03-11-2017, 03:11 | #1 (permalink) |
Junior Member Join Date: May 2013
Member: 1938088 Status: Offline Thanks Meter: 12 | ATF Network - Invalid Response Fix just wanted to repost what bantonman007 said in other thread because it is exactly what i needed to do to fix my problem. i use windows 7, might be different on other operating systems. go to c:\windows\system32\drivers\etc open file "hosts" with text editor remove these 2 entries: 174.120.45.28 www.advanceturboflasher.com 174.120.45.29 www.atf-lightning.com save file, reopen to make sure you really deleted the 2 entries now atf network login works. |
The Following 10 Users Say Thank You to hakim437 For This Useful Post: |
03-11-2017, 12:00 | #2 (permalink) | |
Insane Poster Join Date: Apr 2004 Location: Kwan Sing Bio Temple
Member: 64191 Status: Offline Thanks Meter: 10 | Quote:
work perfectly Advance Turbo Flasher Found ================================================ Driver Version : 00021206 Library Version : 00030210 Box Type : AdvanceBox Turbo Box Firmware : LogiCore 11.0.10 Software Version : v12.67 AdvanceBox SN : D89A5F5A9C5D5F5CD8BEEC6B Box Status : ACTIVATED ================================================ Box Successfully Initialized ================================================ VBATT Powering Down <<<< VBATT Powering Up >>>> SET VCCIO Level Done SET BSI Load Done ///////// /// /// /////// /////// ///////// /// /// /// /// // /// /// /// /// /// /// /// /////// /////// /// /// /// /// /// /// /// /// /// /// /// /// ///// /// /// /////// ////// ======================================= /// /// /// ///////// /////// ////// ///// /// /// /// /// // /// /// /// ///// /// /// /////// /// /// /// //// /// /// /// /// /// /// /// /// /// /// /// /// ////// ======================================= | |
The Following 4 Users Say Thank You to yur1 For This Useful Post: |
03-16-2017, 14:56 | #4 (permalink) |
Junior Member Join Date: Mar 2017 Location: UK
Member: 2696114 Status: Offline Thanks Meter: 2 | Ohh I have just posted a thread concerning this issue. I should have read your thread before I posted mine because simply your solution WORKED! THANKS VERY MUCH HAKIM |
