Go Back   GSM-Forum > Product Support Sections > No More Supported Solutions (Dead Products) > No More Supported H/W Products > Advance-Box
Old 01-30-2015, 17:58   #1 (permalink)
Advance-Box's Avatar
Member: 651945
Thanks Meter: 20,065
--[B][o][x]--[N][o][t]--[A][c][t][i][v][a][t][e][d]--
Before Posting Here about problems in Activating NEW or OLD ATF Boxes, Please follow Simple Steps Below:
1. Upgrade Your ATF Software to 11.90 which you can download here:
ATF_v11.90_Full_Installer.rar
2. Update Your Box Firmware to 11.0.10 via ATF 11.90 which you downloaded from Step 1.
3. Show Complete LOGS of Error Message
Moderators will AUTOMATICALLY DELETE POSTS if:
1. You are showing Logs from ATF Software which is LOWER than 11.90
2. You are showing Logs from ATF Firmware LOWER than 11.0.10
3. You are not showing COMPLETE LOGS
4. Your problem is NOT related to Box Activation
5. If you Blah Blah too much...
The Following 12 Users Say Thank You to Advance-Box For This Useful Post:
Old 01-30-2015, 18:01   #2 (permalink)
Member: 651945
Here is Example of Correct Post:
Hello Mr. X-Shadow, Please check the Activation of My Box. Logs Shown Below:
Advance Turbo Flasher Found
Driver Version : 00021000
Library Version : 00030207
Box Type : ATF Lightning
Box Firmware : LogiCore 11.0.10
Software Version : v11.90
AdvanceBox SN : D951C663B7DFF86EC12D9ABA
Box Status : NOT ACTIVATED
IF Your Post DOES NOT LOOK LIKE ABOVE, it WILL BE DELETED AUTOMATICALLY.
The Following 6 Users Say Thank You to Advance-Box For This Useful Post:
Old 01-31-2015, 08:25   #3 (permalink)
xtreme's Avatar
Member: 48518
Sonork: 100.113013
Thanks Meter: 112
Hi
Box Type : AJF Lightiing
AdvanceBox SN : 828CADCD4AEB9FB995DB99FE
ERROR: Invalid Reply Detected... 0xB003
ATF SOFTWARE IS NOT ACTIVATED ON THIS PC
Please Activate your ATF Software
Box Sn now shows 00000
Old 02-01-2015, 06:22   #4 (permalink)
omi17's Avatar
Member: 1950912
Sonork: 100.1654643(Offline)
Thanks Meter: 397
Smile
Box Successfully Initialized
Box Type : ATF Nitro
AdvanceBox SN : 8E1D3522856DFAF5C299FE00
* Follow these Instructions
1. Connect this PC to the INTERNET
2. Restart ATF Software
Hope You Solve My Problem Soon
Old 02-01-2015, 07:04   #5 (permalink)
Member: 2233182
Sonork: 100.1658712
Thanks Meter: 18
Box Type : ‡TF Nitro9
AdvanceBox SN : F17F497C963DC71BCEAF3969
************ ATF Box EEPROM Updated ************
Please Restart ATF Software...
Install NEW ATF Box Drivers if needed...
Plus this errors
1-After restore box
a)The parameter is incorrect
b)The requested source is in use
c)The handle is invalid
2-When Activating
'N1' is not an interger value
Old 02-01-2015, 07:19   #6 (permalink)
Member: 651945
@xtreme
@muzammal mudass
@omi17
@baalwy
1. DISCONNECT ATF BOX from USB Port
2. Run AdvanceBox.exe version 11.90 without BOX Connected
3. Go to "Product Support" ----> "Box Tools"
4. Make sure "ATF Nitro / Light" is selected on the right side
*** NOW CONNECT ATF BOX TO USB PORT ***
5. Click "Restore Box" and wait 2 to 5 minutes...
*** After Restore Box is Done, it will tell you to UPDATE FIRMWARE
6. Click "Update Firmware" and wait 2 to 5 minutes...
This way, box will be FULLY RESTORE Just like Brand New from Factory.
The Following 2 Users Say Thank You to Advance-Box For This Useful Post:
Old 02-01-2015, 07:20   #7 (permalink)
Member: 2233182
Sonork: 100.1658712
Thanks Meter: 18
FEEL THE POWER...ATF BOOOOOMS AND ROCKS
AdvanceBox SN : F17F497CE13DC7BCCEAF3969
Box Status : ACTIVATED
STEPS
-RESTORE EEPROM
-RESTORE BOX
-UPDATE FIRMWARE
-AUTO ACTIVATED
The Following User Says Thank You to baalwy For This Useful Post:
Old 02-01-2015, 13:42   #8 (permalink)
Member: 420870
Thanks Meter: 10
hello sir
hi my atf box is activated
Box Type : AdvanceBox Turbo
Box Firmware : LogiCore 11.0.00
Software Version : v11.80
AdvanceBox SN : EA25BAE5F8E04E73E7CB07EA
my jtag is also activated
but authorize bb5 is not higlighted in my box .. how to authorize it . please send me info
Old 02-01-2015, 19:37   #9 (permalink)
allumts's Avatar
Member: 1564612
Thanks Meter: 11,282
@rohit41u,
Start Installing last version 11.90 with New Core 11.10 and after if have this problem open you own thread, not here.
allumts
Old 02-01-2015, 19:49   #10 (permalink)
Al-Magic's Avatar
Member: 2189966
Sonork: 100.1653836
Thanks Meter: 111
AdvanceBox SN : E00FE0AEDB31A9F3C8906950
VBATT Powering Down <<<<
VBATT Powering Up >>>>
SET VCCIO Level Done
SET BSI Load Done
Old 02-01-2015, 20:00   #11 (permalink)
allumts's Avatar
Member: 1564612
Guys do the applause at @Al-Magic for have installed an easy update and for having soiled the thread....
Old 02-02-2015, 09:38   #12 (permalink)
Member: 1163778
Sonork: 246
ATF not active
AdvanceBox SN : B583728789701FFE894D1CAD
date: 2013-11-22
Old 02-02-2015, 13:22   #13 (permalink)
Member: 2335963
AdvanceBox SN : CB95BFC4B0280CC0D05AD693
Old 02-03-2015, 01:16   #14 (permalink)
Member: 2240524
need help with this issue
Connecting to : 59.148.208.118
>> Connect timed out.
>> Connect timed out.
10:17:24 : Advance Turbo Flasher Found
10:17:24 : ================================================
10:17:24 : Driver Version : 00021200
10:17:24 : Library Version : 00030209
10:17:26 : Box Type : ATF Nitro
10:17:26 : Box Firmware : LogiCore 11.0.10
10:17:26 : Software Version : v11.90
10:17:26 : AdvanceBox SN : A9E8C139F050D62093F59871
10:17:26 : Box Status : ACTIVATED
10:17:26 : ================================================
10:17:26 : Box Successfully Initialized
10:17:27 :
10:17:27 : VBATT Powering Down <<<<
10:17:30 : VBATT Powering Up >>>>
10:17:30 : SET VCCIO Level Done
10:17:30 : SET BSI Load Done
10:17:30 :
Old 02-03-2015, 03:24   #15 (permalink)
Member: 1163778
Sonork: 246
ATF not active
date: 2013-11-22
restore box ok,update frimware ok but activation not avaiable.please help me
The Following User Says Thank You to laodai1983 For This Useful Post:
Page generated in 0.51519 seconds with 7 queries
