12-01-2014, 13:05 | #76 (permalink) |
No Life Poster Join Date: Apr 2011 Age: 58
Member: 1564612 Status: Offline Thanks Meter: 12,343 | http://forum.gsmhosting.com/vbb/f609...49/index5.html Loock from post #72 BR allumts |
The Following 2 Users Say Thank You to allumts For This Useful Post: |
12-03-2014, 19:20 | #78 (permalink) | |
Member: 1564612 Status: Offline Thanks Meter: 12,343 | Quote:
If are using always Atf Support area is more good: ATF Offcial Support Area / and here you Sw update to 11.82 just copy/paste in Atf Folder and replace the old exe 11.80: http://174.120.45.27/current_exe/AdvanceBox.exe 11.82 exe BR allumts | |
12-10-2014, 22:41 | #79 (permalink) |
Freak Poster Join Date: Nov 2007 Location: SUKATANI-BEKASI-APAC_X
Member: 624037 Status: Offline Sonork: 100.1608764 Thanks Meter: 41 | Cannot conect to server always coneting time out, while I doing SX4 from server, because SX4 standalone not supported Sent from my BlackBerry 9220 using Tapatalk |
12-21-2014, 13:26 | #81 (permalink) |
No Life Poster Join Date: Dec 2007
Member: 651945 Status: Offline Thanks Meter: 20,118 | Release Date: December 21, 2014 Firmware Version Required : 11.0.00 ATF Box USB Driver Required: 2.10.0.0 - Windows 7/8/8.1 (32-bit and 64-bit) ATF Box USB Driver Required: 2.8.30.0 - Windows XP (32-bit and 64-bit) ATF 11.88 *** GET THIS UPDATE VIA AUTO-UPDATE SEVER *** What's Cooking? Lumia WP8/WP8.1 BOOT Repair via USB is now Supported for Retail Lumia Phones: Lumia 920 (RM-820, RM-821, RM-867) Lumia 820 (RM-824, RM-825) Lumia 620 (RM-846) Lumia 928 (RM-860) Lumia 1020 (RM-875, RM-876, RM-877) Lumia 720 (RM-885, RM-887) Lumia 925 (RM-892, RM-893, RM-910, RM-955) Lumia 520 (RM-913, RM-914, RM-915, RM-917) Lumia 625 (RM-941, RM-942, RM-943) Lumia 1320 (RM-994, RM-995, RM-996) Lumia 525 (RM-997, RM-998) The procedure is very simple, just Flash the Phone like you Normally would without clicking any more additional options. ATF will detect your phone's current STATE and will perform the necessary Tasks to Revive it. Please make sure that YOU MUST USE ONLY the 'Nokia Emergency Connectivity" Drivers because as for now, any other 9008 drivers such as Qualcomm and Zeus (Sony) it not supported for USB BOOT Repair. You must also click "UPDATE IMPORTANT FILES" so that you will be able to download the MPRG Loaders that will be used for USB BOOT Repair. More will come after a short Holiday Leave. If you find problems with ATF 11.88 (Because it was done very quickly) Then Please do not use it. B.R. X-Shadow |
The Following 4 Users Say Thank You to Advance-Box For This Useful Post: |
12-21-2014, 14:06 | #82 (permalink) |
No Life Poster Join Date: Apr 2006 Location: IN INDIA
Member: 263005 Status: Offline Thanks Meter: 147 | L520 rm914 boot repair failed Recovery Handle Found! - (WinUSB) Sending Factory Loader... Loader Upload Done! Executing Loader... Start Loader Done! Waiting for USB Cycle... USB Cycle OK! Device Factory Mode OK! USB Reconfiguration Done... eMMC Detected OK... Extracting Partitions from FFU... Looking for SBL1... SBL1 OK Looking for SBL2... SBL2 OK Looking for SBL3... SBL3 OK Looking for UEFI... UEFI OK Looking for RPM... RPM OK Looking for TZ... TZ OK Looking for WINSECAPP... WINSECAPP OK Extracting Partitions Done! Start Writing eMMC Blocks at : 0x00000000 |
12-21-2014, 16:36 | #84 (permalink) | |
Junior Member Join Date: Dec 2014
Member: 2303751 Status: Offline Thanks Meter: 1 | Quote:
You could share a MPRGxxxx for RM-940 (lumia 1520) or if you can for other models lumia 1520 ?? i am looking it everywhere for a long time without success. | |
12-22-2014, 10:27 | #87 (permalink) |
Member: 651945 Status: Offline Thanks Meter: 20,118 | No. This is FREE and works just like regular Lumia Flashing (No Special Options Needed) Only 1 thing you need to have is to MAKE SURE YOU ARE USING "Nokia Emergency Connectivity" Driver when Windows Device Manager detects your Phone. Here is Sample on Lumia 920 Boot Repair via USB: Code: Windows Phone 8/8.1 Flashing Started Loading Flash Files Please Wait... [DEAD BOOT REPAIR SUPPORTED] ====================================================== Windows Phone 8/8.1 Lumia Flasher ====================================================== If the Phone is ALIVE 1. Power On the Phone and Connect it to the USB Port If the Phone is DEAD 1. Connect Phone to the USB Port 2. Press and Hold the VOLUME DOWN and POWER Buttons 3. Wait until the Phone Vibrates Shortly... 4. Stop Pressing the Buttons... If the Phone is DEAD BOOT 1. Connect Phone to the USB Port 2. Install Correct Drivers: "Nokia Emergency Connectivity" ====================================================== Recovery Handle Found! - (WinUSB) Sending Factory Loader... Loader Upload Done! Executing Loader... Start Loader Done! Waiting for USB Cycle... USB Cycle OK! Device Factory Mode OK! USB Reconfiguration Done... eMMC Detected OK... Extracting Partitions from FFU... Looking for SBL1... SBL1 OK Looking for SBL2... SBL2 OK Looking for SBL3... SBL3 OK Looking for UEFI... UEFI OK Looking for RPM... RPM OK Looking for TZ... TZ OK Looking for WINSECAPP... WINSECAPP OK Extracting Partitions Done! Start Writing eMMC Blocks at : 0x00000000 Start Writing eMMC Blocks at : 0x01000000 Start Writing eMMC Blocks at : 0x01200000 Start Writing eMMC Blocks at : 0x01400000 Start Writing eMMC Blocks at : 0x01600000 Start Writing eMMC Blocks at : 0x01A00000 Start Writing eMMC Blocks at : 0x01C00000 Start Writing eMMC Blocks at : 0x01E00000 eMMC Write OK! Closing Partition... Partition Close OK! BOOT WRITE DONE! Waiting for USB Cycle... USB Cycle OK! Rebooting Phone... Nokia Phone Info Mode Initiated... Please wait upto 15 Seconds for SW Reset IMEI: 353680050278169 Version: 1.1.1.3 Product Code: 059N5T3 Module Code: 0205138 Continuing Previous Boot... Please wait upto 30 Seconds for Boot Re-entry Boot Flash Mode Successful... Buffers Flushed OK... Phone Info Query Start... Blocks Returned: 0x07 Blocks Block ID 0x01 : 00241000 Block ID 0x02 : 00240000 Block ID 0x03 : 03A3E000 Block ID 0x05 : Nokia.MSM8960.P4301_ATT.3.2.1 Block ID 0x0D : 0001 Block ID 0x0F : 0301010100000101FF Block ID 0x10 : 0100030000 Checking SD Card Size... Card Size: 0x00000000 Checking Platform Security Status... Platform Secure Boot Status: Active Secure FFU EFUSE Status: Active Debug Status: Active RDC Status: Not Active Authentication Status: Not Active UEFI Secure Boot Status: Active Checking Secure FFU Mode... Secure FFU Mode : SYNC + ASYNC Query Flash App Information... Flash App Information: 02010E011900 UEFI App: FLASH APP Flash App Protocol Version: 1.14 Flash App Implementation Version: 1.25 Query ROOT KEY HASH... ROOT_KEY_HASH: 00E9427DF118D9E27D098D13BECB6C6C89CE59F4ECCF5549C49BC0DB952A6BB4 Sending Image Signatures... Image Signatures Accepted! Erasing Data Partition... Data Partition Erased Successfully Preparing Buffers for DATA LOOP... Allocating System RAM OK! Start Sending DATA BLOCKS... Finished Sending all DATA BLOCKS! Exiting FLASH Mode via REBOOT... Exit FLASH Mode Successful! Flashing Done! Total Flashing Time : 00:01:50 |
The Following 3 Users Say Thank You to Advance-Box For This Useful Post: |
