08-27-2014, 05:58 | #1 (permalink) |
Insane Poster Join Date: Oct 2012 Location: Technology city
Member: 1823012 Status: Offline Thanks Meter: 10 | Atf where is problem |
08-27-2014, 21:41 | #3 (permalink) |
Freak Poster Join Date: Oct 2004 Location: Argentina Age: 48
Member: 86865 Status: Offline Thanks Meter: 30 | Hi, I have a dead lumia 520 rm-915, I repaired boot with ATF JTAG, but noe phone only vibrates, and pc donīt recognizes, here is the log: Default language ID 0x040A JTAG Interface Connected, S/N 0xFAxxxxxx Resetting and Exploring JTAG chain...No Devices found in Chain! Loading AFP (Please Wait)...OK AFP revision 4, compiled 25/06/2014 22:44:00 ================================================== ======== Phone Type : Lumia 520 RM-915 CPU Type : Qualcomm MSM8227 Storage Type: eMMC 8GB Boot Package: 3056.40000.1402.0008 (BIG BOOT) ================================================== ======== 1. Make sure JTAG Connection is 100% OK 2. Always Disconnect the Phone BATTERY 3. Connect USB Cable to Phone 4. Connect RJ-45 JTAG Cable to ATF Box 5. Select the Correct Phone Type RM-XXX 6. Use RESET JTAG button to check the JTAG Connection 7. Click RESTORE BOOT button to Start Boot Repairs ---------------------------------------------------------- Restore Boot... Waiting for Device Connection 15 second(s)...OK Resetting and Exploring JTAG chain...OK Halting Core...OK Initializing Device...OK Detecting EMMC #1 ID...90014A4838473264040100D7D6471118 Flash Description: Hynix H8G2d, 7.23 GiB, SN 00D7D647, Jan 1998 Partition Config: Boot from USER, Boot ACK OFF (0x38) Boot Bus Config: x1 SDR, Bus Reset to x1 (0x00) Testing Device Memory...OK Sending Flash Loader...OK (6025 Op/Sec) Restoring MBR Data...OK Restoring GPT Data from AFP...OK Restoring Partition #1...OK Restoring Partition #2...OK Restoring Partition #3...OK Restoring Partition #4...OK Restoring Partition #5...OK Restoring Partition #6...OK Restoring Partition #7...OK Restoring Partition #8...OK Restoring Partition #9...OK Restoring Partition #10...OK Completed in 0h 17m 25s. Code Download Speed 166 KiB/sec. Boot Restore Done! ================================================== =========== Assemble Phone and Start Normally If Phone cannot Start, perform USB Firmware Update Procedure ================================================== =========== |
08-28-2014, 04:29 | #4 (permalink) |
No Life Poster Join Date: Dec 2007
Member: 651945 Status: Offline Thanks Meter: 20,118 | @mdpm Are you sure your phone is RM-915 ? If so, just charge the battery using another phone. When phone battery is fully charged, you can now flash it. Make sure JTAG wires are already removed before you flash phone via USB. B.R. |
