05-31-2014, 15:23 | #1 (permalink) |
No Life Poster Join Date: Oct 1999 Location: Shenzhen, Hong Kong, Bangkok
Member: 611 Status: Offline Sonork: 100.33333 Thanks Meter: 29,604 | ATF WP8.1, SPI, Android and Samsung JTAG v11.45 Update!! Public Discussion Thread: Firmware Version Required : 11.0.00 ATF Box USB Driver Required: 2.10.0.0 Download ATF 11.45 via the AUTOUPDATE SERVER!!! Quick for Nokia X, X+ and XL Flashing New method of BACKUP/RESTORE IMEI/SIMLOCKS fully Compatible with Nokia X+ and XL (Requires ROOT). WARNING: ATF DOES NOT USE ADB.EXE or FASTBOOT.EXE. Please make sure that ADB.exe or FASTBOOT.exe are not RUNNING before trying to ROOT your Phone because ATF will automatically close ADB.exe and FASTBOOT.exe even if you are still busy flashing an HTC Phone or doing some other Android Tweaks via ADB... Release Date: June 4, 2014 Firmware Version Required : 11.0.00 ATF Box USB Driver Required: 2.10.0.0 Download ATF 11.41 via the AUTOUPDATE SERVER!!! Nokia Android Root Kit 1.2 Universal ROOT Method For Nokia X, X+ and XL Tested On: Nokia X Firmware: ----> 10.0.3 ----> 11.11.1 ----> 1.1.2.2 ----> 1.1.3.20 (REVISION 2) Nokia X+ Firmware: ----> 1.1.0.2 Nokia XL Firmware: ----> 1.1.0.6 ----> 1.1.1.0 (STOCK) ----> 1.1.2.20 (REVISION 2) WARNING: ATF DOES NOT USE ADB.EXE or FASTBOOT.EXE. Please make sure that ADB.exe or FASTBOOT.exe are not RUNNING before trying to ROOT your Phone because ATF will automatically close ADB.exe and FASTBOOT.exe even if you are still busy flashing an HTC Phone or doing some other Android Tweaks via ADB... For this Update, we give Credits to: ----> Chainfire - author of SuperSU.zip ----> dhacker29 - author of TWRP for Nokia Android ----> Dee Troy - author of TWRP Release Date: May 31, 2014 Firmware Version Required : 11.0.00 ATF Box USB Driver Required: 2.10.0.0 Lumia WP 8.1 + Nokia Android + SPI Programmer + Samsung JTAG Nokia Lumia WP 8.1 by Microsoft Initial Support --> Updated Windows Phone Flashing Module to support Lumia 630 and 635 --> Updated Windows Phone Normal Mode Module to Support Lumia 630 and 635 --> Fully tested on Actual Lumia 630 Test Phone --> Test Mode Functions for Lumia 630 and 635 is still not Supported Nokia Android Firmware Flasher for X/X+/XL Updated --> Fixed Flash Error "62%" when using older WinUSB Drivers --> Warns End User when REVISION 2 Flash Files are detected --> Fully tested on Actual Nokia X, X+ and XL Actual Test Phones ATF JTAG 1.0.8 --> Added Built-In AFP File Downloader inside ATFJ.exe --> You can access it through "Help" ---> "Updates" --> Support added for Samsung Phones FULL BOOT Repair --> (Download then via the Built-in ATFJ.exe Downloader) Samsung GT-I8150 Samsung GT-I8150B Samsung GT-I8150T Samsung GT-I8260 Samsung GT-I8260E Samsung GT-I8260L Samsung GT-I8262 Samsung GT-I8262B Samsung GT-I8262D Samsung GT-I8350 Samsung GT-I8550L Samsung GT-I8550E Samsung GT-I8552 Samsung GT-I8552B Samsung GT-I8700 Samsung GT-S6310 Samsung GT-S6310L Samsung GT-S6310N Samsung GT-S6310T Samsung GT-S6312 Samsung GT-S7560 Samsung GT-S7560M Samsung GT-S7562 Samsung GT-S7562L Samsung GT-S7572 Samsung SCH-W789 Samsung SCH-I829 Samsung SGH-T679 Samsung SGH-T679M --> Added ATF JTAG Scripting Language Supports Manual Debugging of Snapdragon SOC Modem Core --> Initial Documentation Released --> http://www.advance-box.com/jtag/ATF_...ING_MANUAL.pdf SPI Tool 1.0 Initial Release --> Direct In Circuit Programming for Small SPI Flash ICs --> NO NEED to remove SPI Flash from PCB --> Ideal for Nokia 105 and 106 Direct SPI Flash Programming --> Ideal for HUAWEI WiMax Modem SPI Reprogramming --> Read/Write Speeds upto 30 Mhz --> Supports CPOL=0, CPHA=0 and CPOL=1, CPHA=1 SPI Modes --> Auto Verify and Auto Rewrite Corrupted Sectors --> Selectable VCCIO Voltage (1.80v, 2.80v and 3.30v) --> Selectable Instruction Set according to SPI Flash IC Brand --> Automatically Detects Flash IC Capacity for Micron/Numonyx --> Automatically Skips IMEI, Simlocks and PM Region of Nokia 105 and 106 * When used with Nokia 105 and 106, you can: ----> Read Full Dump from 100% Working Phone and write it to another phone without damaging the IMEI, Simlocks and PM Region. ----> Write MCU+PPM+CNT, or just PPM+CNT or just PPM only ----> Allows Cross Version PPM Files to be written on any MCU Firmware Version ----> Now you can write your prefered BIG Language Packs which was not supported in FBUS ----> You can read FULL DUMP via FBUS and write it to other phones via SPI Tool [SD Card Password Bruteforce Update] --> Fixed Resume File Saving when CSD was Invalid --> Added Support for UHS-I and UHS-II SD Cards [Samsung Unbrick Image Creator 1.5] --> Added Support for newer 4.4.x tar.md5 2014 Flash Files --> Added Support for newer PIT Factory Files [ATF Box Driver Update] --> New ATF Box Signed Drivers for 32/64 Bit Windows XP, 7, 8 and 8.1 (Version 2.10.0.0) --> If you are using Windows 7 or Windows 8, the Drivers will be Downloaded Automatically via Windows Driver Update Servers [General Updates] --> Complete Product Listing in Nokia.ini as of May 31, 2014 (Nokia X+, Nokia XL, Lumia 630, Lumia 635 and Lumia 930 were added) Who will buy this if you can get more in ATF? __________________________________________________ ________________________ DOWNLOAD HERE: ATF WP8.1, SPI, Android and Samsung JTAG v11.40 Update!! Public Discussion Thread: http://forum.gsmhosting.com/vbb/f609...hread-1806648/ Buy only from ATF [Advance Turbo Flasher] authorized resellers: ATF [Advance Turbo Flasher] Authorized Distributors and Resellers List ATF [Advance Turbo Flasher] official web sites: International - http://www.advance-box.com/ ATF [Advance Turbo Flasher] official support forums: World Wide: Advance Turbo Flasher - GSM-Forum Indonesia: ATF (Advance Turbo Flasher)) Philippine: Gsmph Syria: Arabic Support (Syria) GsmVIP Chinese support forum : ATF Box Vietnam: Saigonmobile India: Advance Box - .:: GsmIndia ::. Official Iran Support Forum : ASANGSM FORUM Bangladesh: Advance Box - Dhaka Mobile Chinese Support forum : www.yananliuhuan.com The Master Piece Last edited by Advance-Box; 06-20-2014 at 08:14. |
The Following 69 Users Say Thank You to gsmfun For This Useful Post: |
05-31-2014, 15:31 | #3 (permalink) |
No Life Poster Join Date: Dec 2006 Location: Karachi, Pakistan Age: 33
Member: 643472 Status: Offline Sonork: 100.96901 Thanks Meter: 16,589 | Samsung GT-I8262 Boot Repaired with ATFJTAG - Repairing Boot with ATFJ.exe v1.0.8: - Boot Repaired successfully, Download Mode - VOL DOWN + HOME + POWER: - Flashing with Odin3: - Profit |
The Following 36 Users Say Thank You to ..::Angel::.. For This Useful Post: |
05-31-2014, 15:56 | #5 (permalink) |
Member: 643472 Status: Offline Sonork: 100.96901 Thanks Meter: 16,589 | Read release note pls: Code: Nokia Android Firmware Flasher for X/X+/XL Updated --> Fixed Flash Error "62%" when using older WinUSB Drivers --> Warns End User when REVISION 2 Flash Files are detected --> Fully tested on Actual Nokia X, X+ and XL Actual Test Phones |
The Following User Says Thank You to ..::Angel::.. For This Useful Post: |
05-31-2014, 16:17 | #7 (permalink) |
Freak Poster Join Date: Jan 2010 Age: 14
Member: 1214273 Status: Offline Thanks Meter: 136 | http://www.advace-box.com/jtag/ATF_J...ING_MANUAL.pdf does not work |
The Following User Says Thank You to online-nokia For This Useful Post: |
05-31-2014, 16:18 | #8 (permalink) |
No Life Poster Join Date: Mar 2011 Location: Pars Abad Age: 37
Member: 1541831 Status: Offline Sonork: 100.1620784 Thanks Meter: 141 | Hi ,plz add support for Nokia MTK chip phone....thanks to great TeAm!!! |
The Following User Says Thank You to Reza2010 For This Useful Post: |
05-31-2014, 16:25 | #9 (permalink) | |
Member: 643472 Status: Offline Sonork: 100.96901 Thanks Meter: 16,589 | Quote:
BR | |
05-31-2014, 16:37 | #10 (permalink) |
Member: 643472 Status: Offline Sonork: 100.96901 Thanks Meter: 16,589 | Yup, more Samsung and other brands Jtag update to come... List of supported models via ATF JTAG that costs only 39$ activation. http://forum.gsmhosting.com/vbb/10010275-post35.html You won't find JTAG tool on this price! :O) BR Last edited by ..::Angel::..; 05-31-2014 at 16:46. |
The Following 4 Users Say Thank You to ..::Angel::.. For This Useful Post: |
05-31-2014, 16:43 | #11 (permalink) |
Insane Poster Join Date: Jul 2008
Member: 806045 Status: Offline Sonork: 91871172 Thanks Meter: 11 | please fix link http://www.advace-box.com/jtag/ATF_J...ING_MANUAL.pdf i think n in adva N ce is missing but with the adding still cant access the file |
The Following 3 Users Say Thank You to gate36 For This Useful Post: |
05-31-2014, 16:49 | #12 (permalink) | |
BR | |
The Following 2 Users Say Thank You to ..::Angel::.. For This Useful Post: |
05-31-2014, 19:36 | #15 (permalink) | |
No Life Poster Join Date: Apr 2011 Age: 58
Member: 1564612 Status: Offline Thanks Meter: 12,343 | Quote:
ATF JTAG 1.0.8 --> Added Built-In AFP File Downloader inside ATFJ.exe --> You can access it through "Help" ---> "Updates" --> Support added for Samsung Phones FULL BOOT Repair --> (Download then via the Built-in ATFJ.exe Downloader) Br allumts | |
The Following 10 Users Say Thank You to allumts For This Useful Post: |
