07-07-2014, 10:48 | #1 (permalink) |
No Life Poster Join Date: Jan 2010 Location: China
Member: 1222089 Status: Offline Sonork: 100.1583019 Thanks Meter: 2,688 | ATF-V2 All in 1 Ultimate Adaptor For ATF BIG BOX/Nitro/Lighting CLICK TO BUY ONLINE ATF-V2 All in 1 Ultimate Adaptor For ATF BIG BOX/Nitro/Lighting ON = Strong PULL-UP Resistors will be applied to eMMC CMD (BLUE) and DATA (GREEN) Lines. ---> This is very usefull for phones that require VccQ and Vcc Power Connections (Samsung, HTC etc) OFF = PULL-UP Resistors WILL NOT be used. ---> This is normally done with Nokia Lumia Phones which does not require VccQ and Vcc Connections For a more stable connection, set switch to "ON" and make sure to connect required power to VccQ and Vcc Lines 3.3v = Most New/Old Micro SD Cards are Compatible with 3.3v Vcc 1.8V = We have prepared a 1.8v Vcc for Future Low-Powered Micro SD Cards [For eMMC Use Only] NC = Secondary CLOCK will not be used for eMMC Communication CLK2 = Secondary CLOCK will be used for eMMC Communication When adapter is used for a NON-EMMC Connection such as JTAG or Micro SD Card, make sure this DIP Switch is on the "NC" Position. CLK2 is NOT REQUIRED for most eMMC Chips, but setting DIP SWITCH to CLK2 will give you a stronger CLK (RED) Signal for better eMMC Communication. CLICK TO BUY ONLINE ATF-V2 All in 1 Ultimate Adaptor For ATF BIG BOX/Nitro/Lighting FOR RESELLER CONTACT ME EMAIL : [email protected] WHATSAPP : +8615814039536 |
The Following 14 Users Say Thank You to Smart-gsm For This Useful Post: |
07-07-2014, 11:08 | #2 (permalink) |
Member: 1222089 Status: Offline Sonork: 100.1583019 Thanks Meter: 2,688 | Beware of Buying copy/bad Quality ATF Adaptor will harm your phones |
The Following 7 Users Say Thank You to Smart-gsm For This Useful Post: |
07-08-2014, 10:21 | #6 (permalink) |
Member: 1222089 Status: Offline Sonork: 100.1583019 Thanks Meter: 2,688 | Samsung N7100 NO PRODUCT NAME REPAIR By ATF ATF-V2 All In 1 Ultimate adapter here you can see picture . how we Repair N7100 EMMC N7100_ATF4IN1_V2.jpg hosted at GSMImagehost - GSM Community image sharing ATF_EA_V2_BOOT_1_OK.jpg hosted at GSMImagehost - GSM Community image sharing ATF_EA_V2_BOOT_2_OK.jpg hosted at GSMImagehost - GSM Community image sharing ATF_EA_V2_USER_DATA_OK.jpg hosted at GSMImagehost - GSM Community image sharing ATF_EMMC_Normal_factory_Erase.jpg hosted at GSMImagehost - GSM Community image sharing ATFEMMC.jpg hosted at GSMImagehost - GSM Community image sharing |
The Following User Says Thank You to Smart-gsm For This Useful Post: |
09-17-2014, 12:15 | #8 (permalink) |
Freak Poster Join Date: Dec 2010 Location: Uzbekistan/Jizzakh
Member: 1470188 Status: Offline Sonork: 100.1638921 Thanks Meter: 88 | N7100 Repair boot done via New adaptor! scan erase and writing phone is download mode after boot repairing flashing done Last edited by mastersgsm; 09-17-2014 at 12:24. |
The Following User Says Thank You to mastersgsm For This Useful Post: |
11-03-2014, 12:10 | #11 (permalink) |
Freak Poster Join Date: Jul 2007
Member: 540932 Status: Offline Thanks Meter: 36 | ATF team i have new adopter 4 in one left side horizontal jtag pinout mention with vcc trest tdo tdi etc i need pinout for deadbot repair for nokia xl-rm-1030 in exe i saw green yellow etc plzzzz can u guide me which is vcc trest tdo tdi tck gnd tms |
11-03-2014, 15:32 | #12 (permalink) |
Member: 540932 Status: Offline Thanks Meter: 36 | i got pinout plzzz check tese are ok brown>gnd green>tms red>tck blue>tdi orange>trst and nrst yellow>tdo now i have adopter with this vcc>trst>tdo>tdi>tck>gnd and tms i connect nokia xl rm-1030 connection ok restore boot at 15% stop writing after that i repeat process but got another error check below logs Default language ID 0x0409, LR 12 JTAG Interface Connected, S/N 0x95C40830 Resetting and Exploring JTAG chain...No Devices found in Chain! Loading AFP (Please Wait)...OK AFP revision 4, compiled 9/28/2014 1:10:00 PM ================================================== ======== Phone Type : Nokia XL [RM-1030] CPU Type : Qualcomm MSM8225 Storage TYpe : eMMC 4GB Boot Package : Full Boot Restore Firmware Version: 1.2.3.1 ================================================== ======== 1. Make sure JTAG Connection is 100% OK 2. Always Disconnect the Phone BATTERY 3. Connect USB Cable to Phone 4. Connect RJ-45 JTAG Cable to ATF Box 5. Select the Correct Phone Type RM-XXX 6. Use RESET JTAG button to check the JTAG Connection 7. Click RESTORE BOOT button to Start Boot Repairs ---------------------------------------------------------- Resetting and Exploring JTAG chain...No Devices found in Chain! Resetting and Exploring JTAG chain...No Devices found in Chain! Resetting and Exploring JTAG chain...1 Device(s) Device #1 ID 0x007700E1 IR4 Restore Boot... Waiting for Device Connection 20 second(s)...OK Resetting and Exploring JTAG chain...OK Halting Core...OK Initializing Device...OK Detecting eMMC #1 ID...1501004A3558574D4201E687CEDC4188 Flash Description: Samsung J5XWMB, 3.64 GiB, SN E687CEDC, Apr 1998 Partition Config: Boot from USER, Boot ACK OFF (0x38) Boot Bus Config: x1 SDR, Bus Reset to x1 (0x00) Resetting and Exploring JTAG chain...1 Device(s) Device #1 ID 0x007700E1 IR4 Restore Boot... Waiting for Device Connection 20 second(s)...OK Resetting and Exploring JTAG chain...OK Halting Core...Retry Resetting and Exploring JTAG chain...OK Halting Core...Retry Resetting and Exploring JTAG chain...OK Halting Core...Retry Resetting and Exploring JTAG chain...OK Halting Core...Cannot Halt Core! |
The Following 2 Users Say Thank You to umerfarooq For This Useful Post: |
11-06-2014, 09:20 | #13 (permalink) |
Member: 540932 Status: Offline Thanks Meter: 36 | sleeping tight when awake plzzzzzzzz check my post tell me what is wrong i try all version all version boot files same error>Halting Core...Cannot Halt Core! Resetting and Exploring JTAG chain...1 Device(s) Device #1 ID 0x007700E1 IR4 Restore Boot... Waiting for Device Connection 20 second(s)...OK Resetting and Exploring JTAG chain...OK Halting Core...OK Initializing Device...OK Detecting eMMC #1 ID...1501004A3558574D4201E687CEDC4188 Flash Description: Samsung J5XWMB, 3.64 GiB, SN E687CEDC, Apr 1998 Partition Config: Boot from USER, Boot ACK OFF (0x38) Boot Bus Config: x1 SDR, Bus Reset to x1 (0x00) Resetting and Exploring JTAG chain...1 Device(s) Device #1 ID 0x007700E1 IR4 Restore Boot... Waiting for Device Connection 20 second(s)...OK Resetting and Exploring JTAG chain...OK Halting Core...Retry Resetting and Exploring JTAG chain...OK Halting Core...Retry Resetting and Exploring JTAG chain...OK Halting Core...Retry Resetting and Exploring JTAG chain...OK Halting Core...Cannot Halt Core! |
