01-18-2011, 15:10 | #1 (permalink) |
No Life Poster Join Date: Jan 2007
Member: 433097 Status: Offline Sonork: 100.1661890 Thanks Meter: 8,074 | ATF v6.50 C1-01 RM-607 USB Flashing problem please help me urgent ATF Code: Number of Image Files: 3 Processing Image File : rm607__03.35.mcusw Processing Image File : rm607__03.35.ppm_m_c Processing Image File : rm607__03.35.image_m_c_0595609 AUTO SELECTED DEAD USB FLASHING... If Flashing DOES NOT Start in 5 Seconds, Then Perform Steps 1, 2, 3 and 4... 1. Remove USB and Battery... 2. Insert USB. 3. Insert Battery. (Some phones boot automatically) 4. Please Power on phone shortly.. Infineon USB Boot: F00A1FB300020303010100FF Sending PBL... PBL Successfully Sent... Sending SBL... SBL Successfully Sent... Setting Transmission Speed Done... Flash Chip Manufacturer: Intel Electronics Corp. Flash Boot Successful... Current File : rm607__03.35.mcusw Image Type : Main Firmware Sections : 05 Compile Name: rm607__03.35.mcusw_ebl_psi.fls Data Size : 26217904 Bytes Sending Certificate Block FIRMWARE Certificate Block Sent Successfully... Processing Section 01 of 05 FIRMWARE Erase Block: 0x40000000~0x4001FFFE Start Erasing... Erasing Please Wait... Block Erase Done... Preparing Data Blocks... Data Size: 131072 bytes Data Checksum: A830 Uploading Data Blocks to phone... Block Write Successful... FIRMWARE Data Blocks uploaded to phone... Processing Section 02 of 05 FIRMWARE Erase Block: 0x40040000~0x4007FFFE Start Erasing... Erasing Please Wait... Block Erase Done... Preparing Data Blocks... Data Size: 262144 bytes Data Checksum: 0000 Uploading Data Blocks to phone... Block Write Successful... FIRMWARE Data Blocks uploaded to phone... Processing Section 03 of 05 FIRMWARE Erase Block: 0x40080000~0x4009FFFE Start Erasing... Erasing Please Wait... Block Erase Done... Preparing Data Blocks... Data Size: 131072 bytes Data Checksum: 865C Uploading Data Blocks to phone... Block Write Successful... FIRMWARE Data Blocks uploaded to phone... Processing Section 04 of 05 FIRMWARE Erase Block: 0x400A0000~0x4019FFFE Start Erasing... Erasing Please Wait... Block Erase Done... Preparing Data Blocks... Data Size: 1048576 bytes Data Checksum: 097B Uploading Data Blocks to phone... Block Write Successful... FIRMWARE Data Blocks uploaded to phone... Processing Section 05 of 05 FIRMWARE Erase Block: 0x40400000~0x41BFFFFE Start Erasing... Erasing Please Wait... Block Erase Done... Preparing Data Blocks... Data Size: 24641536 bytes Data Checksum: C5EE Uploading Data Blocks to phone... Block Write Successful... FIRMWARE Data Blocks uploaded to phone... Data Verification Successful... Current File : rm607__03.35.ppm_m_c Image Type : PPM Image Sections : 01 Compile Name: package_m_c.ppm_ebl_psi.fls Data Size : 3254104 Bytes Sending Certificate Block PPM Certificate Block Sent Successfully... Processing Section 01 of 01 PPM Erase Block: 0x41C00000~0x421FFFFE Start Erasing... Erasing Please Wait... Block Erase Done... Preparing Data Blocks... Data Size: 3250760 bytes Data Checksum: 932D Uploading Data Blocks to phone... Block Write Successful... PPM Data Blocks uploaded to phone... Data Verification Successful... Current File : rm607__03.35.image_m_c_0595609 Image Type : CONTENT Package Sections : 01 Compile Name: package_m_c_0595609.image.fls Data Size : 11799824 Bytes Sending Certificate Block CONTENT Certificate Block Sent Successfully... Processing Section 01 of 01 CONTENT Erase Block: 0x42200000~0x43E5FFFE Start Erasing... Erasing Please Wait... Block Erase Done... Preparing Data Blocks... Data Size: 11796480 bytes Data Checksum: E48A Uploading Data Blocks to phone... Block Write Successful... CONTENT Data Blocks uploaded to phone... Data Verification Successful... |
01-18-2011, 15:23 | #3 (permalink) | |
No Life Poster Join Date: Oct 1999 Location: Shenzhen, Hong Kong, Bangkok
Member: 611 Status: Offline Sonork: 100.33333 Thanks Meter: 29,604 | Quote:
Check LCD, see if fail. If LCD fail then this phone can't be factory reset need replace LCD then can do. Thank tips from WAJID. BR Thomas | |
01-18-2011, 15:51 | #5 (permalink) |
No Life Poster Join Date: Dec 2007
Member: 651945 Status: Offline Thanks Meter: 20,118 | @kabul Actually can Factory Reset even if phone is in Normal Mode. Give it a Try :O) Also Lifetimer is ok in Normal Mode B/R |
The Following User Says Thank You to Advance-Box For This Useful Post: |
01-18-2011, 15:52 | #6 (permalink) | |
No Life Poster Join Date: Nov 2007 Location: Dubai.
Member: 625961 Status: Offline Sonork: 100.1590447 Thanks Meter: 1,285 | Quote:
change LCD it wil b done , tested by me , i did tested two mobiles ,if LCD not good ,phone doesnt get Factory Settings @all. some time MMC also make this if Phone inside MMC while Flashing.. Br, WAJID | |
The Following User Says Thank You to WAJID PNR For This Useful Post: |
01-20-2011, 07:01 | #11 (permalink) |
No Life Poster Join Date: Apr 2007 Location: nothing
Member: 494167 Status: Offline Thanks Meter: 292 | here is full log it stop at 25% i use latest version 1. Remove USB and Battery... 2. Insert USB. 3. Insert Battery. (Some phones boot automatically) 4. Please Power on phone shortly.. Infineon USB Boot: F00A1FB300020503010100FF Sending PBL... PBL Successfully Sent... Sending SBL... SBL Successfully Sent... Setting Transmission Speed Done... Flash Chip Manufacturer: Intel Electronics Corp. Flash Boot Successful... Current File : rm607__03.35.mcusw Image Type : Main Firmware Sections : 05 Compile Name: rm607__03.35.mcusw_ebl_psi.fls Data Size : 26217904 Bytes Sending Certificate Block FIRMWARE Certificate Block Sent Successfully... Processing Section 01 of 05 FIRMWARE Erase Block: 0x40000000~0x4001FFFE Start Erasing... Erasing Please Wait... Block Erase Done... Preparing Data Blocks... Data Size: 131072 bytes Data Checksum: A830 Uploading Data Blocks to phone... b4 phone power on only nokia and then whit scree.and after this phone completly dead |
01-20-2011, 10:02 | #12 (permalink) |
Member: 651945 Status: Offline Thanks Meter: 20,118 | everytime you flash, it hang at 25% ??? I have 2 pieces C1-01 and both of them 100% ok all the time. Check the problem could be on your side. A customer from saudi arabia already reported 200 units flashed successfully (and still counting). |
01-20-2011, 10:14 | #13 (permalink) | |
check inside memory card while flashing mobile, if hav remove memory card then try . connect usb direct from pc(dnt use usb hub). post result i did flashed many c1-01 till nw.. Br. WAJID | |
01-22-2011, 11:52 | #15 (permalink) | |
check there is any error, if nt its phone prblm if same check flash file . i did done more than 25pices still doin without any error........ br WAJID | |
need to flash 6110 | paulomt1 | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 2 | 08-16-2019 19:37 |
5110 flash new software , need help | steve | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 4 | 01-03-2015 05:41 |
HELP: Problem with 5110 | Xabi | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 1 | 07-16-1999 00:44 |
