02-03-2014, 15:19 | #1 (permalink) |
No Life Poster Join Date: Oct 1999 Location: Shenzhen, Hong Kong, Bangkok
Member: 611 Status: Offline Sonork: 100.33333 Thanks Meter: 29,604 | ATF v11.01 Turbo eMMC, JTAG Update!! Public Discussion Thread: Release Date: February 6, 2014 Firmware Version Required : 11.0.00 (NEW FIRMWARE) * Fixed SX-4 Module Failure * Allows ATF Exe to work without Internet Connection * Added Samsung SDC Unbricker Image Writer DOWNLOAD SDC Files Here: SAMSUNG SDC FILES by d18.builder - 4shared After Downloading SDC Files, copy them to: C:\AdvanceBox Turbo Flasher\SD_CARD\SDC_IMAGE\ ATF v11.00 Release Date: February 3, 2014 Firmware Version Required : 11.0.00 (NEW FIRMWARE) [New ATF Box Firmware] LogiCore 11.0.00 * ULTRA FAST SD Card Password Brute Force Speed Upto 20,000 Passwords Per Second on Class 10 Cards * 6000% Speed Increase in SD Card Password Brute Force Speed Compared to LogiCore 10.8.30 * Absolutely the Fastest SD Card Password BF Solution in the World * Added SD Card RAW Read/Write Module with upto 2 MBPS Transfer Rate * Big Improvement on eMMC TP Write Speed (6000% Speed Increase) with upto 2MBPS Transfer Rate * Big Improvement on ATF JTAG Speed with Turbo JTAG Technology upto 30 Mhz usable TCK Speed [ATF Plus] * Added SDC Tool - Direct RAW Read/Write for micro SD Cards * Direct Write Samsung Debrick Images for Supported Qualcomm Based Phones --> UN-BRICK / REPAIR DEAD BOOT Phones WITHOUT JTAG!!! * Read/Write Speeds upto 2 MBPS * Automatic Fatory Erase Before Writing * Automatic Verify Written Blocks * Supports ATF Big SD Card Slot or ATF Micro SD Card Adapter Cable * Adjustable Speed from 5 Mhz to 30 Mhz * Supports SDHC and SDXC Cards (Upto 2TB Size) * Adjustable VCCIO (1.80v, 2.80v or 3.30v) * Custom Read/Write Address * Selectable BLOCK Addressing or NON-LBA Addressing * Supports sdc, img, bin or raw Formats * Improvements in eMMC Tool * eMMC Write Speed is now 60x Faster (1GB = 10 Minutes) * Now Supports ".mmc" Repair Files for Dead Boot Repair via eMMC Connection * Automatic VPP 3.0v Output for ATF Big Boxes during EMMC_MODE --> Now you can directly power eMMC without Voltage Regulators [Intel/Infineon XG221] RM-934 : Nokia Asha 500 Dual SIM RM-973 : Nokia Asha 500 * Added XG221 Full Flashing * Added XG221 Mass Memory Flashing * Added XG221 Backup RPL etc... * Added XG221 Decrypt PM 120 HASH for 15-Digit Phones [ATF Turbo JTAG] * Added Turbo JTAG in Settings to Boost JTAG Speed to 30 Mhz, 15 Mhz or 10 Mhz --> Find this new Option in "Settings" ----> "Turbo JTAG" * Added Lumia 900 "IMEI Repair" / "IMEI Restore" (RM-808 and RM-823 Supported) --> Use this at your OWN RISK * Added Estimated Time to Finish Task --> Put Mouse Over Progress Bar * Additional GUI Enhancements [Driver Updates] * New ATF Box Signed Drivers for 32/64 Bit Windows XP, 7 and 8 (Version 2.8.30.0) * New Nokia Connectivity Cable Driver (Version 7.1.182.0) * New WinUSB Extensions for 32/64 Bit Bit Windows XP, 7 and 8 [Server Updates] * RSA Signing Server for ATF Exe now Implemented Starting with ATF v11.00 [General Updates] * Complete Product Listing in Nokia.ini as of February 3, 2014 * Complete WP7/WP8 Variant Listing as of February 3, 2014 [IMPORTANT ANNOUNCEMENTS] 1. ATF New Driver DOES NOT SUPPORT Older ATF Software Versions (Anything Below v11.00) 2. LogiCore 11.0.00 DOES NOT SUPPORT Older ATF Software Versions (Anything Below v11.00) 3. You need to be Connected to the Internet "THE FIRST TIME" you run AdvanceBox.exe v11.00 Who will buy this if you can get more in ATF? __________________________________________________ ________________________ Buy only from ATF [Advance Turbo Flasher] authorized resellers: ATF [Advance Turbo Flasher] Authorized Distributors and Resellers List ATF [Advance Turbo Flasher] official web sites: International - http://www.advance-box.com/ ATF [Advance Turbo Flasher] official support forums: World Wide: Advance Turbo Flasher - GSM-Forum Indonesia: ATF (Advance Turbo Flasher)) Philippine: Gsmph Syria: Arabic Support (Syria) GsmVIP Chinese support forum : ATF Box Vietnam: Saigonmobile India: Advance Box - .:: GsmIndia ::. Official Iran Support Forum : ASANGSM FORUM Bangladesh: Advance Box - Dhaka Mobile Chinese Support forum : www.yananliuhuan.com The Master Piece Last edited by Advance-Box; 02-06-2014 at 09:51. |
The Following 108 Users Say Thank You to gsmfun For This Useful Post: |
02-03-2014, 15:19 | #2 (permalink) |
No Life Poster Join Date: Dec 2006 Location: Karachi, Pakistan Age: 33
Member: 643472 Status: Offline Sonork: 100.96901 Thanks Meter: 16,589 | Official Download Links: [ATF v11.00 + ATF JTAG 1.06 FULL INSTALLER] ATF_v11.00_Full_Installer_(FIXED).rar via www.4shared.com ATF_v11.00_Full_Installer_(FIXED).rar via www.mirrorcreator.com 1 ATF_v11.00_Full_Installer_(FIXED).rar via www.mirrorcreator.com 2 ATF Full Installer Fixed v11.00 - Mediafire Mirror: https://forum.gsmhosting.com/vbb/****************************/?g8t9b8hdh8cjx7z [ATF JTAG 1.06 FULL INSTALLER] ATF_JTAG_v1.06_Full_Installer_(FIXED).rar via www.4shared.com ATF_JTAG_v1.06_Full_Installer_(FIXED).rar via www.mirrorcreator.com [ATF JTAG 1.06 EXE + LUMIA 900 IMEI REPAIR ONLY] ATF_JTAG_v1.06_EXE_ONLY_(FIXED).rar via www.4shared.com ATF_JTAG_v1.06_EXE_ONLY_(FIXED).rar via www.mirrorcreator.com Last edited by ..::Angel::..; 02-04-2014 at 14:55. |
The Following 62 Users Say Thank You to ..::Angel::.. For This Useful Post: |
02-03-2014, 15:27 | #3 (permalink) |
Member: 643472 Status: Offline Sonork: 100.96901 Thanks Meter: 16,589 | This update v11.00 requires NEW ATF BOX DRIVERS and NEW ATF BOX FIRMWARE v11.0.00 After you install full setup, it will automatically install NEW DRIVERS and than you can click on Update Firmware from Product Support->Box Tools. [IMPORTANT ANNOUNCEMENTS] 1. ATF New Driver DOES NOT SUPPORT Older ATF Software Versions (Anything Below v11.00) 2. LogiCore 11.0.00 DOES NOT SUPPORT Older ATF Software Versions (Anything Below v11.00) 3. You need to be Connected to the Internet "THE FIRST TIME" you run AdvanceBox.exe v11.00 BR |
The Following 20 Users Say Thank You to ..::Angel::.. For This Useful Post: |
02-03-2014, 15:36 | #4 (permalink) |
Freak Poster Join Date: Dec 2008 Location: PH/Singapore/Malaysia
Member: 923652 Status: Offline Sonork: 1601428 Thanks Meter: 89 | please add image tp for all supported samsung like this please correct tp image http://forum.gsmhosting.com/vbb/f609...epair-1768364/ and this please add tsolution for this problem big thanks http://forum.gsmhosting.com/vbb/f664...t=i8190+medusa great update and please fix chrome box only lightning box fix s100 dead boot |
The Following 4 Users Say Thank You to ilaw For This Useful Post: |
02-03-2014, 16:01 | #5 (permalink) |
No Life Poster Join Date: Jan 2006 Location: algeria
Member: 217891 Status: Offline Thanks Meter: 237 | wat mean that ??? * Direct Write Samsung Debrick Images for Supported Qualcomm Based Phones --> UN-BRICK / REPAIR DEAD BOOT Phones WITHOUT JTAG!!! |
The Following 2 Users Say Thank You to moh_boulk17 For This Useful Post: |
02-03-2014, 16:44 | #7 (permalink) |
Freak Poster Join Date: Jun 2013 Location: Faisal_Software_Lab (SQT) PK Age: 28
Member: 1953288 Status: Offline Sonork: 1640280 Thanks Meter: 13 | very nice update but why not add nokia 108 (mediatak) |
The Following 3 Users Say Thank You to faisal.abuzar For This Useful Post: |
02-03-2014, 17:06 | #14 (permalink) |
No Life Poster Join Date: Feb 2008 Location: Brazil Age: 41
Member: 700706 Status: Offline Sonork: 100.1590381 Thanks Meter: 208 | --> UN-BRICK / REPAIR DEAD BOOT Phones WITHOUT JTAG!!! I have a Lumia 900 that connects and then the display goes white and it does not start. Can I fix this without the Jtag activation? What is the procedure? |
The Following User Says Thank You to Bruno Rafael For This Useful Post: |
02-03-2014, 17:11 | #15 (permalink) | |
Member: 643472 Status: Offline Sonork: 100.96901 Thanks Meter: 16,589 | Quote:
BR | |
The Following User Says Thank You to ..::Angel::.. For This Useful Post: |
