Go Back   GSM-Forum > Product Support Sections > Hard/Software Products (official support) > Advance-Box
Old 10-24-2010, 12:20   #1 (permalink)
Member: 1421153
atf on vista?
doee anybody know if atf works on windows vista?
Old 10-24-2010, 12:25   #2 (permalink)
..::Angel::..'s Avatar
Member: 643472
Sonork: 100.96901
Hello!
Yes is supported on vista.
The Following User Says Thank You to ..::Angel::.. For This Useful Post:
Old 10-25-2010, 14:38   #3 (permalink)
Member: 1421153
Thanks angel, can i flash dct4 on atf also?
what about unlocking dc4 and bb5?
or is this software specifically for flashing only?
i am willing to buy this software just need these few question answerd.
Old 10-25-2010, 14:43   #4 (permalink)
Member: 643472
Sonork: 100.96901
Hello!
You can use all supported features on vista and all latest releases version.
DCT4 unlocking is FREE - one click!
Flash is super fast for all BB5 and DCT4 phones.
Old 10-25-2010, 17:11   #5 (permalink)
Member: 1421153
wat about bb5 unlocking n73 6300 etc
Old 10-25-2010, 17:35   #6 (permalink)
Member: 643472
Sonork: 100.96901
Hello!
Yes, its supporetd also!
Old 10-25-2010, 17:40   #7 (permalink)
Member: 1421153
Thank you angel for your help, i will go out and buy atf..
I hope support it also good.
Regards.
Old 10-26-2010, 05:30   #8 (permalink)
dharyadi's Avatar
Member: 369678
windows 7 also support. tested.
Old 10-26-2010, 09:17   #9 (permalink)
Member: 643472
Sonork: 100.96901
Hello!
Windows 7 32bit and 64bit both are supported.
Old 10-26-2010, 19:45   #10 (permalink)
Member: 1421153
is dct4+ supported on atf??
Old 10-26-2010, 20:40   #11 (permalink)
Member: 1421153
ok i see you can do it
how i can unlock 1661-2 RH-122 spain movistar with calculate codes
great box guys
Old 10-27-2010, 10:50   #12 (permalink)
Member: 643472
Sonork: 100.96901
Yes all DCT4 phones are supported.
Old 10-27-2010, 11:01   #13 (permalink)
Member: 943187
why i cant put mcu 1650 and dct4 models in atf? i cant locate the mcu file, but i try jaf theres no problem i can flash.
Old 10-27-2010, 11:24   #14 (permalink)
Member: 643472
Sonork: 100.96901
Hello!
If you can please post screen-shot of error, would be easier to check!
Old 10-27-2010, 21:10   #15 (permalink)
Member: 1421153
just installed atf, looks phone but i get this:
ATF Box is not in USB 2.0 Mode
* Go to "Product Support" tab and click the
* "Restore Box" Button to fix the Box Firmware
** If Problem is Not Solved...
1. Make Sure you are NOT using USB HUBS
2. Make Sure your USB port is USB 2.0
3. Make Sure you are using the latest Drivers
*** If Problem is STILL Not Solved
1. Use a THICKER USB Cable
2. Connect ATF Directly to the Root USB Port
3. Uninstall Drivers, Reboot PC, Reinstall
**** If you are still Stuck...
1. Search your entire PC for "ftdibus.sys
2. Delete all "ftdibus.sys" files you find
3. Reboot PC...
4. Disconnect ATF Box and all Boxes from PC
5. Run C:\AdvanceBox Turbo Flasher\Driver\Remove_ATF_Drivers\Remove_ATF_Drive rs.bat
6. ReInstall ATF Software
7. Connect ATF Box Only to your USB Port
8. Install the Correct Drivers
my question is its asking me atf box is not in usb mode does the box have to be in usb mode?
6110 power does not stay on sc~micro Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) 5 04-10-2013 02:07
what prog changes imei on 6110 and how do i do it? Ravetrancer Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) 3 07-31-2012 20:09
FREECALL HACKED SIMS ON SALE FROM FREECELL! FREECELLUK Main Sales Section 0 07-07-1999 23:22
Page generated in 0.64294 seconds with 11 queries
