05-02-2011, 09:06 | #1 (permalink) |
Crazy Poster Join Date: Oct 2006
Member: 361843 Status: Offline Thanks Meter: 4 | ATF TEEM Nokia x3 ERROR: DCC File Mismatched! need help. IMEI: 357977xxxxxxxxxxx Model : Nokia X3-00 Product Serial Number: DKL240989 Product Code : 0581259 Module Code : 0204201 Basic Production Code: 0578316 Default SN Type : 0 MCU SW Version : V 03.60 21-10-09 RM-540 (c) Nokia V BT MCM Version : 1673-46034 PPM Version : V 03.60 21-10-09 RM-540 (c) Nokia HW Version : 1000 RFIC Version : 0831 DSP Version : ICPR91_09w39_RC LCD Version : SEIKO Content Pack Version : Content: v_0581259 V 03.60 21-10-09 RM-540 (c) Nokia AHNE Version : 41 Retu Version : 40 Tahvo Version : 00 ******** Reading SimLock ******** CONFIG KEY: 0000000000000000 PROVIDER KEY: 2440700000000000 Provider : AT&T;U.S.A. (3650) Counters : 0/3 , 0/10 Block [1] 1:Open 2:Open 3:Open 4:Open 5:Open Block [2] 1:Open 2:Open 3:Open 4:Open 5:Open Block [3] 1:Open 2:Open 3:Open 4:Open 5:Open Block [4] 1:Open 2:Open 3:Open 4:Open 5:Open Block [5] 1:Open 2:Open 3:Open 4:Open 5:Open Block [6] 1:Open 2:Open 3:Open 4:Open 5:Open Block [7] 1:Open 2:Open 3:Open 4:Open 5:Open SP Lock Status : Not Locked SIMLOCK_TYPE : PA_SL3 (15-digit NCK) SIMLOCK_TEST : PASSED SECURITY_TEST : PASSED SECURITY_CODE : 12345 PHONE_MODE : TEST MODE ================================================ Dynamic Camera Configuration ================================================ DCC ID : NI00IIIIRR03095A1F87 DCC Ver: XXXXXX ERROR: DCC File Mismatched! Required DCC File: NI00IIIIRR03095A1F87 Write the correct DCC to Fix the Problem after I change ic cpu + flash is camera ready. please given me dcc file. |
05-02-2011, 09:37 | #3 (permalink) |
No Life Poster Join Date: Feb 2005 Location: MX-KEY is the BEST NOKIA TOOL Age: 50
Member: 116314 Status: Offline Thanks Meter: 147 | install full package same version file and u will have dcc file |
The Following User Says Thank You to rajufzr For This Useful Post: |
05-02-2011, 09:55 | #4 (permalink) |
No Life Poster Join Date: Dec 2006 Location: Karachi, Pakistan Age: 33
Member: 643472 Status: Offline Sonork: 100.96901 Thanks Meter: 16,589 | Hello. All latest DCC files are available there: C:\AdvanceBox Turbo Flasher\Nokia\DCC\Common BR |
The Following User Says Thank You to ..::Angel::.. For This Useful Post: |
05-02-2011, 11:12 | #5 (permalink) |
Member: 361843 Status: Offline Thanks Meter: 4 | after flash phone with ver 3.60 by usb. I click Tuning anh Maintenace > camera config click Query Dynamic camera configuartion> select C:\AdvanceBox Turbo Flasher\Nokia\DCC\Common\NI00IIIIRR0306150018.dcc but ERROR: DCC File Mismatched! here log: MCU: V 03.60 21-10-09 RM-540 (c) Nokia IMEI: 35797703xxxxxx Model : Nokia X3-00 Product Serial Number: DKL240989 Product Code : 0581259 Module Code : 0204201 Basic Production Code: 0578316 Default SN Type : 0 MCU SW Version : V 03.60 21-10-09 RM-540 (c) Nokia V BT MCM Version : 1673-46034 PPM Version : V 03.60 21-10-09 RM-540 (c) Nokia HW Version : 1000 RFIC Version : 0831 DSP Version : ICPR91_09w39_RC LCD Version : SEIKO Content Pack Version : Content: v_0581259 V 03.60 21-10-09 RM-540 (c) Nokia AHNE Version : 41 Retu Version : 40 Tahvo Version : 00 ******** Reading SimLock ******** CONFIG KEY: 0000000000000000 PROVIDER KEY: 2440700000000000 Provider : AT&T;U.S.A. (3650) Counters : 0/3 , 0/10 Block [1] 1:Open 2:Open 3:Open 4:Open 5:Open Block [2] 1:Open 2:Open 3:Open 4:Open 5:Open Block [3] 1:Open 2:Open 3:Open 4:Open 5:Open Block [4] 1:Open 2:Open 3:Open 4:Open 5:Open Block [5] 1:Open 2:Open 3:Open 4:Open 5:Open Block [6] 1:Open 2:Open 3:Open 4:Open 5:Open Block [7] 1:Open 2:Open 3:Open 4:Open 5:Open SP Lock Status : Not Locked SIMLOCK_TYPE : PA_SL3 (15-digit NCK) SIMLOCK_TEST : PASSED SECURITY_TEST : PASSED SECURITY_CODE : 12345 PHONE_MODE : TEST MODE ================================================ Dynamic Camera Configuration ================================================ DCC ID : NI00IIIIRR0306150018 DCC Ver: XXXXXX ERROR: DCC File Mismatched! Required DCC File: NI00IIIIRR0306150018 Write the correct DCC to Fix the Problem You selected >>> C:\AdvanceBox Turbo Flasher\Nokia\DCC\Common\NI00IIIIRR0306150018_0030 01.dcc Uploading to phone... Successfully Uploaded DCC Data Rebooting Phone... (Wait for 9 Seconds) VBATT OFF... VBATT ON Setting VBATT Done!... MCU: V 03.60 21-10-09 RM-540 (c) Nokia IMEI: 357977039290471 Model : Nokia X3-00 Product Serial Number: DKL240989 Product Code : 0581259 Module Code : 0204201 Basic Production Code: 0578316 Default SN Type : 0 MCU SW Version : V 03.60 21-10-09 RM-540 (c) Nokia V BT MCM Version : 1673-46034 PPM Version : V 03.60 21-10-09 RM-540 (c) Nokia HW Version : 1000 RFIC Version : 0831 DSP Version : ICPR91_09w39_RC LCD Version : SEIKO Content Pack Version : Content: v_0581259 V 03.60 21-10-09 RM-540 (c) Nokia AHNE Version : 41 Retu Version : 40 Tahvo Version : 00 ******** Reading SimLock ******** CONFIG KEY: 0000000000000000 PROVIDER KEY: 2440700000000000 Provider : AT&T;U.S.A. (3650) Counters : 0/3 , 0/10 Block [1] 1:Open 2:Open 3:Open 4:Open 5:Open Block [2] 1:Open 2:Open 3:Open 4:Open 5:Open Block [3] 1:Open 2:Open 3:Open 4:Open 5:Open Block [4] 1:Open 2:Open 3:Open 4:Open 5:Open Block [5] 1:Open 2:Open 3:Open 4:Open 5:Open Block [6] 1:Open 2:Open 3:Open 4:Open 5:Open Block [7] 1:Open 2:Open 3:Open 4:Open 5:Open SP Lock Status : Not Locked SIMLOCK_TYPE : PA_SL3 (15-digit NCK) SIMLOCK_TEST : PASSED SECURITY_TEST : PASSED SECURITY_CODE : 12345 PHONE_MODE : TEST MODE ================================================ Dynamic Camera Configuration ================================================ DCC ID : NI00IIIIRR0306150018 DCC Ver: XXXXXX ERROR: DCC File Mismatched! Required DCC File: NI00IIIIRR0306150018 Write the correct DCC to Fix the Problem You selected >>> C:\AdvanceBox Turbo Flasher\Nokia\DCC\Common\NI00IIIIRR0306150018_0030 01.dcc Uploading to phone... Successfully Uploaded DCC Data Rebooting Phone... (Wait for 9 Seconds) VBATT OFF... VBATT ON Setting VBATT Done!... MCU: V 03.60 21-10-09 RM-540 (c) Nokia IMEI: 357977039290471 Model : Nokia X3-00 Product Serial Number: DKL240989 Product Code : 0581259 Module Code : 0204201 Basic Production Code: 0578316 Default SN Type : 0 MCU SW Version : V 03.60 21-10-09 RM-540 (c) Nokia V BT MCM Version : 1673-46034 PPM Version : V 03.60 21-10-09 RM-540 (c) Nokia HW Version : 1000 RFIC Version : 0831 DSP Version : ICPR91_09w39_RC LCD Version : SEIKO Content Pack Version : Content: v_0581259 V 03.60 21-10-09 RM-540 (c) Nokia AHNE Version : 41 Retu Version : 40 Tahvo Version : 00 ******** Reading SimLock ******** CONFIG KEY: 0000000000000000 PROVIDER KEY: 2440700000000000 Provider : AT&T;U.S.A. (3650) Counters : 0/3 , 0/10 Block [1] 1:Open 2:Open 3:Open 4:Open 5:Open Block [2] 1:Open 2:Open 3:Open 4:Open 5:Open Block [3] 1:Open 2:Open 3:Open 4:Open 5:Open Block [4] 1:Open 2:Open 3:Open 4:Open 5:Open Block [5] 1:Open 2:Open 3:Open 4:Open 5:Open Block [6] 1:Open 2:Open 3:Open 4:Open 5:Open Block [7] 1:Open 2:Open 3:Open 4:Open 5:Open SP Lock Status : Not Locked SIMLOCK_TYPE : PA_SL3 (15-digit NCK) SIMLOCK_TEST : PASSED SECURITY_TEST : PASSED SECURITY_CODE : 12345 PHONE_MODE : TEST MODE ================================================ Dynamic Camera Configuration ================================================ DCC ID : NI00IIIIRR0306150018 DCC Ver: XXXXXX ERROR: DCC File Mismatched! Required DCC File: NI00IIIIRR0306150018 Write the correct DCC to Fix the Problem You selected >>> C:\AdvanceBox Turbo Flasher\Nokia\DCC\Common\NI00IIIIRR0306150018_0030 01.dcc Uploading to phone... Successfully Uploaded DCC Data Rebooting Phone... (Wait for 9 Seconds) VBATT OFF... VBATT ON Setting VBATT Done!... MCU: V 03.60 21-10-09 RM-540 (c) Nokia IMEI: 357977039290471 Model : Nokia X3-00 Product Serial Number: DKL240989 Product Code : 0581259 Module Code : 0204201 Basic Production Code: 0578316 Default SN Type : 0 MCU SW Version : V 03.60 21-10-09 RM-540 (c) Nokia V BT MCM Version : 1673-46034 PPM Version : V 03.60 21-10-09 RM-540 (c) Nokia HW Version : 1000 RFIC Version : 0831 DSP Version : ICPR91_09w39_RC LCD Version : SEIKO Content Pack Version : Content: v_0581259 V 03.60 21-10-09 RM-540 (c) Nokia AHNE Version : 41 Retu Version : 40 Tahvo Version : 00 ******** Reading SimLock ******** CONFIG KEY: 0000000000000000 PROVIDER KEY: 2440700000000000 Provider : AT&T;U.S.A. (3650) Counters : 0/3 , 0/10 Block [1] 1:Open 2:Open 3:Open 4:Open 5:Open Block [2] 1:Open 2:Open 3:Open 4:Open 5:Open Block [3] 1:Open 2:Open 3:Open 4:Open 5:Open Block [4] 1:Open 2:Open 3:Open 4:Open 5:Open Block [5] 1:Open 2:Open 3:Open 4:Open 5:Open Block [6] 1:Open 2:Open 3:Open 4:Open 5:Open Block [7] 1:Open 2:Open 3:Open 4:Open 5:Open SP Lock Status : Not Locked SIMLOCK_TYPE : PA_SL3 (15-digit NCK) SIMLOCK_TEST : PASSED SECURITY_TEST : PASSED SECURITY_CODE : 12345 PHONE_MODE : TEST MODE ================================================ Dynamic Camera Configuration ================================================ DCC ID : NI00IIIIRR0306150018 DCC Ver: XXXXXX ERROR: DCC File Mismatched! Required DCC File: NI00IIIIRR0306150018 Write the correct DCC to Fix the Problem I need you help thanks ..::Angel::.. |
05-02-2011, 11:27 | #6 (permalink) |
No Life Poster Join Date: Dec 2007
Member: 651945 Status: Offline Thanks Meter: 20,118 | @nmobile What version of ATF software are you using? Go to Settings and remove check on Automatically Repair DCC... Then, connect phone and select "Force Write DCC" before writing the DCC FILE. B.R. |
The Following User Says Thank You to Advance-Box For This Useful Post: |
need eeprom photo???? | mobileinfo | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 0 | 05-26-1999 11:35 |
