Offline Sonork: 100.1658107 Thanks Meter: 10 | Use the rear ports on the pc , a good typical wire Blackberry, enables the BIOS from the USB 2.0 ports and give the FullSpeed or appearing to you faster. |
