10-04-2018, 18:03 | #1 (permalink) |
No Life Poster Join Date: Jan 2006 Location: algeria
Member: 217891 Status: Offline Thanks Meter: 237 | ATF team try make all free at ur tool |
The Following 3 Users Say Thank You to moh_boulk17 For This Useful Post: |
10-09-2018, 09:46 | #4 (permalink) |
No Life Poster Join Date: Jun 2010 Location: Russia Age: 44
Member: 1331464 Status: Offline Thanks Meter: 206 | I have atf box and paid for all. Repair emmc is free solution you underastand it. Jtag paid and atf network paid. If somebody want free he can use usb cable and cracked best. |
10-16-2018, 11:59 | #5 (permalink) | |
Freak Poster Join Date: Feb 2008 Location: Indonesia
Member: 713923 Status: Offline Thanks Meter: 38 | Quote:
ATF jtag free bro,iam always use emmc tool for repair direct emmc this log Samsung j110G emmc : ================================================== ==== ================================================== ==== eMMC Test Point Connection Module ================================================== ==== ================================================== ==== 1. DO NOT USE THE PHONE"S BATTERY 2. Connect the Soldered TP Connections to ATF Box 3. Disconnect the USB Cable and Wait until the the ATF Software will tell you to Connect the USB. Interface Reset OK! eMMC Access Type: SECTOR MODE eMMC Supported Voltage Range: 3.5-3.6V, 3.4-3.5V, 3.3-3.4V, 3.2-3.3V, 3.1-3.2V 3.0-3.1V, 2.9-3.0V, 2.8-2.9V, 2.7-2.8V, 1.9-2.0V CID : 65646F4D204D4F52128100000615444D CSD : D07FFF320F59007FF6DB80001E40001D eMMC Boot Information Revision 1.0 (for MMC v4.0) BOOT PARTITION : NOT BOOT ENABLED PARTITION ACCESS : R/W USER PARTITION PERM_BOOT_CFG_PROT : DISABLED PWR_BOOT_CFG_PROT : DISABLED BOOT MODE : x1 SINGLE DATA RATE + LOW SPEED RESET BUS WIDTH : ENABLED eMMC FirmW UPDATE : DISABLED EMMC CACHE SIZE : 0 KB SUPER PAGE SIZE : 0 KB HC ERASE GROUP SIZE: 0 KB USER AREA SIZE : 0 BYTES BOOT PARTITION SIZE: 0 KB RPMB PARTITION SIZE: 0 KB eMMC Device Information Manufacturer ID: 65 Device Type : Removable Card Application ID : 6F Product Name : M MOR Product Rev : 8.1 Product SN : 00000615 Manufactured : January 2001 Card Specific Data CSD_STRUCTURE : Extended SPEC_VERS : Version 4.1/4.2/4.3 TAAC : 8000 ns TRAN_SPEED : 4000000 KHz READ_BL_LEN : 512 Bytes WP_GRP_ENABLE : NO WRITE_BL_LEN : 512 Bytes CONTENT_PROT_APP : NO PERM_WRITE_PROTECT: NO TMP_WRITE_PROTECT : NO Extended CSD Saved: 65646F4D204D4F52128100000615444D.ext_csd Backup Directory: C:\X\AdvanceBox Turbo Flasher\eMMC\EXT_CSD\ | |
10-16-2018, 21:07 | #6 (permalink) | |
Member: 217891 Status: Offline Thanks Meter: 237 | Quote:
and atf jtag is free ? | |
