ATF and Windows 7 32-bit / Windows 7 64-bit Hi, If you encountered some issues using Advance Turbo Flasher in windows 7 (win7) Please use the image below for your reference http://www.advance-box.com/images/wi...patibility.jpg BR ATF |
not working on x64.... exe keep on crashing.... will try if its on my system.... |
@Jhay-r Try Tip # 2 http://forum.gsmhosting.com/vbb/f609...lume-i-951331/ I am using Win7 64-bit. B.R. X-Shadow |
hi: where are win 7 drivers? tnks |
It is inside the C:\Advancebox Turbo Flasher\Driver\ATF_NEW_DRIVERS BR Thomas |
Turbo Flash ATF Thanks |
Thank you very much for the wonderful topic |
Thank you thank you...... |
Windows 7 64 bit Ultimate runs perfect, without marking anything, just installed and did run. |
win7 64 bit work great work for me... only this box for nokia work in win7 64 bit other boxes not work .... thanks atf team b.r senkron24 |
yes atf is my best choice for work in win7 64bits long time ago . |
[QUOTE=frozenice;5491744]Hi, If you encountered some issues using Advance Turbo Flasher in windows 7 (win7) Please use the image below for your reference http://www.advance-box.com/images/wi...patibility.jpg Where i can find this window in w7? |
@Blueteamgsm Rightmouse click on ATF program icon on your desktop. Go to compatibility tab.;) |
yes atf is my best choice for work in win7 64bits long time ago . thanks ATF team |
