nokia c1-01 was freezing.
i flashed d set.
Number of Image Files: 3
Processing Image File :
rm607__06.20.mcusw
rm607__06.20.ppm_c
rm607__06.20_009.image_c_voda_nl_9f7c8
AUTO SELECTED DEAD USB FLASHING...
If Phone Booting does not Start in 5 Seconds,
Then Perform Steps 1, 2, 3 and 4...
1. Remove USB and Battery...
2. Insert USB.
3. Insert Battery. (Some phones boot automatically)
4. Please Power on phone shortly...
Infineon USB Boot: F00A1FB300020303010100FF
Sending PBL...
PBL Successfully Sent...
Sending SBL...
SBL Successfully Sent...
Setting Transmission Speed Done...
Flash Chip Manufacturer: Samsung Electronics Corp.
Flash Boot Successful...
Unique Data: 120008090A16182D
Original Product Code: 0596389
Reading : CCC... OK!
Reading : HWC... OK!
Reading : NPC... OK!
RPL Backup was Successful...
Plain RPL saved to:
C:\AdvanceBox Turbo Flasher\Nokia\Backup\352842058595777\3528420585957 77_051151.rpl
Certificate Block Saved to:
C:\AdvanceBox Turbo Flasher\Nokia\Backup\352842058595777\3528420585957 77_CERTIFICATE_3DA367E3.bin
PM Block Saved to:
C:\AdvanceBox Turbo Flasher\Nokia\Backup\352842058595777\3528420585957 77_PMM_PROT_7AA23817.bin
Security Code: 12345
Data Sections : 05
Current File : rm607__06.20.mcusw
Compile Name: rm607__06.20.mcusw_ebl_psi.fls
Image Type : Main Firmware
Data Size : 26217904 Bytes
Sending Certificate Block
FIRMWARE Certificate Block Sent Successfully...
Processing Section 01
FIRMWARE Erase Block: 0x40000000~0x4001FFFE
Start Erasing...
Erasing Please Wait...
Block Erase Done...
Preparing Data Blocks...
Data Size: 131072 bytes
Data Checksum: 9899
Uploading Data Blocks to phone...
Block Write Successful...
FIRMWARE Data Blocks uploaded to phone...
Processing Section 02
FIRMWARE Erase Block: 0x40040000~0x4007FFFE
Start Erasing...
Block Erase Done...
Data Size: 262144 bytes
Data Checksum: 0000
Processing Section 03
FIRMWARE Erase Block: 0x40080000~0x4009FFFE
Start Erasing...
Block Erase Done...
Data Checksum: 865C
Processing Section 04
FIRMWARE Erase Block: 0x400A0000~0x4019FFFE
Start Erasing...
Block Erase Done...
Data Size: 1048576 bytes
Data Checksum: 835A
Processing Section 05
FIRMWARE Erase Block: 0x40400000~0x41BFFFFE
Start Erasing...
Block Erase Done...
Data Size: 24641536 bytes
Data Checksum: 8BA5
Data Sections : 01
Current File : rm607__06.20.ppm_c
Compile Name: package_c.ppm_ebl_psi.fls
Image Type : PPM Image
Data Size : 3906280 Bytes
PPM Certificate Block Sent Successfully...
PPM Erase Block: 0x41C00000~0x421FFFFE
Start Erasing...
Block Erase Done...
Data Size: 3902936 bytes
Data Checksum: F610
PPM Data Blocks uploaded to phone...
Data Verification Successful...
Data Sections : 01
Current File : rm607__06.20_009.image_c_voda_nl_9f7c8
Compile Name: package_c_voda_nl.image.fls
Image Type : CONTENT Package
Data Size : 13896976 Bytes
CONTENT Certificate Block Sent Successfully...
CONTENT Erase Block: 0x42200000~0x43E5FFFE
Start Erasing...
Block Erase Done...
Data Size: 13893632 bytes
Data Checksum: 192F
CONTENT Data Blocks uploaded to phone...
CONTENT Erase Block: 0x43E60000~0x43F3FFFE
Start Erasing...
Block Erase Done...
Total Flashing Time (Erase + Flashing) : 00:02:39
(Booting time is NOT Included)
Waiting for Phone to Start-Up..(Max 150 seconds)
Selected VPL File:
RM607_059F7C8_06.20_009.vpl
Variant Details : RM-607 VAR EURO-C NL VODA SL WGRAY
Software Version : 06.20
Product Type : RM-607
Product Code : 059F7C8
Variant Version : 009
FACTORY SET TO : Full Factory Set
OK
FACTORY SET TO : User Data
OK
FACTORY SET TO : Leave Factory
OK
FACTORY SET TO : Service Center
OK
FACTORY SET TO : Software Upgrade
OK
FACTORY SET TO : Production Tune
OK
RESET LIFE TIMER TO : 0000:00
OK
after flashing device works for a while then goes blank white display.
