01-21-2014, 08:05 | #1 (permalink) |
Freak Poster Join Date: Dec 2008 Location: PH/Singapore/Malaysia
Member: 923652 Status: Offline Sonork: 1601428 Thanks Meter: 89 | ATFJTAG Clear pic for I9300 emmc repair Trouble: After Update to 4.3 I9300XXELLA_IDEELL1 China firmware phone status : SAMSUNG LOGO BLINK OR RESTART Download mode working BUT! Cannot flash error Fullflash,boot and Repair efs cannot write So i think atf samsung live phone will repair my i9300 Already did Via memory card solution (boot repair) i need repair emmc for my i9300 and pinout for atfjtag correct this image if this is wrong pinout thanks atfjtag team |
The Following 4 Users Say Thank You to ilaw For This Useful Post: |
11-09-2014, 20:24 | #5 (permalink) | ||
No Life Poster Join Date: Apr 2011 Age: 58
Member: 1564612 Status: Offline Thanks Meter: 12,343 | Only with BIG ATF you can use PIN2 from RJ45 cable, for Nitro you have need 4 in 1 adapter or....warranty itc.. bye bye can Modific Pcb of Atf Nitro. Quote:
Br allumts Last edited by allumts; 11-09-2014 at 20:30. | ||
12-21-2014, 14:38 | #7 (permalink) |
Member: 1564612 Status: Offline Thanks Meter: 12,343 | @One_Hermit, this modified RJ45 cable working ONLY with Atf Big box, no light or nitro. You can try to repair "No P.Name" with eMMc direct Jtag, but have need also all .bin files for this model, use Atf Support Area for this. If you NOT have Atf Big box you must need adapter 4 in 1 Find all in Sticky thread... BR allumts |
12-21-2014, 14:55 | #8 (permalink) |
Freak Poster Join Date: Oct 2014 Location: India
Member: 2282226 Status: Offline Thanks Meter: 52 | thanks for reply i have atf big box but i9300 emmc repair file not found @ ATF Offcial Support Area > please give link for this if you have i dont have 4in1 adaptor and no reseller available at my area [gujarat-india] |
12-21-2014, 15:30 | #9 (permalink) |
Member: 1564612 Status: Offline Thanks Meter: 12,343 | If have Atf Big box can use the diagram above, no need adapter. For eMMc file I9300 i not remember now where are posted, can use search button or when i've a little of time i upload this, not are sure when... not are in my shop now. BR allumts |
12-23-2014, 13:59 | #11 (permalink) |
Member: 2282226 Status: Offline Thanks Meter: 52 | now came this error : http://forum.gsmhosting.com/vbb/10142501-post54.html not sure given pinouts are ok or not @ 1st post of this thread |
12-23-2014, 14:46 | #12 (permalink) | |
Member: 1564612 Status: Offline Thanks Meter: 12,343 | Quote:
In 99% of case you error is eMMc damaged. Can try changing only Power IC ant try if can revive if not work must need replace eMMc BR allumts | |
12-23-2014, 14:53 | #13 (permalink) | |
The error in link is other type of error, can be long wires or other issue, but in above screen ERROR sayd id eMMc damaged BR allumts | |
