03-14-2010, 06:12 | #1 (permalink) |
No Life Poster Join Date: Dec 2007
Member: 651945 Status: Offline Thanks Meter: 20,118 | || ATF || Tips and Tricks Volume I If the phone is alive (non dead phone) you can: Use "Reset Box" to Force the phone into Local Mode or Use "BUSCheck" to Force the phone into Test Mode ||| Tip # 2 ||| If your Turbo Flashing stops or hangs below 50% when you try to flash BIG flash files (5800, N95, N97 etc...) You can edit AdvanceBox.ini and change the setting: ;----------------------------- BB5 SETTINGS -------------------------------- [BB5] NoOfRefresh_BeforeData=3 NoOfRefresh_AfterData=1 change to: ;----------------------------- BB5 SETTINGS -------------------------------- [BB5] NoOfRefresh_BeforeData=10 NoOfRefresh_AfterData=10 However, using "10" and "10" settings will make your flashing time 2-3 seconds slower than before on all phones. ||| Tip # 3 ||| The Right-Click mouse button now works if you want to copy+paste your logs manually from the software into the forum. The Button on the Lower Right Corner will take Screenshots of the software and save it inside the "\Logs\Captured\" directory. |
The Following 13 Users Say Thank You to Advance-Box For This Useful Post: |
04-04-2010, 18:13 | #2 (permalink) |
Freak Poster Join Date: Oct 2005 Location: China
Member: 191046 Status: Offline Sonork: 100.84351 Thanks Meter: 7 | but support is not working for me . not possible to download flash files http://forum.gsmhosting.com/vbb/f609...wnload-955507/ |
Cell Phone Tips and Tricks - Students and Cell Phones | murtaza_nns | Off Topic Zone | 3 | 10-05-2009 21:59 |
My tips and tricks and questions for N73 6280 etc | pearsonjohnboy | BB5BOX | 7 | 03-06-2008 14:58 |
Ah no, its dummy S40 phone and unfortunately S60 tip and trick doesn’t works on that | apocalypso | Nokia Base Band 5 ( BB-5 ) | 0 | 06-25-2007 14:05 |
9210 Tips and Trick #1 and #2 | X-Shadow | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 0 | 11-26-2001 02:26 |
