10-01-2014, 18:00 | #46 (permalink) |
No Life Poster Join Date: Mar 2014 Location: Kfe~Labs Co.- Age: 52
Member: 2140790 Status: Offline Sonork: 100.1679059 Thanks Meter: 212 | after unistall and clean pc, still cant work wwith last version.- please help http://forum.gsmhosting.com/vbb/f609...l#post10590167 aUt0 |
10-01-2014, 18:01 | #47 (permalink) |
Member: 2140790 Status: Offline Sonork: 100.1679059 Thanks Meter: 212 | Hi after unistall and clean pc, still cant work wwith last version.- add server not work, all time ask about new key activation but server not response(busy) please help http://forum.gsmhosting.com/vbb/f609...l#post10590167 SOLVED COPY 32BIT DLL INSIDE ATF FOLDER (Using Win7 64Bit) working now aUt0 Last edited by Automatico; 10-01-2014 at 18:09. Reason: dll 32bit for win7 64 bit Work perfect :) Bye and Thanks |
The Following User Says Thank You to Automatico For This Useful Post: |
10-01-2014, 18:17 | #48 (permalink) |
No Life Poster Join Date: Nov 2006 Location: philippines Age: 42
Member: 388962 Status: Offline Sonork: 100.1637202 Thanks Meter: 263 | i was hoping to get new supported model for unlock in some places, we don't have that much dead phone so emmc jtag is not much of a use. most of what we need is unlocking for some newer phones like lumia 520, and other latest lumia phones. i humbly ask atf team to please work on unlocking new lumia phones. thank you. |
10-02-2014, 08:19 | #49 (permalink) |
No Life Poster Join Date: Dec 2007
Member: 651945 Status: Offline Thanks Meter: 20,117 | After you install ATF 11.70, you will see 2 Folders inside C:\AdvanceBox Turbo Flasher\OpenSSL\ DLL_32-BIT DLL_64-BIT Now inside each folder are 2 dll Files... Try First to copy the 2 files from DLL_32-BIT, and paste it to C:\AdvanceBox Turbo Flasher\ overwrite the current files there... if that does not work and still Invalid Response, then try the other 2 dlls inside DLL_64-BIT folder. |
The Following User Says Thank You to Advance-Box For This Useful Post: |
10-02-2014, 10:09 | #51 (permalink) |
Junior Member Join Date: Jan 2012 Location: Magyarország
Member: 1714300 Status: Offline Thanks Meter: 1 | ================================================ Box Successfully Initialized ================================================ ================================================ Advance Turbo Flasher Found ================================================ Driver Version : 00021000 Library Version : 00030207 Box Type : ATF Nitro Box Firmware : LogiCore 10.3.80 Software Version : v11.70 AdvanceBox SN : E8DADEE6F20E1D51CA9F17BE ============================================== Please update your Box Firmware ============================================== * Follow these Instructions 1. Disconnect any phones connected to ATF Box 2. Go to "Product Support Tab" 3. Go to "Box Tools" Section 4. Click "Update Firmware" button * Make sure you put ATF Software in Windows FireWall Exclusion List * Make sure you put ATF Software in your Virus Scanner Exclusion List ================================================ Box Successfully Initialized ================================================ No firmware update, server error |
10-02-2014, 10:35 | #52 (permalink) |
Member: 651945 Status: Offline Thanks Meter: 20,117 | @pityiri After you install ATF 11.70, you will see 2 Folders inside C:\AdvanceBox Turbo Flasher\OpenSSL\ DLL_32-BIT DLL_64-BIT Now inside each folder are 2 dll Files... Try First to copy the 2 files from DLL_32-BIT, and paste it to C:\AdvanceBox Turbo Flasher\ overwrite the current files there... if that does not work and still Invalid Response, then try the other 2 dlls inside DLL_64-BIT folder. |
10-02-2014, 11:01 | #53 (permalink) |
No Life Poster Join Date: Jul 2007
Member: 551619 Status: Offline Thanks Meter: 136 | Please Help for : ========================================= Please Try Again Later (Server Busy) ========================================= ================================================ ATF SOFTWARE IS NOT ACTIVATED ON THIS PC Please Activate your ATF Software ================================================ Anti-Virus & Firewall Disable Reconnect Box & Restart Application Not Working OS : Windows 7 64bit Same Version Working with Windows 7 32bit without Any Problem Box.png 11.70.png Last edited by SkyNet4u; 10-02-2014 at 11:08. |
10-02-2014, 11:07 | #55 (permalink) |
Member: 1714300 Status: Offline Thanks Meter: 1 | ================================================ Box Successfully Initialized ================================================ ================================================ Advance Turbo Flasher Found ================================================ Driver Version : 00021000 Library Version : 00030207 Box Type : ATF Nitro Box Firmware : LogiCore 10.3.80 Software Version : v11.70 AdvanceBox SN : E8DADEE6F20E1D51CA9F17BE ============================================== Please update your Box Firmware ============================================== * Follow these Instructions 1. Disconnect any phones connected to ATF Box 2. Go to "Product Support Tab" 3. Go to "Box Tools" Section 4. Click "Update Firmware" button * Make sure you put ATF Software in Windows FireWall Exclusion List * Make sure you put ATF Software in your Virus Scanner Exclusion List ================================================ Box Successfully Initialized ================================================ please help TeamViewer not work dll overrite |
10-02-2014, 11:13 | #57 (permalink) |
Member: 651945 Status: Offline Thanks Meter: 20,117 | @SkyNet4u Man please read what is already written more than 10 times in this forum. After you install ATF 11.70, you will see 2 Folders inside C:\AdvanceBox Turbo Flasher\OpenSSL\ DLL_32-BIT DLL_64-BIT Now inside each folder are 2 dll Files... Try First to copy the 2 files from DLL_32-BIT, and paste it to C:\AdvanceBox Turbo Flasher\ overwrite the current files there... if that does not work and still Invalid Response, then try the other 2 dlls inside DLL_64-BIT folder. It means use 32-bit DLL for 64-BIT Machine... |
The Following 2 Users Say Thank You to Advance-Box For This Useful Post: |
