08-06-2013, 16:45 | #2 (permalink) |
No Life Poster Join Date: Dec 2006 Location: Karachi, Pakistan Age: 33
Member: 643472 Status: Offline Sonork: 100.96901 Thanks Meter: 16,589 | Hi, well, it was fixed in version 10.00. We will look into this again and fix if needed. You can use Repair IMEI big standalone button now to repair DCT4 IMEIs. BR |
08-06-2013, 21:04 | #3 (permalink) | |
No Life Poster Join Date: Jun 2009 Location: SouthAmericaUnlockers Age: 52
Member: 1057178 Status: Offline Sonork: Kfe~Labs Co.- Thanks Meter: 568 | Quote:
thnks in advance polaco | |
08-07-2013, 07:05 | #4 (permalink) | |
Freak Poster Join Date: Mar 2012 Location: somewhere in world Age: 37
Member: 1738848 Status: Offline Sonork: 100.1640328 Thanks Meter: 505 | Quote:
bro u r right imei showing good in phone but the problem is phone going sw off in 30 sec as i know it want to write good imei ( from server) if u have other solution then plz reply hear... | |
08-07-2013, 07:11 | #5 (permalink) | |
No Life Poster Join Date: Apr 2007 Location: M W Balasore,Odisha,INDIA Age: 52
Member: 492222 Status: Offline Sonork: 100.1594126 Thanks Meter: 10,377 | Quote:
Br - srinibas | |
08-07-2013, 07:33 | #6 (permalink) | |
bro all ready repair most off handset without change uem..just erase write full flash write good rpl write good pm and unlock..any way server is now ok my problem solved | |
08-07-2013, 17:04 | #7 (permalink) | |
Your Problem (for all DCt4&++) is buy a simple Clip RSA (any Model) and, for know if you have a damage UEM, Just press Read UEM, is it ok, Just Write a good PM With ATF Box Br Polaco | |
08-11-2013, 00:31 | #10 (permalink) |
No Life Poster Join Date: Nov 2012 Location: Ek India Happy Wala.. :-)
Member: 1834832 Status: Offline Thanks Meter: 1,450 | Help me Atf team about nokia 3100 Boot Check, Please wait... MCUID Response ------------------------------------- MessageID : 92 msbUPP_ID : 11 lsbUPP_ID : 20 ------------------------------------- Boot OK Boot File: C:\AdvanceBox Turbo Flasher\Nokia\DCT4_Loader\u_2nd.fia DataLen : 000009D8 Secondary Loader Sent... Boot OK! MCU_CONFIGURATION_RESPONSE_DCT4_MUL3 DCT4 Mess 9F MUL3 Mess 9F TransMode : 01 NumFlash : 02 DevAddr0 : 01 ManuId0 : 00EC - SAMSUNG (SEC) DevId0 : 22FA - K8S6415ETA ExtId0 : 0000 RevId0 : 2811 SectorSize0: 10 Reserved0 : 00 DevAddr1 : 02 ManuId1 : 0000 - Flash DevId1 : 0001 - not used ExtId1 : 0000 RevId1 : 0000 SectorSize1: 00 Reserved1 : 00 ExtBUSC : AD 7E B6 1A 1B BE 0B E2 7D 58 6B E4 DB EE 65 14 CheckSum : 80 ReceiveConfigurationResponse_DCT4 - FLS1_NO_ERROR SearchForBootstrap_DCT4 : No Error Algo Match File : C:\AdvanceBox Turbo Flasher\Nokia\DCT4_Loader\uh_amd.fia ALGO SENT.. Perform AUTHENTICATION.. MSID: 8411B8C7E6EE4A1D27F40ACDF1 DecodedMSID: 843E4EBAE900895B4DAA000000 EncodedFAID: 9636298850BA8CB04033239F Authentication : SUCCESSFULL BB_RESTART : 07 FF MCURestart : SUCCESS Done! MCU: V 06.31 25-11-05 RH-19 (c) Nokia. IMEI: ??????????????? Model : Nokia 3100 MCU SW Version : V 06.31 25-11-05 RH-19 (c) Nokia. UEM Version : 8 UPP Version : 4384 RFIC Version : 0358 DSP Version : N5.20 LCD Version : X4 ********** SIMLOCK INFO ********** CONFIG_DATA : 5555555555555555 PROFILE_BITS : 0000000000000000 ASIC : 2 PROVIDER : Unknown Provider Unable to read SP Data.. ST_SIMLOCK_TEST : FAILED ST_LCD_TEST : PASSED SECURITY_CODE : 12345 MASTER_CODE : 1370355423 PHONE_MODE : TEST here is log when try to rebuild imei process show done bt not repair...when i try to unlock the phone also came error plez help me......... unlock log Generating Simlock Table... Uploading Default Simlock Table... ERROR: Wrong Simlock Table Data then i use sl repair.... Generating Simlock Table... Uploading Default Simlock Table... ERROR: Wrong Simlock Table Data now imei rebuild/repair standalone log ================================================ STEP 1 of 3: Read UEM IMEI ================================================ Boot Check, Please wait... MCUID Response ------------------------------------- MessageID : 92 msbUPP_ID : 11 lsbUPP_ID : 20 ------------------------------------- Boot OK Boot File: C:\AdvanceBox Turbo Flasher\Nokia\DCT4_Loader\u_2nd.fia DataLen : 000009D8 Secondary Loader Sent... Boot OK! MCU_CONFIGURATION_RESPONSE_DCT4_MUL3 DCT4 Mess 9F MUL3 Mess 9F TransMode : 01 NumFlash : 02 DevAddr0 : 01 ManuId0 : 00EC - SAMSUNG (SEC) DevId0 : 22FA - K8S6415ETA ExtId0 : 0000 RevId0 : 2811 SectorSize0: 10 Reserved0 : 00 DevAddr1 : 02 ManuId1 : 0000 - Flash DevId1 : 0001 - not used ExtId1 : 0000 RevId1 : 0000 SectorSize1: 00 Reserved1 : 00 ExtBUSC : AD 7E B6 1A 1B BE 0B E2 7D 58 6B E4 DB EE 65 14 CheckSum : 80 ReceiveConfigurationResponse_DCT4 - FLS1_NO_ERROR SearchForBootstrap_DCT4 : No Error Algo Match File : C:\AdvanceBox Turbo Flasher\Nokia\DCT4_Loader\uh_amd.fia ALGO SENT.. Perform AUTHENTICATION.. MSID: 8411B8C7E6EE4A1D27F40ACDF1 DecodedMSID: 843E4EBAE900895B4DAA000000 EncodedFAID: 9636298850BA8CB04033239F Authentication : SUCCESSFULL VBATT Powering Down <<<< VBATT Powering Up >>>> SET VCCIO Level Done SET BSI Load Done MCURestart : SUCCESS Done! ================================================ STEP 2 of 3: Calculate RPL Data < Stand Alone RPL Calculation in Progress > < This will take upto 20 Seconds > ================================================ DCT4 RPL Calculation Successful ================================================ STEP 3 of 3: Write RPL Data to Phone ================================================ Boot Check, Please wait... MCUID Response ------------------------------------- MessageID : 92 msbUPP_ID : 11 lsbUPP_ID : 20 ------------------------------------- Boot OK Boot File: C:\AdvanceBox Turbo Flasher\Nokia\DCT4_Loader\u_2nd.fia DataLen : 000009D8 Secondary Loader Sent... Boot OK! MCU_CONFIGURATION_RESPONSE_DCT4_MUL3 DCT4 Mess 9F MUL3 Mess 9F TransMode : 01 NumFlash : 02 DevAddr0 : 01 ManuId0 : 00EC - SAMSUNG (SEC) DevId0 : 22FA - K8S6415ETA ExtId0 : 0000 RevId0 : 2811 SectorSize0: 10 Reserved0 : 00 DevAddr1 : 02 ManuId1 : 0000 - Flash DevId1 : 0001 - not used ExtId1 : 0000 RevId1 : 0000 SectorSize1: 00 Reserved1 : 00 ExtBUSC : AD 7E B6 1A 1B BE 0B E2 7D 58 6B E4 DB EE 65 14 CheckSum : 80 ReceiveConfigurationResponse_DCT4 - FLS1_NO_ERROR SearchForBootstrap_DCT4 : No Error Algo Match File : C:\AdvanceBox Turbo Flasher\Nokia\DCT4_Loader\uh_amd.fia ALGO SENT.. Writing RPL DATA... (Wait Upto 15 Seconds) RPL Write Status: Successful BB_RESTART : 07 FF MCURestart : SUCCESS Done! then also imei not repair........ imei repair via server rpl........ Connecting to Server... Connection GOOD! Sending data to server... SERVER_ACK_MESSAGE: DCT4 RPL SERVER OFFLINE DCT4_RPL_CREDITS : 50 Credits for Today help me team...... |
