06-26-2015, 00:34 | #1 (permalink) |
Crazy Poster Join Date: Feb 2009 Location: fatehpur up india
Member: 969145 Status: Offline Thanks Meter: 19 | atf team pls solv this errer uploading images Default language ID 0x0409, LR 14 JTAG Interface Connected, S/N 0x89DF5120 Resetting and Exploring JTAG chain...No Devices found in Chain! Loading AFP (Please Wait)...OK AFP revision 4, compiled 9/28/2014 1:16:00 PM ================================================== ======== Phone Type : Nokia XL [RM-1030] CPU Type : Qualcomm MSM8225 Storage TYpe : eMMC 4GB Boot Package : Full Boot Restore Firmware Version: 1.2.3.2 ================================================== ======== 1. Make sure JTAG Connection is 100% OK 2. Always Disconnect the Phone BATTERY 3. Connect USB Cable to Phone 4. Connect RJ-45 JTAG Cable to ATF Box 5. Select the Correct Phone Type RM-XXX 6. Use RESET JTAG button to check the JTAG Connection 7. Click RESTORE BOOT button to Start Boot Repairs ---------------------------------------------------------- Resetting and Exploring JTAG chain...1 Device(s) Device #1 ID 0x007700E1 IR4 Restore Boot... Waiting for Device Connection 20 second(s)...OK Resetting and Exploring JTAG chain...OK Halting Core...Retry Resetting and Exploring JTAG chain...OK Halting Core...OK Initializing Device...OK Detecting eMMC #1 ID...1501004A3558574D420175CCB63E31ED Flash Description: Samsung J5XWMB, 3.64 GiB, SN 75CCB63E, Mar 1998 Partition Config: Boot from USER, Boot ACK OFF (0x38) Boot Bus Config: x1 SDR, Bus Reset to x1 (0x00) Testing Device Memory...OK Sending Flash Loader...Memory Write Error, Access to Memory Not Completed! Resetting and Exploring JTAG chain...1 Device(s) Device #1 ID 0x007700E1 IR4 ======================================= || FLASHBUS EXTENSION || || ======= ======= || || |==/ \==| | | || || | | (O) (O) (O) | | || || | | |==\ /==| || || ======= ======= || || 8 1 1 10 || ======================================= FLASHBUS JTAG PINOUT 1 - VBATT 4.0V (Optional) 2 - 3 - TRST + SRST 4 - TDO 5 - TDI 6 - TCK 7 - GROUND 8 - TMS Resetting and Exploring JTAG chain...1 Device(s) Device #1 ID 0x007700E1 IR4 Restore Boot... Waiting for Device Connection 20 second(s)...OK Resetting and Exploring JTAG chain...OK Halting Core...Retry Resetting and Exploring JTAG chain...OK Halting Core...OK Initializing Device...OK Detecting eMMC #1 ID...1501004A3558574D420175CCB63E31ED Flash Description: Samsung J5XWMB, 3.64 GiB, SN 75CCB63E, Mar 1998 Partition Config: Boot from USER, Boot ACK OFF (0x38) Boot Bus Config: x1 SDR, Bus Reset to x1 (0x00) Testing Device Memory...OK Sending Flash Loader...OK (91932 Op/Sec) Restoring Partition #1...OK Restoring Partition #2...Flash Write Error at 0x00000200, Loader Error, Code 0x76 Please send this log and "..\Logs\.log" file to support! Resetting and Exploring JTAG chain...1 Device(s) Device #1 ID 0x007700E1 IR4 Resetting and Exploring JTAG chain...1 Device(s) Device #1 ID 0x007700E1 IR4 Resetting and Exploring JTAG chain...No Devices found in Chain! Resetting and Exploring JTAG chain...No Devices found in Chain! Resetting and Exploring JTAG chain...No Devices found in Chain! Resetting and Exploring JTAG chain...No Devices found in Chain! Resetting and Exploring JTAG chain...No Devices found in Chain! Resetting and Exploring JTAG chain...No Devices found in Chain! Restore Boot... Waiting for Device Connection 20 second(s)...OK Resetting and Exploring JTAG chain...OK Halting Core...Retry Resetting and Exploring JTAG chain...OK Halting Core...OK Initializing Device...OK Detecting eMMC #1 ID...1501004A3558574D420175CCB63E31ED Flash Description: Samsung J5XWMB, 3.64 GiB, SN 75CCB63E, Mar 1998 Partition Config: Boot from USER, Boot ACK OFF (0x38) Boot Bus Config: x1 SDR, Bus Reset to x1 (0x00) Testing Device Memory...OK Sending Flash Loader...OK (91929 Op/Sec) Restoring Partition #1...OK Restoring Partition #2...Flash Write Error at 0x00000200, Loader Error, Code 0x76 Please send this log and "..\Logs\.log" file to support! Restore Boot... Waiting for Device Connection 20 second(s)...OK Resetting and Exploring JTAG chain...OK Halting Core...OK Initializing Device...Init Write Error at line 2, Access to Memory Not Completed! Restore Boot... Waiting for Device Connection 20 second(s)...OK Resetting and Exploring JTAG chain...OK Halting Core...Retry Resetting and Exploring JTAG chain...OK Halting Core...OK Initializing Device...OK Detecting eMMC #1 ID...1501004A3558574D420175CCB63E31ED Flash Description: Samsung J5XWMB, 3.64 GiB, SN 75CCB63E, Mar 1998 Partition Config: Boot from USER, Boot ACK OFF (0x38) Boot Bus Config: x1 SDR, Bus Reset to x1 (0x00) Testing Device Memory...OK Sending Flash Loader...OK (91417 Op/Sec) Restoring Partition #1...OK Restoring Partition #2...Flash Write Error at 0x00000200, Loader Error, Code 0x76 Please send this log and "..\Logs\.log" file to support! |
06-26-2015, 03:11 | #2 (permalink) |
No Life Poster Join Date: Dec 2007
Member: 651945 Status: Offline Thanks Meter: 20,118 | @saurabh singh You eMMC appears to be READ ONLY Mode. First Try latest ATF JTAG Software which come from FULL Installer 12.34 here: ATF_v12.34_Full_Installer.rar If you get same error with newer ATFJ.exe, then you can only repair this phone via eMMC Connection. You need to connect this via eMMC TOOL and show me logs from eMMC Tool. For eMMC PINOUT, check this post: http://forum.gsmhosting.com/vbb/10399850-post2.html Download link for Nokia XL can be found there. Load it in ATF Software "ATF Plus" ---> "eMMC Tool" via "WRITE" button. It will show you pinout. |
06-26-2015, 03:11 | #3 (permalink) |
06-26-2015, 04:12 | #4 (permalink) |
10-20-2015, 12:02 | #5 (permalink) |
Freak Poster Join Date: Sep 2012 Location: Loading! Age: 34
Member: 1813502 Status: Offline Sonork: 100.1623430 Thanks Meter: 182 | s7562 boot repair error Hi ATF supporters I am trying to boot repair Samsung galaxy dous (S7562) but during boot restore it is giving some error like this |
