06-13-2015, 17:49 | #1 (permalink) |
No Life Poster Join Date: Jan 2006 Location: could'nt found yet
Member: 223973 Status: Offline Thanks Meter: 155 | atf wont detect by pc BR K@mi |
06-15-2015, 16:35 | #6 (permalink) |
Member: 223973 Status: Offline Thanks Meter: 155 | it wont help .... pc wont detect the box ...usb device not recognize thats what i got... what i have done so far 1.it was old pcb so i modify it didnt help just status changed now blue green orange leds are on. 2.remove eeprom remain same 3.change usb connector wont help either Br |
06-28-2015, 11:26 | #9 (permalink) | |
No Life Poster Join Date: Apr 2011 Age: 58
Member: 1564612 Status: Offline Thanks Meter: 12,343 | Quote:
BR allumts | |
07-01-2015, 12:21 | #12 (permalink) |
Member: 1564612 Status: Offline Thanks Meter: 12,343 | Hi you Atf Big had the "Modified PCB" or you have Write Fw for Atf Big with "Modified PCB" having "Normal Pcb"...this not understand. If you Big Atf had Normally PCB try to Restore Eeprom selecting "Normal PCB" otherwise if is "Modified PCB" try to rewrite Fw for "MODIFIED PCB" then restore Eeprom Selecting this type of Pcb, Update Fw and Install Drivers. |
07-01-2015, 12:55 | #13 (permalink) |
Member: 223973 Status: Offline Thanks Meter: 155 | ahhh you don't understand my problem sir .... how can I restore the box when its not detected by computer ?? m asking for help regarding usb connection between computer and box hope u understand now . Br |
