10-24-2013, 17:39 | #16 (permalink) | |
No Life Poster Join Date: Dec 2007
Member: 651945 Status: Offline Thanks Meter: 20,117 | Quote:
I have 610 Qualcomm OSBL and it is totally useless for now... Just useful for R&D and for non idiots who will not format NAND DISK Windows pop-up Thanks to some samsung android open source... now possible to decrypt modem file system golden. But until something is released, it's all blah blah for now For 900, I already released unlock via JTAG. | |
The Following User Says Thank You to Advance-Box For This Useful Post: |
10-24-2013, 18:07 | #17 (permalink) | |
No Life Poster Join Date: May 2011 Location: tropical island
Member: 1568769 Status: Offline Sonork: 161.1167 Thanks Meter: 208 | Quote:
10-24-2013, 18:40 | #18 (permalink) |
No Life Poster Join Date: May 2008 Location: persian Age: 43
Member: 777729 Status: Offline Sonork: 100.1616470 Thanks Meter: 824 | fail to read flash nokia 105 rm 908 how to read flash? START INFINEON BUS CHECK ************************************************** **** Sending PBL 37888 bytes... PBL Successfully Sent... Sending SBL 65024 bytes... SBL Successfully Sent... Flash Chip Manufacturer: Spansion Electronics Corp. Flash Chip Type: 64 Mbit (4Mb x 16) NOR Extended Information: Mirrorbit / Multi-Bank / 1.8v ************************************************** **** INFINEON BUS CHECK DONE ************************************************** **** VBATT Powering Down <<<< VBATT Powering Up >>>> SET VCCIO Level Done SET BSI Load Done Booting Phone... CPU ID Response: A200341100 CPU Type: XG110 2.1B Phone Booted at after First attempt... ************************************************** **** START INFINEON BUS CHECK ************************************************** **** Sending PBL 19456 bytes... PBL Successfully Sent... Sending SBL 65024 bytes... SBL Successfully Sent... Flash Chip Manufacturer: Spansion Electronics Corp. Flash Chip Type: 64 Mbit (4Mb x 16) NOR Extended Information: Mirrorbit / Multi-Bank / 1.8v Reading NOR Flash: 0x00000000~0x01000000 WARNING: Invalid Data at 0x00000000 Flash Dump Done... ************************************************** **** INFINEON BUS CHECK DONE ************************************************** **** ERROR: Dump File Is Incorrect!!! File Size is too Small Total Time: 00:00:04 VBATT Powering Down <<<< VBATT Powering Up >>>> SET VCCIO Level Done SET BSI Load Done Booting Phone... CPU ID Response: A200341100 CPU Type: XG110 2.1B Phone Booted at after First attempt... ************************************************** **** START INFINEON BUS CHECK ************************************************** **** Sending PBL 19456 bytes... PBL Successfully Sent... Sending SBL 65024 bytes... SBL Successfully Sent... Flash Chip Manufacturer: Spansion Electronics Corp. Flash Chip Type: 64 Mbit (4Mb x 16) NOR Extended Information: Mirrorbit / Multi-Bank / 1.8v Reading NOR Flash: 0x00000000~0x01000000 WARNING: Invalid Data at 0x00000000 Flash Dump Done... ************************************************** **** INFINEON BUS CHECK DONE ************************************************** **** ERROR: Dump File Is Incorrect!!! File Size is too Small Total Time: 00:00:04 |
10-24-2013, 22:07 | #19 (permalink) | |
No Life Poster Join Date: Jul 2005 Location: Auckland
Member: 160928 Status: Offline Thanks Meter: 338 | Quote: | |
10-25-2013, 01:32 | #20 (permalink) | |
No Life Poster Join Date: Mar 2007
Member: 468656 Status: Offline Thanks Meter: 76 | Quote:
10-25-2013, 04:59 | #24 (permalink) |
No Life Poster Join Date: Sep 2007 Location: Gsm_World
Member: 583353 Status: Offline Thanks Meter: 259 | sir can you share your readed good back up for this model nokia 107 we dont have good unit for back up purpose. br, |
The Following User Says Thank You to nelsky For This Useful Post: |
10-25-2013, 16:43 | #28 (permalink) |
Freak Poster Join Date: Dec 2007 Location: iran Age: 45
Member: 652684 Status: Offline Thanks Meter: 20 | VBATT Powering Down <<<< VBATT Powering Up >>>> SET VCCIO Level Done SET BSI Load Done Booting Phone... CPU ID Response: A200341100 CPU Type: XG110 2.1B Phone Booted at after First attempt... ************************************************** **** START INFINEON BUS CHECK ************************************************** **** Sending PBL 19456 bytes... PBL Successfully Sent... Sending SBL 65024 bytes... SBL Successfully Sent... Flash Chip Manufacturer: Spansion Electronics Corp. Flash Chip Type: 64 Mbit (4Mb x 16) NOR Extended Information: Mirrorbit / Multi-Bank / 1.8v Reading NOR Flash: 0x00000000~0x01000000 WARNING: Invalid Data at 0x00000000 Flash Dump Done... ************************************************** **** INFINEON BUS CHECK DONE ************************************************** **** ERROR: Dump File Is Incorrect!!! File Size is too Small Total Time: 00:00:04 nokia 105 not read dump |
10-25-2013, 19:33 | #30 (permalink) | |
Junior Member Join Date: Jul 2007
Member: 551941 Status: Offline Thanks Meter: 40 | fix Quote:
stop all anti virus program b.r | |
