02-06-2016, 06:20 | #18 (permalink) |
No Life Poster Join Date: Apr 2007 Location: M W Balasore,Odisha,INDIA Age: 52
Member: 492222 Status: Offline Sonork: 100.1594126 Thanks Meter: 10,377 | |
02-06-2016, 08:21 | #21 (permalink) | |
No Life Poster Join Date: Oct 2009 Location: India [UNKNOWN]
Member: 1143809 Status: Offline Sonork: 100.1602432 Thanks Meter: 574 | Quote:
join us on yahoo i will solve out your problem Last edited by srinibas; 02-06-2016 at 08:52. Reason: Remove personal information | |
02-06-2016, 08:59 | #24 (permalink) | |
Member: 492222 Status: Offline Sonork: 100.1594126 Thanks Meter: 10,377 | Quote:
1 - Uninstall ATF > 2 - Delete ATF folder > 3 - Download V12.60 > 4 - Install V12.60 > 5 - Update Important files > 6 - Connect box & Install Driver Br - srinibas | |
The Following 4 Users Say Thank You to srinibas For This Useful Post: |
02-06-2016, 13:45 | #26 (permalink) |
No Life Poster Join Date: Oct 2003 Location: Kenya,Mombasa
Member: 40758 Status: Offline Thanks Meter: 26 | SPI programming not working ================================================ Advance Turbo Flasher Found ================================================ Driver Version : 00021206 Library Version : 00030210 Box Type : ATF Nitro Box Firmware : LogiCore 11.0.10 Software Version : v12.60 AdvanceBox SN : Box Status : ACTIVATED ================================================ Box Successfully Initialized ================================================ VBATT Powering Down <<<< VBATT Powering Up >>>> SET VCCIO Level Done SET BSI Load Done ///////// /// /// /////// /////// ///////// /// /// /// /// // /// /// /// /// /// /// /// /////// /////// /// /// /// /// /// /// /// /// /// /// /// /// ///// /// /// /////// ////// ======================================= /// /// /// ///////// /////// ////// ///// /// /// /// /// // /// /// /// ///// /// /// /////// /// /// /// //// /// /// /// /// /// /// /// /// /// /// /// /// ////// ======================================= Resetting ATF Box... Initializing SPI Module... Setting VCCIO Voltage... SPI Module Initialized... Clocks Sent... Searching for an SPI Device... SPI Device Not Found! Try to Reconnect ATF Box USB Cable or Try to Change VCCIO Setting to 3.30V or Check your SPI Connections |
02-06-2016, 14:50 | #27 (permalink) | |
No Life Poster Join Date: Jun 2007 Location: India
Member: 523972 Status: Offline Sonork: 100.1596548 Thanks Meter: 1,259 | Quote:
Thanks, B.Uttam | |
