05-01-2019, 11:50 | #226 (permalink) | |
Freak Poster Join Date: Nov 2014
Member: 2301015 Status: Offline Sonork: 100.1668279 Thanks Meter: 10 | HELP ME ================================================ Advance Turbo Flasher Found ================================================ Driver Version : 00021000 Library Version : 00030207 Box Type : ATF Nitro Box Firmware : LogiCore 11.0.10 Software Version : v11.90 AdvanceBox SN : F46DB0D6FBA8C907EF840B05 ========================================= Please Try Again Later (Server Busy) ========================================= ================================================ ATF SOFTWARE IS NOT ACTIVATED ON THIS PC Please Activate your ATF Software ================================================ * Follow these Instructions 1. Connect this PC to the INTERNET 2. Restart ATF Software ================================================ Box Successfully Initialized ================================================ VBATT Powering Down <<<< VBATT Powering Up >>>> SET VCCIO Level Done SET BSI Load Done Quote:
05-03-2019, 05:57 | #227 (permalink) |
Freak Poster Join Date: Jul 2015 Location: Ukraine, Odessa
Member: 2430597 Status: Offline Thanks Meter: 83 | periodically the server turns on try later I also waited a lot and the server earned |
The Following User Says Thank You to volk12 For This Useful Post: |
09-09-2019, 21:58 | #230 (permalink) |
Crazy Poster Join Date: Sep 2011 Location: Iran Age: 37
Member: 1651673 Status: Offline Thanks Meter: 1 | please help me box mot update frimware ============================================== Please update your Box Firmware ============================================== * Follow these Instructions 1. Disconnect any phones connected to ATF Box 2. Go to "Product Support Tab" 3. Go to "Box Tools" Section 4. Click "Update Firmware" button * Make sure you put ATF Software in Windows FireWall Exclusion List * Make sure you put ATF Software in your Virus Scanner Exclusion List ================================================ Box Successfully Initialized ================================================ VBATT Powering Down <<<< VBATT Powering Up >>>> SET VCCIO Level Done SET BSI Load Done box sn: 8B4FAC7D |
09-10-2019, 13:09 | #231 (permalink) |
Member: 1651673 Status: Offline Thanks Meter: 1 | Advance Turbo Flasher Found ================================================ Driver Version : 00021228 Library Version : 00030119 Box Type : ATF Nitro Box Firmware : LogiCore 11.0.00 Software Version : v8.90 AdvanceBox SN : 8B4FAC7DA30E934AD938931D Box Status : ACTIVATED ================================================ Box Successfully Initialized ================================================ VBATT Powering Down <<<< VBATT Powering Up >>>> SET VCCIO Level Done SET BSI Load Done ///////// /// /// /////// /////// ///////// /// /// /// /// // /// /// /// /// /// /// /// /////// /////// /// /// /// /// /// /// /// /// /// /// /// /// ///// /// /// /////// ////// ======================================= /// /// /// ///////// /////// ////// ///// /// /// /// /// // /// /// /// ///// /// /// /////// /// /// /// //// /// /// /// /// /// /// /// /// /// /// /// /// ////// ======================================= |
05-25-2020, 05:51 | #238 (permalink) |
No Life Poster Join Date: Oct 2007 Location: VIZAG,A.P, INDIA
Member: 602547 Status: Offline Sonork: 100.1621466 Thanks Meter: 930 | ================================================ Advance Turbo Flasher Found ================================================ Driver Version : 00021206 Library Version : 00030210 Box Type : AdvanceBox Turbo Box Firmware : LogiCore 11.0.10 Software Version : v11.90 AdvanceBox SN : 982690E898592E19AD970812 ========================================= Please Try Again Later (Server Busy) ========================================= ================================================ ATF SOFTWARE IS NOT ACTIVATED ON THIS PC Please Activate your ATF Software ================================================ * Follow these Instructions 1. Connect this PC to the INTERNET 2. Restart ATF Software ================================================ Box Successfully Initialized ================================================ |
The Following User Says Thank You to cellcare prasad For This Useful Post: |
05-25-2020, 17:22 | #239 (permalink) |
No Life Poster Join Date: Apr 2008 Location: -=Cellulare Zone Europ-EGYPT=-
Member: 762055 Status: Offline Sonork: -=664053=- Thanks Meter: 778 | sever down dead Product . BR, -=MR_Gsm=- |
The Following User Says Thank You to -=MR_Gsm=- For This Useful Post: |
05-29-2020, 07:16 | #240 (permalink) |
Insane Poster Join Date: Nov 2017 Location: uzbekistan
Member: 2782328 Status: Offline Thanks Meter: 6 | ATF TEAM run server or activate ofline please, or give any solution. Advance Turbo Flasher Found ================================================ Driver Version : 00021206 Library Version : 00030210 Box Type : AdvanceBox Turbo Box Firmware : LogiCore 11.0.10 Software Version : v12.70 AdvanceBox SN : 15B32DEACB37D114D65BA6F4 ========================================= Please Try Again Later (Server Busy) ========================================= ================================================ ATF SOFTWARE IS NOT ACTIVATED ON THIS PC Please Activate your ATF Software ================================================ * Follow these Instructions 1. Connect this PC to the INTERNET 2. Restart ATF Software ================================================ Box Successfully Initialized ================================================ VBATT Powering Down <<<< VBATT Powering Up >>>> SET VCCIO Level Done SET BSI Load Done |
