03-31-2015, 13:07 | #1 (permalink) |
No Life Poster Join Date: Oct 1999 Location: Shenzhen, Hong Kong, Bangkok
Member: 611 Status: Offline Sonork: 100.33333 Thanks Meter: 29,604 | ATF v12.12 update!! Public Discussion Thread: Firmware Version Required : 11.0.10 or 11.0.12 ATF Box USB Driver Required: 2.10.0.0 - Windows 7/8/8.1 (32-bit and 64-bit) ATF Box USB Driver Required: 2.8.30.0 - Windows XP (32-bit and 64-bit) You need to download this exe via the AUTO-UPDATE SERVER ATF 12.12 We are proud to present to you VPXO and VMXO eMMC Firmware Update Support for some of the MOST WANTED eMMCs in the MARKET!!! You can now REPAIR TOTALLY DEAD EMMCS using Provided NAND RE Test Points. ATF Plus - eMMC Tool 3.5 (PRO) --> EMMC Firmware Update + NAND RE Test Points Added for: ------> V3W00M - KMV3W000LM-B310 - (VMX0 CONTROLLER) First In The World ------> S5XKMB - KMS5X000KM-B313 - (VPX0 CONTROLLER) First In The World ------> MAG2GA - KLMAG2GE4A-A001 - First In The World ------> M8G1WA - KLM8G1WE4A-A001 - First In The World --> Massively Improved Samsung eMMC Firmware Update Procedure More info for totally dead eMMC Here: STEP BY STEP repair VTU00M (and Others) totally dead EMMC. V3W00M - KMV3W000LM-B310 <--- This is eMMC Type D PINOUT S5XKMB - KMS5X000KM-B313 <--- This is eMMC Type E PINOUT MAG2GA - KLMAG2GE4A-A001 <--- This is eMMC Type F PINOUT M8G1WA - KLM8G1WE4A-A001 <--- This is eMMC Type F PINOUT ** We Apologize for the "UGLY" Watermark on our NEW PINOUTS... But Team Zero keeps copy pasting our eMMC Solutions and our eMMC Pictures ;P ** You can download eMMC Factory NAND Pinouts AND eMMC Fimrwares by clicking "UPDATE IMPORTANT FILES" in your ATF Software as well. eMMC Factory Pinouts will be saved here: C:\AdvanceBox Turbo Flasher\eMMC\eMMC_TP\ eMMC Firmware will be saved here: C:\AdvanceBox Turbo Flasher\eMMC\Firmware\ B.R. X-Shadow P.S. If you need ATF To support a specific eMMC, please post here: http://forum.gsmhosting.com/vbb/f609...nouts-1941023/ Release Date: April 12, 2015 Firmware Version Required : 11.0.10 or 11.0.12 ATF Box USB Driver Required: 2.10.0.0 - Windows 7/8/8.1 (32-bit and 64-bit) ATF Box USB Driver Required: 2.8.30.0 - Windows XP (32-bit and 64-bit) You need to download this exe via the AUTO-UPDATE SERVER ATF 12.11 ATF Plus - eMMC Tool 3.4 (PRO) --> Fixed San.Disk eMMC Detection CMD8+ Problem --> Removed CMD1 DEBUG Reponses Added eMMC Firmware for Samsung M8G2YC (KLM8G2YE4C-C001) --> This is the eMMC Used on most Lumia 520/620 with Problems --> Please remember that Updating eMMC Firmware will ERASE IMEI and Simlocks --> Please BACKUP 512MB of eMMC before attempting eMMC Firmware Update --> For Totally Dead eMMC, use eMMC NAND Factory Pinout Type C More info for totally dead eMMC Here: STEP BY STEP repair VTU00M (and Others) totally dead EMMC. You can download eMMC Factory NAND Pinouts AND eMMC Fimrwares by clicking "UPDATE IMPORTANT FILES" in your ATF Software as well. eMMC Factory Pinouts will be saved here: C:\AdvanceBox Turbo Flasher\eMMC\eMMC_TP\ eMMC Firmware will be saved here: C:\AdvanceBox Turbo Flasher\eMMC\Firmware\ Added New Lumia Products in Nokia.ini Lumia 640 XL LTE (RM-1062) Lumia 640 XL LTE (RM-1063) Lumia 640 XL LTE (RM-1064) Lumia 640 XL LTE DS (RM-1065) Lumia 640 LTE (RM-1074) Lumia 640 XL LTE DS (RM-1096) ================================================== ============ Release Date: March 31, 2015 Firmware Version Required : 11.0.10 or 11.0.12 ATF Box USB Driver Required: 2.10.0.0 - Windows 7/8/8.1 (32-bit and 64-bit) ATF Box USB Driver Required: 2.8.30.0 - Windows XP (32-bit and 64-bit) ---> eMMC Tool 3.3 (PRO) -----> Added Support for Samsung eMMC Repair "TOTALLY DEAD 00FF8080" eMMCs (First in The World) -----> This can repair totally dead Samsung eMMCs which always reply "BUSY" to Normal eMMC Initialization -----> This Solution Requires an Activation + Special eMMC Socket Adapter -----> This Solution can be customized to any Samsung eMMC Model with BGA-153/169 or BGA-162 Pinout P.S. No Regards to NEWBIES who think Reversing 64KB eMMC BOOTROM + 128KB FIRMWARE is hard ---> More Spreadtrum CPU eMMC Test Point Finder Support -----> Supported Spreadtrum CPU: SC6820i, SC6820ES, SC7715, SC7735S, SC7715A, SC7715T, -----> SC6815AS, SC8810ES, SC8825, SC8825A -----> More Info about Spreadtrum eMMC Finder Support Here: http://forum.gsmhosting.com/vbb/f609...orial-1908984/ General Nokia Updates: BB5 FBUS BOOT Improvements Added New Lumia Models to Nokia.ini --> Lumia 430 DS (RM-1099) --> Lumia 640 DS DTV (RM-1109) --> Lumia 640 LTE DS (RM-1113) --> Lumia 435 DS DTV (RM-1114) --> Lumia 532 DS DTV (RM-1115) ******************************* ATF JTAG 1.0.14 Build 7528 ******************************* Release Date: March 31, 2015 Firmware Version Required : ATF Lightning/Nitro: LogiCore 11.0.10 ATF Chrome/GOLD : LogiCore 11.0.10 or LogiCore 11.0.12 Change Log --> DUAL JTAG Connections now Supported on ATF Chrome/GOLD Boxes ----> Now you can connect 2 Phones at the same time for ATF Chrome/GOLD Boxes ----> Connect 1 Phone on "FLASHBUS" port and connect another phone on "EXTENSION" port --> Initial BroadCom CPU Support ----> CPU Supported: BCM21654, BCM21654G, BCM21664, BCM21664T, BCM28155, BCM28155T --> Greatly Improved Qualcomm CPU eMMC Write Speeds --> Increased Qualcomm CPU eMMC Write Timeouts --> Added Remove Write Protection BIT for Samsung Brand eMMCs --> Added Support for SmartGsm EXTENSION Port JTAG Adapter (via LogiCore 11.0.12) --> Added VBATT 4.0v Output for Powering Phone ----> Now you don't need an EXTERNAL Power Supply just in case Phone Battery is Dead ----> Just connect "VBATT 4.0v" to VBATT (+) POSITIVE of Phone's Battery Terminal *** IMPORTANT NOTICE *** For ATF Chrome/GOLD boxes, JTAG PINOUTS for "FLASHBUS" port and "EXTENSION" port are NOT THE SAME. FLASHBUS port uses 8-PINS RJ-45, and the JTAG PINOUT is: 1 - VBATT 4.0V (Optional) 2 - 3 - TRST + SRST 4 - TDO 5 - TDI 6 - TCK 7 - GROUND 8 - TMS EXTENSION port uses 10-PINS RJ-48, and the JTAG PINOUT is: 1 - TRST + SRST 2 - VBATT 4.0V (Optional) 3 - 4 - TDO 5 - TDI 6 - TCK 7 - 8 - GROUND 9 - TMS 10 - For Better and more Stable connection on the EXTENSION PORT, we suggest using a SmartGSM ATF EXTENSION PORT JTAG ADAPTER. Who will buy this if you can get more in ATF? __________________________________________________ ________________________ Buy only from ATF [Advance Turbo Flasher] authorized resellers: ATF [Advance Turbo Flasher] Authorized Distributors and Resellers List ATF [Advance Turbo Flasher] official web sites: International - http://www.advance-box.com/ ATF [Advance Turbo Flasher] official support forums: World Wide: Advance Turbo Flasher - GSM-Forum Indonesia: ATF (Advance Turbo Flasher)) Philippine: Gsmph Syria: Arabic Support (Syria) GsmVIP Chinese support forum : ATF Box Vietnam: Saigonmobile India: Advance Box - .:: GsmIndia ::. Official Iran Support Forum : ASANGSM FORUM Bangladesh: Advance Box - Dhaka Mobile Chinese Support forum : www.yananliuhuan.com The Master Piece Last edited by Advance-Box; 04-22-2015 at 22:18. |
The Following 18 Users Say Thank You to gsmfun For This Useful Post: |
03-31-2015, 13:50 | #5 (permalink) |
No Life Poster Join Date: Nov 2011 Location: .::INDIA::. Age: 35
Member: 1681461 Status: Offline Sonork: [OFFLINE] Thanks Meter: 1,011 | ATF Offical Support resume capabiliy yes Internet Download Manager and not resume capabiliy Internet speed low for india Thanks |
03-31-2015, 14:26 | #6 (permalink) |
No Life Poster Join Date: Apr 2007 Location: M W Balasore,Odisha,INDIA Age: 52
Member: 492222 Status: Offline Sonork: 100.1594126 Thanks Meter: 10,377 | Last edited by srinibas; 03-31-2015 at 14:59. |
The Following 7 Users Say Thank You to srinibas For This Useful Post: |
03-31-2015, 14:58 | #9 (permalink) | |
Member: 492222 Status: Offline Sonork: 100.1594126 Thanks Meter: 10,377 | Quote:
Br - srinibas | |
The Following User Says Thank You to srinibas For This Useful Post: |
