10-22-2015, 10:58 | #91 (permalink) |
No Life Poster Join Date: Sep 2006 Location: InTheSky
Member: 355613 Status: Offline Sonork: 100.1674359 Thanks Meter: 170 | Library Version : 00030207 Box Type : ATF Lightning Box Firmware : LogiCore 11.0.10 Software Version : v12.40 AdvanceBox SN : D849DA11CA8B0D72E3EF4C4A Box Status : NOT ACTIVATED |
10-23-2015, 21:56 | #92 (permalink) |
Major Poster Join Date: Sep 2007 Location: egypt
Member: 579107 Status: Offline Thanks Meter: 20 | Driver Version : 00021000 Library Version : 00030207 Box Type : ATF Lightning Box Firmware : LogiCore 11.0.10 Software Version : v12.40 AdvanceBox SN : 9418EB83834E6A1DFC8DB1D8 Box Status : NOT ACTIVATED |
11-03-2015, 09:41 | #100 (permalink) |
Junior Member Join Date: Jan 2014
Member: 2114238 Status: Offline Sonork: ramco_tr Thanks Meter: 0 | ================================================ Advance Turbo Flasher Found ================================================ Driver Version : 00021000 Library Version : 00030207 Box Type : ATF Lightning Box Firmware : LogiCore 11.0.10 Software Version : v12.40 AdvanceBox SN : E91586F9CF47A953D2631A09 Box Status : NOT ACTIVATED ================================================ Please Activate your Box ================================================ * Follow these Instructions 1. Disconnect any phones connected to ATF Box 2. Go to "Product Support Tab" 3. Go to "Box Tools" Section 4. Fill in the Required Information 5. Click "Activate Box" button ================================================ Box Successfully Initialized ================================================ |
11-05-2015, 06:15 | #101 (permalink) |
Freak Poster Join Date: Feb 2013 Location: algeria
Member: 1882414 Status: Offline Sonork: 21000 Thanks Meter: 28 | my atf netro is activated (jetag) last yares 2014 and ai work with heur mor than 50 times and today show mes tis Checking ATF JTAG Activation from Server...ATF Box Not Activated for JTAG. Checking ATF JTAG Activation from Server...ATF Box Not Activated for JTAG. Checking ATF JTAG Activation from Server...ATF Box Not Activated for JTAG. Checking ATF JTAG Activation from Server...ATF Box Not Activated for JTAG. Checking ATF JTAG Activation from Server...Impossible d'établir une connexion avec le serveur * Default language ID 0x0409 JTAG Interface Connected, S/N 0xFC04162A Resetting and Exploring JTAG chain...No Devices found in Chain! Default language ID 0x0409 JTAG Interface Connected, S/N 0xFC04162A Resetting and Exploring JTAG chain...No Devices found in Chain! Loading AFP (Please Wait)...OK AFP revision 4, compiled 5/25/2014 6:53:00 PM ================================================== ======== Phone Type : Samsung GT-S7562 CPU Type : Qualcomm MSM7227A Storage TYpe : eMMC 4GB Boot Package : Full Boot Restore (4.0.4) ================================================== ======== 1. Make sure JTAG Connection is 100% OK 2. Phone BATTERY should be CONNECTED!!! 3. Connect RJ-45 JTAG Cable to ATF Box 4. Connect USB Cable to the Phone 5. Click RESET JTAG button to check JTAG Connection 6. Click RESTORE BOOT button to Start Operation ---------------------------------------------------------- Restore Boot... Waiting for Device Connection 20 second(s)...Timeout During Operation! Loading AFP (Please Wait)...OK AFP revision 4, compiled 6/10/2014 1:23:00 PM ================================================== ======== Phone Type : Nokia XL [RM-1030] CPU Type : Qualcomm MSM8225 Storage TYpe : eMMC 4GB Boot Package : Full Boot Restore Firmware Version: 1.1.1.0 ================================================== ======== 1. Make sure JTAG Connection is 100% OK 2. Always Disconnect the Phone BATTERY 3. Connect USB Cable to Phone 4. Connect RJ-45 JTAG Cable to ATF Box 5. Select the Correct Phone Type RM-XXX 6. Use RESET JTAG button to check the JTAG Connection 7. Click RESTORE BOOT button to Start Boot Repairs ---------------------------------------------------------- Loading AFP (Please Wait)...OK AFP revision 4, compiled 7/20/2014 12:07:00 AM ================================================== ======== Phone Type : Samsung SGH-M919N - Galaxy S4 CPU Type : Qualcomm APQ8064AB Storage Type: eMMC Size: OPEN (16GB, 32GB, 64GB) Boot Package: Android 4.3 - M919NUVUEMK5 ================================================== ======== 1. Make sure JTAG Connection is 100% OK 2. Always Disconnect the Phone BATTERY 3. Connect USB Cable to Phone 4. Connect RJ-45 JTAG Cable to ATF Box 5. Select the Correct Phone Type RM-XXX 6. Use RESET JTAG button to check the JTAG Connection 7. Click RESTORE BOOT button to Start Boot Repairs ---------------------------------------------------------- and in 2015 ATF JTAG v1.0.15.8544 (17/06/2015) Default language ID 0x040C, LR 14 JTAG Interface Connected, S/N 0xFC04162A Resetting and Exploring JTAG chain...No Devices found in Chain! Loading AFP (Please Wait)...OK AFP revision 4, compiled 26/11/2013 10:48:00 ================================================== ======== Phone Type : Lumia 610 RM-835 - Supported : Lumia 610 RM-849 - Supported : Lumia 610C RM-836 - Supported Unlock Type : Read PIN and PUK Unlock Codes Other Notes : Disconnect USB Cable before Reading Codes ================================================== ======== 1. Make sure JTAG Connection is 100% OK 2. Always Disconnect the Phone BATTERY 3. Connect RJ-45 JTAG Cable to ATF Box 4. Disconnect USB Cable from the Phone 5. DO NOT click RESET JTAG button 6. Click READ CODES button to Start Reading Unlock Codes ---------------------------------------------------------- Disconnect USB Cable from Phone (If Connected) Re-Connect USB Cable to Phone... Connect USB Cable to Phone...OK USB Connected! Waiting for First Event...OK Disconnect USB Cable Now...OK Re-Connect USB Cable to Phone... Waiting for Device Connection 10 second(s)...OK Resetting and Exploring JTAG chain...OK Halting Core with 300ms Delay...OK Initializing Device...OK Retrieving Unlock Codes...OK =================================== Service Provider Unlock Codes Found =================================== Level 1 PIN: 70795129 ACTIVE Level 1 PUK: 91230605 ACTIVE Level 2 PIN: 09848050 Level 2 PUK: 26533777 Level 3 PIN: 84863935 Level 3 PUK: 74570294 Level 4 PIN: 56609203 Level 4 PUK: 76490542 Level 5 PIN: 41239235 Level 5 PUK: 40276762 =================================== Reading Unlock Codes Done! ================================================== ========================== 1. Remove JTAG Connection and Assemble Phone 2. Insert SIM Card from different Provider into the Phone 3. Power ON the Phone 4. Enter 8-digit PIN Code or 8-digit PUK Code when Phone Requires it 5. After Code is accepted, wait 30 seconds until Operator Signal Appears Write Down 8-digit PIN CODE on a piece of paper and attach it to the phone under the battery. This will allow the owner of the phone to unlock this phone again if he will flash the phone firmware in the future. ================================================== ========================== Saving "..\Logs\Screenshots\2015-10-23_08-08-18.jpg"...OK |
11-13-2015, 09:31 | #102 (permalink) |
Crazy Poster Join Date: Jan 2008 Location: Bestncheap.net
Member: 688901 Status: Offline Sonork: 1614241 Thanks Meter: 107 | Driver Version : 00021000 Library Version : 00030207 Box Type : AdvanceBox Turbo Box Firmware : LogiCore 11.0.00 Software Version : v11.70 AdvanceBox SN : A73CB38BF6EEDBFF922A1659 Box Status : NOT ACTIVATED Please Help Bro... Thanks... Br. Alfajar Bestncheap |
11-18-2015, 21:45 | #103 (permalink) |
Junior Member Join Date: Aug 2008
Member: 840399 Status: Offline Thanks Meter: 0 | ================================================ Advance Turbo Flasher Found ================================================ Driver Version : 00021000 Library Version : 00030207 Box Type : ATF Lightning Box Firmware : LogiCore 11.0.10 Software Version : v12.20 AdvanceBox SN : C9375290FCCA9F9680DCCA17 Box Status : NOT ACTIVATED |
01-01-2016, 07:04 | #104 (permalink) |
Junior Member Join Date: Dec 2008
Member: 923784 Status: Offline Thanks Meter: 0 | Hello Mr. X-Shadow, Please check the Activation of My Box. Logs Shown Below: ================================================ ================================================ Advance Turbo Flasher Found ================================================ Driver Version : 00021206 Library Version : 00030210 Box Type : AdvanceBox Turbo Box Firmware : LogiCore 11.0.10 Software Version : v8.70 AdvanceBox SN : EC657F8FE6D69D3FF5B31529 Box Status : NOT ACTIVATED |
01-02-2016, 08:46 | #105 (permalink) | |
Member: 923784 Status: Offline Thanks Meter: 0 | Quote:
Advance Turbo Flasher Found ================================================ Driver Version : 00021206 Library Version : 00030210 Box Type : AdvanceBox Turbo Box Firmware : LogiCore 11.0.10 Software Version : v12.40 AdvanceBox SN : EC657F8FE6D69D3FF5B31529 Box Status : NOT ACTIVATED | |
